Question about Maytag MFT2771WEM Top Freezer Side by Side Bottom Freezer French Door Refrigerator
I have a Maytag French door fridge with water and ice on the door. The water is flowing into the filter but not flowing out to supply water to door or water to make ice. I replaced the filter but did not help. Water used to flow out very slowly but now not at all. Seems to be a clog or could the line out of the filter be frozen? When you push for water on the door you can hear it flow into the filter. Then I take the filter off and the water pours out. Please help. Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
Check the inlet valve on the water supply sometimes these do not open correctly not allowing full pressure to go through
Posted on Jun 02, 2017
SOURCE: water dispenser
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Posted on Oct 30, 2008
catriver
  • 878 Answers
SOURCE: Maytag MFD2561HES
Texas, sounds like your water reservoir is frozen up. Remove your 2 cripser drawers, you will see the reservoir behind them. Take a hair dryer and go over the tank and tubing ends. See if the water starts flowing. I find a lot of frozen water reservoirs on these french door models. They have a insulation kit for them. Catriver.
Posted on Sep 29, 2007
aborcass
  • 2651 Answers
SOURCE: maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Posted on Mar 12, 2008
  • 19 Answers
SOURCE: Can't unlock ice water depenser on maytag side by side
On most brands all you have to do is hold the lock button until it unlocks.
Posted on Jun 10, 2009
  • 2976 Answers
SOURCE: Water flow on my Maytag ICE20 is very slow.
The orifice into the filter is getting clogged. A toothpick or small paperclip will clear it.
Posted on Jul 21, 2009
Squeeking noise when using water service- poor flow. sometimes squeak when ice maker fills
Do you have filter in the fridge?This will cause this type of problem. Have you replaced it lately?
Jul 22, 2015 | Maytag MFD2560HES Bottom Freezer French...
I have a Maytag French Door Bottom Freezer / Refrigerator. Model MFI2568AEW. I changed the water filter today and 10 seconds after installing the new filter it started making a very loud noise like
Sounds like water hammer, has the water supply got it's own shut-off valve behind the fridge or in the basement ? Try shutting the valve then open it just a little. Perhaps the water supply was opened fully after installing the new filter.
Oct 15, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag fridge
Hi, our frig takes about 24 hours to start making ice. According to our owner's manual that's normal.
Aug 07, 2014 | Maytag MFI2568AE Side by Side French Door...
Our ice maker stopped working. there is water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfdjdfh
May 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
Jul 21, 2009 | Maytag MFD2562KE Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Filtered water
what kind of supply line is going to the dispenser,, if you have well water you might want to think about even another filter in the line before the frige, change the supply line to copper if it is copper change it to another copper line,,, there is no reason for it to only happen to the ice maker,, what about the ice bucket and ice tray:{where the water fills to make the ice} try cleaning these also
Aug 04, 2008 | Maytag MFD2561HE Bottom Freezer French...
Maytag MFD2561HES
Sep 29, 2007 | Maytag MFD2561HE Stainless Steel Bottom...
Maytag MFT2771WEM Top Freezer Side by Side Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
