Question about Freecom 120 GB USB 20 Hard Drive
USB device not recognize,which is my nightmare and also problem, and i know the problem is my hard drive model so what can i do to solve this problem?
  • Freecom Master
  • 27,725 Answers
Click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Posted on May 27, 2011
Romulus Name for Maxtro D540X
U can do one thing , convert your HDD using ide to usb or sata to usb converter and connect ur HDD via usb and check what happens....
Dec 26, 2013 | Maxtor DiamondMax D540X 40 GB Hard Drive
USB DEVICE NOT RECOGNIZED One of the USB devices
This may cause if your USB port is out of order. Or your pen drive is not in good condition.
Think this is helpful !
Aug 11, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hello i have a problem with my external hard drive (320GB western digital), when i'm connect to my PC..the windows does not recognized it and said malfunction device.How can i solve it? Need help nooriz
Unplug all USB devices that may be connected. Then do the following.
You can attempt a repair of the USB system by opening The Device Manager and
removing all of the USB devices. Then reboot the computer, that should cause
Windows to reload the USB drivers from the dll cache
Nov 14, 2009 | Western Digital (WD3200JS) 320 GB Hard...
I have an external hard drive back up, Verbatim, Model USB320 and my computer does not recognize it being attached.
Hello
A few questions that may confirm problem.
Does your computer seem to know that something is plugged in?
Or does it say that it does not recognize the device?
Well, if the computer actually knows that a device has been plugged in, but you just cannot see the device in my computer, here is how you fix that. Just follow these steps:
Control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your device presented in the schematic below.
Right click on the device and assign a new drive letter.
If your computer states that it does not recognize the device, try plugging it in one of the back USB ports of the computer. Please rate this.
Best regards
Sep 29, 2009 | Verbatim SmartDisk Firelite Portable USB...
External hard drive
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your USB drive
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 09, 2009 | Computers & Internet
My laptop HP zd8000 doesn't recognize Seagate external hard drive
hi..the reason for your problem is your extenal
hard drive has been affected by viruses.The best
solution to this problem is scanning your hard drive.
once you scan it u will be free of viruses and your
laptop will be able to recognise your hard drive.
try it out..
thank u..
rate me..
Feb 10, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Driver needed for 2gb kingston usb
If it is Win XP with SP1 ( check this - tight click My Computer, click Properties and check if it is Service Pack 1), then you need the latest SP from microsoft (that is SP3).
WinXP not recognizing USB drives, the SP is the most common cause I  have seen. Update to SP3 and it should solve your problem.
HTH,
Deboo
Dec 08, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My U3 Smart SanDisk Cruzer Micro 2.0GB USB Drive Not Recognized
We can fix it -- and recover the data (provided it is recoverable -- which it generally is). If we don't get your data back, we ship the drive back to you and you pay nothing. We've been recovering data for over 16 years and are successful about 85% of the time.
Craftsman Computer Services, Cudahy, Wisconsin
Aug 02, 2008 | SanDisk 1GB Cruzer Titanium USB Flash...
USB device not recognized
if it,s showing in the device manager as an exclamation mark. that means it,s found it, but can,t recognise it.
i,d suggest formatting and partitioning it, with some good software. also ensure that it,s powered via 2 usb cables to laptop, from 1 on the drive itself. some bigger hard-drives, need the extra power to drive them.
Mike @ compurepair.
Jul 25, 2008 | Western Digital 500GB My Book World...
Freecom 120 GB USB 20 Hard Drive Logo
169 people viewed this question
Top Freecom Computers & Internet Experts
Greg Ulan
Mithilesh Kumar
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
