Icannot get power on the load sie of my GE 15132 timer . must ialso conct the 2 com and 2nc to obtain power?
  • 11,800 Answers
The wiring depends entirely on what the driven device will be and at what voltage - some require the 2 NC connectors to be wired while others don't.
You can see all the recommended wirings in the manual, at page 2. If you no longer have it you can download it from here
https://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15132-Manual-eng.pdf
Posted on May 27, 2011
My GE timer, model 15132 has stopped working. I can see that resistor R2 on the circuit board has fried (it's black). Anyone know the value of this resistor?
Usually if you look close, several parts have burn or blackened area at point of solder.
This indicates that multiple parts are affected... replace timer.
Otherwise, there is no schematic for these types of digital timers that shows the value of parts.
Following resources have images of similar problem, and similar timers.
http://waterheatertimer.org/Timer-caught-fire.html#resistor
http://waterheatertimer.org/Boxtype.html
http://waterheatertimer.org/How-to-wire-GM40-timer.html
Gene
Water Heater Timers Save Money
Jul 10, 2015 | GE Hardware & Accessories
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Dec 05, 2014 | Hardware & Accessories
The display has gone blank on T1033 . the only way to get towel rack to work is by pressing the on/off selector
1) Try resetting timer. Aube/Honeywell TI033 7-day 2400watt timer cannot be exposed to temperatures below freezing, even though manual says -5 F. High temperature range is 122 F .
This timer has 3-year limited warranty. Internal battery is non-replaceable.
http://waterheatertimer.org/Aube-timers-and-manuals.html
2) There is no other programmable in-wall timer that can handle 2400 watts without using contactor.
3) Replace with GE 15132 timer for cold environments, and single-pole or 3-way operation: Use contactor for heavy loads.
http://waterheatertimer.org/images/Dawn-dusk-120Volt-pump22-28.jpg
4) Add comment as needed
Dec 28, 2012 | Hardware & Accessories
No digital display on my ge 15132 timer
Reset timer and reprogram.
If functionality is not restored, then timer has gone bad.
http://waterheatertimer.org/How-to-wire-GE-15132-timer.html
GE15132 digital timer from Home Depot has 1 year limited warranty.
Digital timers do not have replacement parts, and are susceptible to power surge such as simple power outage.
Buy new timer at Home Depot, and return defect timer in new package for refund.
Oct 10, 2012 | Hardware & Accessories
How to ground a Tork EW103B time switch wired for 240Volt since there is no ground lug in the plastic housing or on the body of the timer itself
Many plastic timer enclosures do not have ground screw.
Simply join the ground wires inside wiring space using wire nut.
http://waterheatertimer.org/Tork-Digital-timers-and-manuals.html#ew
Since the timer mechanism is plastic, it is non-conductive.
It's like using all-plastic electric drill. The drill does not have ground wire because the electrical components are housed completely in non-conductive plastic.
You can buy the Tork 9000A metal Nema3R enclosure if grounding is preferred. Or buy Intermatic 2T511GA metal Nema3R enclosure plus buy Tork IAP adapter to fit Intermatic enclosures.
Choose the metal enclosures when conduit needs to be supported and timer could be hit by some object.
The non-grounded box and non-grounded timer is also true of GE digital timers 15132 and 15136. Which coincidentally have same wiring as EW103 when using 240Volt.
However the Tork DTU40 timer has ground screw >>> but the timer is not grounded, so ground screw is merely for joining wires together.
http://waterheatertimer.org/images/IMG_2232-Tork-DTU-timer-600.jpg
Jul 31, 2012 | TORK Hardware & Accessories
My GE 15132 was operating fine for a year but now is losing time..the clock runs about 4 hours a day slow...I am resetting it once or twice a day....what could be wrong??
Contact Jasco and tell them what you said here.
http://www.jascoproducts.com/contactus/index.asp
Although GE has made high-quality timers for many years, the 15000 series box timers have been on the mass market for a year or so, and there are no replacement parts like available for Intermatic timers.
http://waterheatertimer.org/GE-timers-and-manuals.html
I tested the GE series and found them to be cheaply made with moveable plastic parts and lightweight overall.
http://waterheatertimer.org/GE-15207-clock.html
Jun 24, 2011 | General Electric GE 56941 24-Hour Outdoor...
I have a ge timer 15132 and it is wired up properly feed to screw 1 and 2 , jumper from hot to com, load to no contact and the neutral tied with the other from the feed, all the time are set proper and the...
I have tested this timer.
GE 15132 timer can be wired muliple ways to accommodate different voltages and many different timing needs.
1) First thing is you must set dip switches BEFORE applying power.
Timer arrives pre-set for 277Volts.
For 120V, set all 4 dip switches to the left, or ON.
2) Otherwise your wiring sounds correct.
Hot black wire to far left 'clock' terminal.
Neutral white wire to next 'clock' terminal.
Jumper from Hot terminal to COM terminal.
Black Load wire on NO terminal.
White Load wire to same 'clock' terminal as Neutral
3) Possible solution:
Move wires to COM2 and NO2 and see if that relay is working.
4) Make sure your programming does not have conflicts.
See if manual override is working.
Test for voltage across 'clock' terminals
Move manual override and watch if relay clicks open-closed.
Check that Load is operable by moving NO wire to COM terminal.
5) If timer is not functioning, exchange at Home Depot.
You can switch out mechanism without replacing box.
Mechanism is held with hex screws.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 22, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
Quisiera saber biem como se conerta ,en 120 v el digital interruptor horario ge 15132
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/15132-Manual-spn.pdf
Estoy usando traductor Google.
http://translate.google.com/
Por encima se enlazan con 15.132 manuales en espa?ol.
Me escribi? una p?gina web sobre el temporizador de GE 15132.
Las p?ginas se muestra el cableado.
Sin embargo, las instrucciones est?n en Ingl?s.
Utilice traductor Google para ayudarle a entender las instrucciones de p?gina web.
A?ade un comentario en el fondo, si puedo ayudar m?s.
Nov 07, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
GE Digital Time Switch (15132) for basic landscape lighting
Leave the breaker off, remove the wires from the timer and just connect them. then turn the power on. Unless you have a short somewhere, the lights should come on. What you have just done is made the breaker your switch. If the breaker kicks you know to keep looking for a short as it is not the timer. Regards, Joe
Jan 04, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
