Question about PC Chips P21G (881038000916) Motherboard
What is in a pc main things - PC Chips P21G (881038000916) Motherboard
  • 65 Answers
Video ans sound cables card wifi and ethjernet aloty of stuff
Posted on May 27, 2011
Testimonial: "thanks man"
Asus eee pc 1000ha wont take charge from adapter
try unplugging from the mains, remove the battery, hold the power button down for 30 seconds. plug the mains adapter in and try turning on. if it doesn't work then it's either the power socket or the mainboard.
if it does work, then try it again with the batter in. if it stops working then your battery's shot.
Apr 13, 2013 | ASUS Eee PC 1000HA Notebook
I have a HP G60. When i hit the power button automatically a grey screen pops up and I dont hear any boot attempt from the laptop or fan. just the cd drive adjusting. and it stays like this no buttons...
windows Vista or W7? (oldest G60 is 2008 G60-100)
so never any text at the screen battery main out.
run on AC power only, batteries are very unreliable things.
no text , like "Hit F10 to enter BIOS" as seen for 10 years. now.
this shows if the PC is alive or not. is it?
if that fails. show text then check for a dead black lamp.
no fan running means no power or its packed solid in lent.
try a new power pack.? the fan must run. or there is no power.
battery out tests ALL, leave it out. so we dont have 2 problems.
run on AC power only.
i use a thing called a volt meter to see of the 19vdc actual lands
on the main board. from that powre pack.
there are many steps, after 19vdc hits main board
we strip the whole PC down to PROVE no modules are shorted.
please test the LT with battery MAIN removed.
and report action of screen, any thing there.
and if FAN works, as it must. or will overheat FAST>
ever clean the vents on the PC? (with can-o-air)
Sep 21, 2017 | HP G60 Notebook
I have a millermatic 251 but the gat wont come out when i pull the triger
First, you need to check that you have the correct input voltage going to the machine. The main PC board on the welder disperses the input voltage to many different things,ie. the gas solenoid, the drive motors, contactors, transformer, stabilizer etc.
So if your machine is made to run on 230v and it is plugged into 208v, the first thing to stop working is the gas solenoid because it requires more voltage (34vdc on this model) to actuate.
If it turns out you are running the correct power to the machine, there is something wrong with an internal component on the machine and it needs to be brought to a certified miller service center where it will most likely be one of two things, the gas solenoid (about $30+ labor) or the main PC board ($500-600+labor) hope for the best on that one.
best of luck!
Aug 14, 2011 | Miller Welding Tools
Not working main board complaint i need service
Hi,can you please give me a little more information about your main board,any power,any video to computer screen at all,dpes the main power supply box power up where the black power cord is plugged in the back of the computer?Any of these things will help me in a closer resolution to your problem,thank you:)
Feb 22, 2011 | Computers & Internet
I have A FIC AD11 motherboard in my PC and a 1st main board CD for it. When I had 98se in this PC I could use the 1st Main-board CD to set up the FIC AD11 motherboard. Now that I have switched to XP...
All the drivers for it are already in the XP install disk and were loaded when you installed it - so no need for a separate drivers disk like the one for 98se.
Dec 06, 2010 | FIC AD 11 (51-80439-00) Motherboard
My home network was working fine for a long time. Here's the config: cable modem > main PC > Tu2-ET100 > xover cable > TU2-ET100 > second PC. I can connect PC to PC fine, Internet on main...
if one computer is working and the second one hooked on it not than it may be a cable thing ..if both are not working than it is a network and you have to call the provider...to check that plug them one by one directly to the main cable ..cause there is a possibility the the main ones LAN card to failed ..and cause both are basically connected trough it they can not work ..
Usually most computers have a on board LAN port ...if it is a suspicion that the LAN card failed try to use the one on board ..
Sep 02, 2010 | Trendware TRENDnet TU2 ET100 network...
Main fan on dell dimension e521 on full blast when comp on
Do you have your PC in some sort of enclosed space with little ventilation? If so, the constant fan activity is your PC trying to keep things cool inside. With little ventilation comes great heat, and PCs like it cool.
Dec 27, 2008 | Dell Dimension E521 PC Desktop
Insignia TV040919
Look for burned PC board traces on the bottom of the main board. With lightning/surges it could be a wide variety of things. You're probably doing the right thing in looking for a main board however it's probably going to cost you more than the set is worth to go that route........even if parts are available.
Oct 06, 2008 | Insignia IS 20" TV040919 TV
Mirroring, I think
hey are you trying to clone your main computer to set up ur 2nd hand comp?
if so try this one
download norton ghost @
http://norton-ghost.en.softonic.com/
Apr 25, 2008 | Dell Dimension 8200 PC Desktop
Red power light on, making a noise but won't switch on/off
hi dear customer. add fast check the electric power and voltage. latter , cheking jumper on the main board, total main boart opening the cacing out,servising total main board.
Jan 14, 2008 | Packard Bell iMedia 6826 (P481000502) PC...
PC Chips P21G (881038000916) Motherboard Logo
55 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
