I have a Altec Lansing ADA885 Computer Speakers with a subwoofer that came with my dell computer. Sometimes the subwoofer play and sometimes it dont. Can you help me fix this problem? Thanks
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 27, 2011
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
Trying to connect to TV but only center speaker works. System came with Dell Computer. Have 5 speakers and subwoofer????
Hi there bud ...Are you sure you using the RCA Cables , and not just the Cables that came with SPeakers?
Also make sure THat your T.V can handle 5.1 Channel Sound Speakers..
Hope you come right bud
Happy new year
Jan 07, 2010 | Altec Lansing ACS 45.1 Computer Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
I can't seem to find the drivers for my altec lansing ada885 speakers for my dell dimension 8100
i think you dont to find a driver for altec speakers, it sould be your sound card of your pc might need to have the drivers.
Nov 07, 2009 | Computers & Internet
Subwoofer fuse 'holder' missing.
tape or solder a piece of metal across where the fuze and holder would go.
OR
go to radio shack, pick up a small cartridge style fuze holder and an appropriate replacement fuze. (if you dont have the original fuze, dont bother with this method) Open the box or case to gain access to the circuit board. solder a new holder to the contacts.
Be aware that I have no clue what the fuze holder on that particular model looks like.
May 27, 2009 | Altec Lansing ADA 885 Computer Speakers
My subwoofer (Altec Lansing[AVS500]) is always makeing a thumping
You could only verify this by gaining access to the rear of the speaker but I suspect that the 'spider' has come unglued. This is a device that surrounds the lower (inner) end of the cone to provide a second point of suspension; without this, the voice coil can slap against the side or bottom of the magnet structure.
I don't think a repair is an economical choice for these; repairs only make sense for 'professional' speakers that cost several hundred dollars to replace.
Apr 13, 2009 | Altec Lansing 621 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
