Question about Microwave Ovens
Sharp microwave oven works (lights, turntable etc) but doesn't heat.
    Scholar:
  • 142 Answers
First you need to make sure that all "normally open" door switches are closing when you close the door. Next would be the diode. That is a little black thing that runs from one of the capacitor terminals to the chassis. You should have continuity one way, but NO continuity when you reverse test it. It is like an electrical check valve so to speak. If that shows open both ways, or continuity both ways, replace it and you should have fixed your microwave oven. Of course there are a lot of other ways your oven does not work. Get back to me if you need more help.
Posted on May 27, 2011
    Problem Solver:
  • 9 Answers
Try to replace magnetron and diode usualy that's the most problem of microwave hope that works
Sharp combo microwave: Turntable wont stop unless I leave the door ajar. Light stays on too while turntable is going. Everything else works fine - it just doesn't know when to shut up! :)
It's a door switch that's bad. Probably the secondary interlock switch. You need an ohm meter to verify switch not 'making' electrically. Usually the only thing that causes this switch to fail is from opening the door when the microwave is cooking, secondly, by cooking at very extended lengths of time.
Aug 28, 2013 | Sharp Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Sharp R-405H microwave turntable doesn't rotate and makes strange noise
Replace the turntable motor, it is defective and will only get worse.
Mar 17, 2012 | Sharp R-405H 1100 Watts Microwave Oven
Our sharp r520lw just quit working, timer works, light works, all buttons work, (clear, etc) however turntable doesn't work and no
That would be a bad bottom door switch or its mount.
See the help file on door switches here.
See the service manual here.
Dec 13, 2011 | Sharp R-520LW Microwave Oven
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Jan 08, 2009 | Sharp Microwave Ovens
Turntable stop working along with microwave and convection oven
would be a door micro-swtch sharp part # Sharp Part Number: QSW-MA085WRE0
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
