Question about Pride Jazzy Select 6 Indoor Power Wheelchair
Jazzy power chair 1103 ultra won`t turn on .I tried the unlock procedure no luck.new face plate is ordered .had been using a pen to turn on and off .the last time there was a beeping sound would not stop I unpluged battery ,than reconnected but now nothing
  • 5 Answers
SOURCE: i need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Posted on Jan 28, 2010
  • 31 Answers
SOURCE: y mom's jazzy 1103 ultra will not operate .
Make sure motors are in gear. Unplug from wall then try to turn on.
Posted on Jun 26, 2010
  • 692 Answers
SOURCE: I just gave my mother
tam The batteries need to be replaced. With the lights flashing indicating low voltage and the chair just creeping means weak batteries. With a donated chair you do not know how long the chair sat without being charged. You need to purchase 2 U1 batteries. If there is a battery warehouse store near you or an Interstate battery store check with them because your cost will be less than going through a provider. Hope this helps you
Posted on Sep 26, 2010
HoverTech
  • 232 Answers
SOURCE: Re: Pride Jazzy 1103 Ultra.
When the power seat lift lowers down, there is usually a bracket that pushes a button under the seat that tells the motor the seat is lowered and the power chair is safe to operate. Sometimes the bracket can get bent and the button does not get pressed when the seat goes down. Check under the seat around the seat post for the button and make sure the bracket is connecting to it. Carefully bend it back into place if it is not hitting the button properly. If the bracket came off, it will need to be replaced.
Posted on Oct 20, 2010
  • 4 Answers
SOURCE: I have a Jazzy 1103
It could be a few things.
It might be on freewheel. To solve this: 1. Turn the chair off. 2. Locate the freewheel lever just behind the drive wheel, and on top of the motor. 3. Push the lever inward to engage the motors. 4. Repeat steps 1 and 2 for the other side. 5. Turn the chair on and see if it works .
If not, it the circuit breaker might need to be reset because of heavy strain on the motors and batteries. To solve this: 1. Turn the chair off. 2. Find the circuit breaker on the front of the case, off to the right side (you will see a hole in the case) 3. Press the circuit breaker button. 4. Turn the chair on and see if it works.
if not, the battery may need to be disconnected and reconnected To do this 1. Turn the chair off 2. Release the friction lock lever under the seat. 3. Remove the seat. 4. Release the rear shroud fastener and the yellow fastener under the front shroud. 5. Remove the shroud. 6. Disconnect and reconnect the battery connector (the big plug) 7. Replace the shroud and seat. 8. Turn the chair on and see if it works.
If not, contact your provider.
Posted on Feb 25, 2011
How to reset controller on jazzy power chair
yellow light is flashing and i can't turn chair off. still operates.
Jun 20, 2012 | Pride Jazzy 1103 Ultra Standard Power...
I have changed out the batteries and hand control on my Jazzy 1103 Ultra.but now the circuit breaker keeps tripping. Dee
Donna sounds like the wiring could be the problem. Did you change the batteries? Does the joystick light up when you turn the chair on? Or does the breaker pop when you try to turn the chair on? Give me as much info as you can as to what you are doing when the breaker pops thanks
Jan 31, 2011 | Pride Jazzy 1103 Ultra Standard Power...
Left jazzy uncharged for a couple months now the lights just blink and it wont operate.
Strong you need new batteries. The batteries aren't strong enough to power up the chair and no amount of charging will bring em back. Sorry Good luck
Nov 14, 2010 | Pride Jazzy 1103 Ultra Standard Power...
I have a Jazzy Power Chair that hasn't been in use for several years. When I tried to charge the battery only the red light comes on. How do I get the yellow light to come on to show it is being charged?
Retired get new batteries if they haven't been charged for that long they're shot. Invest in 2 good U1 batteries, charge before use and you should be good to go Good Luck
Nov 01, 2010 | Pride Jazzy 1103 Ultra Standard Power...
The battery light flashes and the chair wont go.
Sounds like it might be time to change the batteries. Even if batteries are charged correctly they eventually lose power with use and need to be changed. Here is a link to the battery needed for the Jazzy 1103 Ultra http://www.replacementupsbattery.com/UB12350-NB.html
Oct 31, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Y mom's jazzy 1103 ultra will not operate .
Jun 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Replacing battteries in Jazzy 1103 power chair
Here's a quick link to the owners manual for the 1103 that will show you how to replace the batteries on your chair.
http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_1103_Ultra_om.pdf
Oct 22, 2009 | Pride Jazzy 1103 Ultra Indoor Power...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
143 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
