Question about Microwave Ovens
Just received a Grohe hand held sprayer 46 298 IE0 for a kitchen faucet as raplacement for a previous model. It came with 2 inserts, one white and the other yellow that appear to go into the handle. How and which do I use?
jyackle5
  • 8197 Answers
SOURCE: I have a problem with
On the link below is the install manual for your faucet. It will tell you how to tighten the faucet.
http://www.groheamerica.com/lib/1/tpi/1120380.pdf
http://www.groheamerica.com/lib/1/tpi/1311678.pdf
If you need to contact Grohe for parts go to this link below.
http://www.groheamerica.com/en/contact-grohe/p/25_16615.html
Posted on Jan 30, 2011
valeantudor
  • 787 Answers
SOURCE: Delta single handle kitchen faucet
Where does it leak?
Posted on Feb 21, 2011
male_28_cam
  • 1555 Answers
SOURCE: My Grohe Ashford faucet is
Sorry, I got your solution and was about to post and at the same moment supply went off. I don't use a ups. sorry for my fault. I will not let your money flush out, Indeed I will fix your sink. I'm barely on my bike battery because no supply is here kindly give me another few hours because we are facing a torando out here. I will make sure that you will get your output more than your investment.
Posted on Apr 02, 2011
heatman101
  • 43501 Answers
SOURCE: have just installed glacier bay
Take it back to HD or Lowes where you got it and trade it in for a Delta....you will be glad you did... this is only the beginning of your problems....you get what you pay for...
heatman101
Posted on Apr 21, 2011
sassycass720
SOURCE: Moen 7600 kitchen faucet leaking
If you mean that there is leaking from around the base of the handle or the stem instead of the faucet head, that sounds like an O Ring that needs replacement.
Posted on Oct 01, 2011
The small round metal mesh discs inside the kitchen tap have fallen out & will not stay in when re-inserted. Now the water squirts out at weird angles drenching the kitchen work surfaces. Do I need a...
Hi Jean,
These mesh discs and the part they go into - along with a few other small parts - make up what is called "an aerator".
Most aerators simply screw on threads at the end of your faucet. You can remove it by twisting it. You may need a wrench to loosen it first. Wrap the aerator in thick cloth / towel so that the wrench does not dent or scrape the finish on the aerator body.
Some aerators thread up and inside the faucet - rather than at the end - and need a special wrench to remove
Once removed, you should reassemble the parts and reinstall on the faucet. You may find replacement aerators in Home Depot, Lowe's, etc. if you're missing parts, etc. If changing it out, be sure to bring the old one with you to match.
I hope this helps & good luck!
Sep 22, 2011 | Microwave Ovens
I obtained a Grohe replacement faucet head (kitchen) - part number 46298IE). The box contains (besides the faucet head) two small round cylinders (white); one has a green end; the other is white with a...
Thanks for the info about the lifetime warranty, who knew? The two parts mentioned are flow control valves that get inserted at the base of the sprayhead, not the in the hose. The green one says "water care" which will restrict flow more than the white one. It's an either or scenario, not both. There is a VERY faint arrow that points up toward the top of the nozzle. Push it all the way up and reconnect the hose tightly. That's it. My replacement didn't come with a wrench, did that come with the original faucet?
One more thing, if you bought a house that has this and don't qualify for the lifetime warranty, don't get stuck paying $100-$150 for this part if you just need to replace the aerator. The gray head that the water comes out twists out with a wrench revealing the aerator. The part number is 13929 or sometimes referred as 1392900, $10-15, if you can find it.
Sep 19, 2011 | Microwave Ovens
Don't know what the extra water line is for on my new kitchen faucet
Is it for the auxiliary sprayer that you may not have? You don't give much information about your new faucet except you do say it is on your microwave oven. I could give better help if I had an idea what make/brand/model it was.
Thank you for your question @ FixYa.com
Aug 15, 2011 | Microwave Ovens
I have a Price Pfister faucet model F-534-70CC. It won't swivel,what do I do????
If this was a new install, back off the retaining nut a half turn. Most people have a habit of overtightening.
If it has been installed for quite some time, check to make sure that the sprayer hose is not wrapped around something or wegged somehow (under the sink).
Jul 08, 2011 | Microwave Ovens
Have just installed glacier bay faucet model #8181/ 785 564 single handle with pull-out sprayer. once pulled out the sprayer will not re-seat into the faucet but hangs out about an inch or two. have...
heatman101
Apr 21, 2011 | Microwave Ovens
My Grohe Ashford faucet is loose from kitchen sink. For the price - the things seems cheap to me - under the sink some traingular piece of plastic holds it in - but no apparent screw to tighten? What am I...
Apr 02, 2011 | Microwave Ovens
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
Feb 25, 2011 | Microwave Ovens
I have a grohe model 33 790 and it is dripping so i assume the cartridge needs to be replaced. how do i get the cover off to get to it stansevey@aol.com
You shouldn't have posted this in the microwave oven section - the 33790 is a faucet!
Facing the faucet, on the right (where the lever is) the en-cap is bayonet mounted - twist and pull.
To remove the cartridge, there is a key that needs to be pullet out from the cavity , the lever unhooked and the cartridge pulls out. The replacement o-rings and special oval seals are available from Guillen in Florida.
Aug 22, 2010 | Microwave Ovens
Microwave Ovens Logo
1,647 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
