Question about Garden
Received a new hose,valve, regulator part #G517-5200-W1 for our grill from the manufacturer. How do I take out the old and put in the new?
frcs68
  • 1605 Answers
SOURCE: weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Posted on Mar 24, 2009
  • 512 Answers
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Posted on Jun 17, 2009
  • 494 Answers
SOURCE: Replacing hoses and regulator on gas grill
I work for a propane co. I get many customers that bring in their melted or leaking bbq grill hoses and regs. Bring the bad hose/reg to your local propane gas co and see if they can make a custom hose for you. You may have to buy a new regulator to use it with the new hose, but that's better than buying a new grill. Call around first and see which ones can do it. You'll eventually find someone that can fix you up.
Posted on May 16, 2010
Testimonial: "great suggestion - i'll give it a shot. Thank you!"
radar001
  • 1051 Answers
SOURCE: Genesis Silver B Grill: grill won't heat past 350 or so. put a new regulat...
An odd thing with many propane gas grills is how the regulator functions. If the tank is opened too fast the regulator over-adjusts and delivers no gas. Try this: Turn tank off and open all burner controls. This should clear the line of any gas. Close burner controls and open tank very slow. Now lite and temp should go up.
Posted on May 19, 2010
  • 561 Answers
SOURCE: I have a Kenmore model 141.16681 and gas now leaks at the regulator valve
check regulator to see that the rubber seal in the tank coupling
is still good if this has perished or fallen out this maybe the cause of
gas at this point.
best purchase a new regulator if it seems faulty, this part is your life saver, and after 8 years good service could well need replacement.
I hope this was useful.
Posted on Sep 02, 2012
Put on new tank and grill won't ignite. Connection is tight. Once I heard the gas and now nothing. It's been days. I tried cleaning out a bit. The large black plastic cap does have some cracks...
I don't think you need a new ignitor kit. The problem isn't there. It's the grill's regulator.
However, I do have some concern with the cracks inside the Hose Connect to the tank, being cracked. That should be replaced. You can pickup a new Hose/Regulator Assembly for about $30.00 any hardware store or home improvement center that sell grills and accessories. Take the old one with you for comparison purposes.
After installing the new hose. Open the Gas Valve on the tank VERY. VERY Slowly (Slow motion, slow). Doing it this way will, eliminate the problem you're having now. And always to it this way in the future.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Aug 13, 2011 | Weber Genesis Silver B Grill
I recently changed new tank on Ducane, when I tried to ignite it wont, and also I see air flow at orifice at the regulator. I feel it when I tried to put finger on the orifice. please help.
Simple solution to get you grilling again.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first & turn it to HIGH.
Did the burner light and the fa,e height look correct? If so, light the remaining burner exactly
the same way. Now, do all the flame heights look correct? If so, you solved the problem.
Always remember to turn the tank valve ON Very, Very Slowly.
If the above didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly, as the regulator is locked up. You can pick one up from any home center or hardware store that sell grills and accessories for about $30.00. Take your old one with you for comparison purposes.
I hope this helped you troubleshoot and solve the problem, Please let me know and Happy Grilling!!
Jul 03, 2011 | Ducane 30400040 Stainless Steel Grill
My charbroil masterflame 7000 is leaking gas. I beleive I need to replace the regulator and hose. Please advise on how to get the old hose off and put the new hose on. I need a diagram if possible. I would...
If you have already disconnected the hose from the tank. Track it back to where it connects to the burner(s) manifold. It should be up under the grill head. You should see a brass nut. Using an appropriately sized open end wrench, loosen this nut and the hose will disconnect from the grill.
The new Hose/Regulator Assembly will simply attach in the reverse order of how you removed the faulty one. After installing the new one and connecting the hose to the tank. Open the valve on the tank about halfway and check the connections for leaks. Thick soapy water, brushed on with a paint brush will work for detecting leaks. Look for bubbles other than those made by the soapy water. If you see one, tighten the connection a bit more. Be sure not to cross thread the nut, when installing it.
If you haven't purchase a new one yet, you can the Hose/regulator Assembly at any home center or hardware store that sell gas grills and accessories. They run about $30.00.
Hope this helped you and Happy Grilling.
Jun 19, 2011 | Char-Broil CharBroil Master Flame Gas...
When i push igniter it clicks but burners won't come on and i do not even smell gas , i burped it and turned gas tank upside down once, still won't work, grill is only 5 yrs old.
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it, as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 19, 2011 | Ducane 30400040 Stainless Steel Grill
New propane tank. Burner will not light, no gas flow. This was a replacement grill from coleman because they couldn't get the regulator. Starting to get very disgusted with this product.
jcw - It sounds like the regulator is locked up from turning on the gas tank valve. Happens a lot with the new OPD Valves on the grill tanks.
motion, slow).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Jun 18, 2011 | Coleman RoadTrip 9928-A50 Propane Grill
I have a Vermont Casting VM450SSP Grill that needs a new Hose Regulator-S/B Valve Assembly. I have ordered two separate times what "Appliance Factory Parts" thinks is the part I need and both...
This ma=y be a case of changes in parts for your VC Grill. The ownership of Vermont Castings changed 6 years ago, when Majestic Fireplace, who was then the owner went bankrupt and Monesson Hearth products bought VC in the bankruptcy. Shortly there after, Monesson made some sweeping changes to the grill line (your model was discontinued) and really up graded what Majestic Fireplace had done with that line of grills. Overall, they started building a better quality grill.
Unless you have a piped in high pressure propane gas system, the one that Appliance Factory Parts furnished you should work fine (based on what I saw on their website). In addition, if you purchased your grill, prior to the change in 20lb LP Gas Grill Tanks Valves, 6 years ago. Some manufacturers changed their grill hoses to conform with the new OPD Valve grill tanks. It wasn't required, they just did it, to avoid regulators locking up, when the tank valve is opened to fast.
Hope this helped answer and solve the problem for you. Happy Grilling!!
Jun 18, 2011 | Vermont American Tool Company VM450SSP...
Grill is one old and won't light. There is no gas coming from the tank to the grill. Is it the regulator?
age of the grill is irrelevant, i am old and i still can do few thingzzzz...
i assume that your regulator is connected directly to the bottle, then hose to your bottle, then hose is connected to the regulator and other end to the grill?
or it is bottle, hose, regulator, grill?
you need to follow the path regardless, be outside, light breeze is better, no open flame in at least 20m (yards) radius in any direction.
1. close gas bottle/tank
2. disconnect, everything from the bottle
3. crack open tank valve and hear if gas is escaping, close valve back
4. connect regulator to the bottle and again crack open the valve, hear if you have esacping gas, allow actually whiff of gas against your cheek or wetted finger to establish the flow. close the valve
5. connect hose to the regulator (procedure is reversed if first is hose and then regulator), crack open the valve, hear for escaping gas, check against wetted finger and cheek if there is flow, close the valve
6. connect your grill open all valves on it and open valve on the tank/bottle. allow free flow for about 30sec, close valves on grill. vent grill for about two minutes, try to ignite any of the burners. if burner ignite, you solved the problem, if they do not, and you did have flow on all previous stages, close bottle valve, disconnect everything from grill, clean grill valves and nozzles (burner have nozzle inside!), reconnect and vent again, try ignite, if ignition occures, you solve the problem, if not, then you are due for new grill...
if at any stage you do not have gas flow, this meant that this particular piece of equipment is in trouble, this particular piece of equipment need then repair or replacement, under no circumstance pull apart the reducer! NO OPEN FLAME DURING TESTING!!!
Jul 27, 2010 | Weber Q Grill
How to install a new regulator?
You can buy the regulator at Home Depot. Just cut the gas hose off at the old regulator and put new regulator on with a hose clamp. $200.00??? Somebody is trying to rip you off !!!!!
Jul 23, 2010 | Weber Genesis Silver B Grill
Replace Regulator and hose
I have a similar problem. I just spoke with a Rep from Charbroil and this model grille does not support replacement of just the hose..You need to replace the entire Valve Assembly. You can get a new Grille at Lowes for 10 dollars more than the replacement cost of the Valve....
Jul 17, 2010 | Char-Broil Quickset Traditional 463761006...
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
