Question about Gateway 7330GZ Notebook
My computer was running slow one day so I decided to do a system restore. During the restore process, my computer overheated and it shut down. Now everytime I go to turn on the computer, the gateway and windows load screens come up and then the screen just go black and it restarts itself again. Ive tried safe mode, and all of those options that come on a gateway laptop but I cant figure it out! HELP?!?
    Problem Solver:
  • 12 Answers
MAy be You have deleted the Operating system and also the Operatiing system files.
ALong with You may also have deleted the Files needed for System restore . accidently .
Please try to load the OS with teh cd which you may have received along with .
Posted on May 27, 2011
I am running in safe mode, I computer will only let me go back one day, this problen started ten days ago.
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. If you need more help with this post a reply
Hope this helps.
Jan 19, 2013 | Microsoft Windows XP Home Edition
Upon starting my dell inspiron mini 10 I have to wait 17 min before I can use the start button. ctl+alt+dell show me the process running: system idle process is the only process running, the CPU usage...
Do you have any antivirus program installed? If you have, check if it set to scan during startup. This might be the reason why your computer is slow during startup since a full computer scan can definitely eat up memory usage.
Hope this helps.
May 22, 2011 | Dell Inspiron Mini 10 Notebook
When I boot my computer the monitor flashes the Windows XP logo then goes dark and the computer shuts down and then restarts itself and start the process all over again and again
Try starting it in safe mode, F8 during the boot process, this loads a windows shell, once active, run a system restore.
(Programmes - Accessories - System tools - System restore)
Choose a date prior to your problems.
Sep 12, 2010 | Kogi L7CH Monitor
My XPS 200 keeps shutting down and power light blinks
During when does your computer shutdown? Please check the diagnostic lights at the back as well which ones have light on it during the time it would shutdown.
Since you said that the light is blinking yellow it just says that your power supply is running outside its normal operating range. So most likely you would need a change of power supply. Maybe a higher wattage would be better.
Apr 28, 2010 | Dell XPS 200 PC Desktop
Running Restore Plus! with associated HP XPP SP2 CD, runs fine until "Software is being installed for you. The system may reboot automatically. DO NOT TURN OFF POWER TO YOUR COMPUTER DURING THIS PROCESS"...
what could make your system hang is your hard disk. If the hard disk has a bad sector, then it will make the system to hang.
Observe the hard disk closely to know if it will bring any crackling sound/noise. This noise or sound indicates that the hard disk is bad.
So while considering other factors, consider your hard disk.
Good luck.
Mar 26, 2010 | Computers & Internet
Tring to run restore disk but laptop kepts shut down
Maybe it's shutting down because it overheating. Check all your air vents for dust buildup. Use an old toothbrush to brush the dust away from the vent holes and blow air through the vents using one of those compressed air cans made for cleaning keyboards. One time I worked on a Sony laptop that I had to take apart to get all the dust cleaned out of the air vent. You can also try running your restore disk with the laptop sitting right next to a window A/C unit. Try to position the laptop so it gets maximum exposure to the cold air of the A/C unit.
If you get the laptop working again and you think overheating is a problem I recommend downloading a free piece of software named FanSpeed. Here's a link.
http://www.softpedia.com/get/System/System-Info/SpeedFan.shtml I'll let you read the description for yourself, but in short it allows you to monitor the temperature inside your computer and to adjust how the fans react to this temperature.
Jun 02, 2009 | Acer Aspire 5100 Notebook
V2311US overheating and shutting down
Try to clean heatsink and fan. Make sure fan is spinning(common problem).
Mar 20, 2009 | HP Compaq Presario V2311US (EC186UA) PC...
Acer Aspire 3003 Strange Problem
Uninstall AVG and then download and install Avast Free version Antivirus. It is way better than AVG and MIGHT fix the problem.
Sep 10, 2008 | Acer Aspire 3000 Notebook
W34oua gateway system restore download
You need to solve the overheating problem first. Shut down the computer, unplug it and remove the bottom cover. Clean the dust and lint. Blow compressed air from a compressed air can. Re-install the cover and restart your computer. If you own a laptop, the fan should be running ALL THE TIME, sometimes slow, sometimes fast buta always running. Check the the fan is blowing air. If it is not, you'll need to replace it before doing anything else.
Aug 03, 2008 | Twinhead N14RATK Notebook
Bootup problem
Your CPU is overheating.
Try and get into the BIOS and increase the fan speed & any aother fan on the system. Don't increase the temperature range, as this will damage the system.
You won't be able to sort out the software problem until the system is running within the hardware limits.
You can also run a office fan to help get the system to cool while making the changes in the BIOS.
May 11, 2008 | Computers & Internet
Gateway 7330GZ Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
