Question about Dryers
Dryer super noisy,probably needs a roller drum kit.Will replace belt as well,while I am at it,and a lint catcher.HOW DO YOU REMOVE THE TOP COVER TO DO THESE REPAIRS?????,ARE THERE ANY OTHER PARTS I SHOULD REPLACE AS WELL??????
  • 1 more comment
  • einakin May 27, 2011
    What is the Brand?
  • lordbaltar May 27, 2011
    it is a Maytag,model #LDE9316ADE
    I need to know the details on removing the top off!
    Scholar:
  • 142 Answers
If it is an older dryer you can raise the top by pushing something flat, like a knife, or a scalpel between the top and the front on both sides. There are two clips that, when you push them with the scalpel, they will unlock the top. You might want to look at the front felt that the drum rides on.
Posted on May 27, 2011
Testimonial: "Thank you for that,but I tried that,and unlike my old dryer,it will not release! "
My dryer is really noisy
Hi tonybusanop...
Sounds like your drum rollers need lubricant or replacement as they will make noise when dry or worn like you describe.
I will include info on replacing the rollers on an electric dryer, they are assembled about the same as a gas dryer.
Please take time to rate me
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Aug 16, 2011 | GE DPSB613GDWW Gas Dryer
Dryer stopped spining and when i turn it by hand it makes a wierd noise
Hi jamie the ch....
Sounds like you have two problems...
1...broken belt
2...noisy rollers
I will send the info to replace the noisy rollers, and included with the info will give you info on how to change the belt.
Your problem sounds like drum rollers have flat spots on them and a broken belt.
This should solve your noise problem and belt problem.
I will include a link on how to route your belt.
http://www.expertappliance.com/dryerbeltconfiguration.html
Aug 16, 2011 | Kenmore Dryers
Dryer overheats and makes a roaring sound
You have two problems.
1...Overheat problem
2...Drum rollers noisy
I will include both fixes.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistors due to overheat.
A vent clogged with lint can cause it to overheat.
2...ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the lint filter, and the two screws that hold the lint filter housing in place to the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 23, 2011 | Maytag Dryers
THUMPING NOISE AS DRYER TURNS. I believe one of the rollers is loose, broke or??? Best way to access them. I can't get the bottom side cover screws loose. Can they be accessed from the top?
pulley and motor.
Please rate me
Jan 14, 2011 | Dryers
One of the belts have gone and need to know how to relace it
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Be real careful not to knock any of the wires off of the timer switch.
Remove the lint filter, and the two screws that hold the lint filter housing to
the top of the lid.
Then remove the top of the dryer.Most lids clip on to the base of the machine,
some slide off.
Remove the front of the machine, this will expose the belt and drum, remove
the drum and belt and this will expose the drum rollers, idler arm bracket
with pulley, and motor with pulley.
Pay attention to the route of the belt,this will come in handy when you go
to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum
not to turn.
While you have the drum out, I would recommend that you lubricate the drum
rollers at the shaft of the roller with a good grade of machine oil like 3
in One oil. This will save you a problem later with the rollers getting
noisy, also check your drum rollers for flat spots, if they have flat spots
on them this will cause a noise like a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Free answer...Please rate me
Dec 22, 2010 | Dryers
How do u install the new belt?
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
Remove the lint filter, and the two screws that hold the lint filter housing to the top of the dryer.
Most lids clip on to the base of the dryer, and some slide off.
not to turn.
Dec 10, 2010 | Whirlpool LER3624JQ Electric Dryer
Belt is snapped, how do i replace?
Remove the lint filter, and the two screws that hold the lint filter housing to the top of the lid.
Most lids clip on to the base of the machine, some slide off.
not to turn.
Dec 10, 2010 | General Electric DWXR463EGWW Dryer
Need to replace belt
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer, also remove the lint filter and the two screws that hold the lint filter housing in place.
Then remove the top of the dryer, normally this is clipped to the frame.
Remove the front of the machine by removing the screws at the top of the machine housing, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
not to turn.
Dec 06, 2010 | Whirlpool Dryers
Turns on but the drum if has more than two socks in doesnt turn
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer, also remove the two screws holding down the lint filter housing and remove the lint filter.
Then remove the top of the dryer, most of them will unclip.
Please rate me
Dec 06, 2010 | Maytag PYE2300AY Electric Dryer
Loud squeeking belt
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley or noisy drum rollers.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out you can check the condition of the drum rollers.
I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil.
This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Aug 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
219 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
