Question about Motorola Mobility i1 Smartphone
My phone is not charging. i have replaced the battery with a brand new one. What can I do? The only response I get is the LED blue light on steadily when I plug in my charger...HELP!!!
  • 3,083 Answers
Battery contacts inside the phone can get slightly oxidized. When this happens, you have to clean them with a qtip and alcohol, or a pencil eraser. There is little else you can try to fix this kind of a problem, so hope that fixes it for you. If this doesn't work, run the phone by your provider too see what can be done.
Good luck, and hope this helps.
Posted on May 27, 2011
4206p blue led light not functioning
As per my earlier response , check your charging system and battery on your vehicle. You need to determine if something is depleting the battery of your vehicle or if the charging system is ok. Alternator belt and battery are first ..
Feb 19, 2014 | Python 4206p Responder Le Remote Start...
Charging battery
Sometimes if charged too long or your not around when the light does go off, after awhile the battery looses its charge. when that happens the charger will start to charge again and it will seem that it isn't working right or charging. in your instruction booklet it should tell you how long it should take to charge. some say 45 min some say hours. set a timer once you find the time recommended for your device, once it goes off unplug if light is off. good luck
Dec 07, 2013 | Case Logic IKBT-50 Bluetooth Keyboard...
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
My case logic mouse does not show up in the "find devices" area. batteries are brand new. I just want it to work.
I tried searching case logic's site for support for this mouse...but to no avail. Apparently this was a hit and run product they never looked back on. Anyways, I found a few answers from other users on the net. Here's one such solution I could glean. Hope it helps:
1) Locate the 'reset' button on the bottom of the mouse. (Tiny little black button on ours...)
2) Plug in the USB receiver. The blue LED button should light steadily.
3) Turn on the mouse. Hold it near the USB receiver.
4) Push the blue LED button on the receiver, and as it begins flashing slowly, push the reset button on the bottom of the mouse. This should synchronize the mouse and the USB receiver within moments.
5) If the blue LED button on the USB receiver begins flashing very rapidly, the mouse and the USB receiver are communicating, and the mouse should begin to work.
If it does not, the battery in the mouse may need to be removed and replaced, then the whole process started again...
If it works, you'll probably have to go into Mouse Properties in your Device Manager and adjust the response of the mouse, because the default settings are often positively crazy sensitive!
Mar 11, 2011 | Case Logic Computers & Internet
I'm charging the headset and the led is blinking red, but when i disconnect the usb, i still can't turn it on
When the headset's battery is fully charged (about 3 hours), the indicator light is steadily lit in blue
Aug 18, 2010 | Motorola Mobility H270 Bluetooth Headset
How do i set my my motorola h350 into discoverable mode
Plug the Motorola charger into the end of
the headset.
The blue indicator light turns on when the
battery is charging. It may take up to 1
minute for the light to turn on. When the
headset's battery is fully charged (about 2
hours), the blue indicator light turns off.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
Oct 05, 2009 | Motorola Mobility H300 Wireless Headset
HP altec lansing Pavillon DV 6700 not powering
I am sorry to say that this is likely to be motherboard damage. The only other possibility is the the Power jack on the laptop itself is loose or shorted.
Either way.. You need a qualified repair.
The safe bet is a new motherboard.
sincerely,
Sagacious1
Aug 07, 2009 | Computers & Internet
Not charging
Check the life of the battery - even if it is brand new they have a shelf life. If you do not know - call interstate battery and they can tell you
May 24, 2009 | HP Compaq Evo n610c Notebook
JAzz DV179
Well.. I have to plug in the charger that came with the dv-179. If I use my Phone (motorola usb) charger, or a USB cable (into the computer or a hub), all it does is light up the back red light (and not the front 'self timer' led) and does not charge the camera. So remember, if the back led lights up, you've got the wrong charger!
Jan 25, 2008 | Jazz DV-179 Digital Camera
Motorola Mobility i1 Smartphone Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
