When i enter the xp cd then restart my computer which key to press to boot from the xp cd. i want know how to formate c with xp cd on mercury mother board step by step. please tell me
  • 565 Answers
The first thing you have to do is go into the BIOS setup. When booting the computer, it will usually show which key to press to enter the BIOS. Usually it's "DEL" or F2, maybe F12. Just hit all the F keys until it goes into BIOS if you have to. Once in BIOS to have to navigate to the boot order and set it so that it will boot to CD. Press F10 to save and exit.
With the XP cd in the drive and boot the computer. Wait until it says "press any key to run CD" or similar phrase. Then hit any key. The computer will then load some files. When the screen asks what you want to do, tell it to go into "recovery console". Once in recovery console, type in the following: format c: /fs:ntfs There is a space after the colon that follows c.
That will format the drive with the NTFS file system. If you just want to reinstall XP, all you have to do when the screen popsup that asks you what you want to do is tell it you want to install XP and follow it out. Here is a website for how to insatll XP: http://www.getpcmemory.com/microsoft/how-to-install-windows-xp-step-by-step-guide-to-clean-installation-of-xp/
Or here: http://www.codeproject.com/KB/work/installwindowsxp.aspx
Posted on May 27, 2011
    Problem Solver:
  • 12 Answers
Insert the Windows installation disk into your CD drive. Shut down your PC. Then, boot from CD. This part is important: do NOT run the Windows installation from Windows itself. Shut down first, and then boot up the machine from CD. My Dell has a little message as it's booting up that says "Press F12 to boot from CD," so that's what I did. If you're not sure how to boot from CD, check your PC's user guide for more info.
The reason why booting from CD is important is because we're going to delete the C: drive partition where Windows is installed and re-format it. You can't do this if Windows booted from C:, because it can't delete the partition from which it is running.
You CAN install Windows without deleting the partition and formatting, but that means all your program files and other riff-raff that's collected on your C: drive will still be there when you're done, just taking up unnecessary space. That's not the point of all this. Be sure to boot from CD.
Step 1. Step through the Windows installation. You'll be greeted by WordPerfect 5.1-like blue screens with white text on them, which seem scary, but aren't. All the directions are clearly spelled out on each of them. Still, we'll go over what to do.
At the Welcome to Setup page, press Enter. Press F8 to accept the Windows XP Licensing Agreement. You'll be asked if you want to repair your existing Windows XP installation. Press ESC to bypass the repair and install a fresh copy. All your existing disk partitions will be listed, like this.
You want to delete the current partition where Windows is installed. Use the arrow key to select it, and press D to delete it. Press L to confirm. Then, to create a new partition, select the unpartitioned space and press C. To create a new partition with the maximum amount of space allotted to it, press Enter.
Now select the brand spanking new partition you've just created to install Windows on. Format the drive as NTFS (Quick if you want, but I went thorough just to be sure.) Depending on the size of the drive and how fast your computer is, this will take some time. Get a sandwich. Then, follow Windows Setup's steps, set your area code and name and password and let it reboot as many times as necessary until it asks you to log in for the first time. Congratulations! Welcome to your fresh new Windows installation.
But we're not done yet.
Step 2. Install any missing drivers. Once you get Windows XP up and running, chances are everything on your computer won't be working perfectly. Are you connected to the internet? Can you play music? Is your screen resolution unusually large? The answer is probably no to all those questions, except the last one. Do not panic. This is the part where you install the right drivers for your hardware. First, get a list of what Windows doesn't have installed correctly. From Control Panel, go to System, then Hardware, and click on the Device Manager. Chances are it'll look something like mine did after my fresh installation:
Those yellow question marks/exclamation points are Windows' way of saying "I know this hardware is here, but I don't know what it is or how to control it." Insert each driver CD you've got stacked up beside you and install the software needed for all your computer's components. If you don't have a driver disk, get on that other machine you've got next to you, and Google up the brand and model of each of the components for which you need a driver, download, burn to disk and install on your fresh Windows machine. Those two handy hardware audits you printed out in Step 2 will be your friend, but without the discs that came with your machine, it will be a bit of a guessing game, matching up the yellow question marks with the items on your reports. Take educated guesses. Good luck.
As for me, I had to manually install drivers for my video card, sound card, printer, TV tuner card and Bluetooth adaptor. Your mileage may vary.
Step 3. Update Windows. If you used the Windows installation CD that shipped with your computer three years ago, you've got an old version of Windows that came out 7 service packs ago. As soon as you're online (got that ethernet card/wifi card driver installed?) go directly to Windows Update and patch up Windows nice and tight and secure. Do not wait to do this as there are probably lots of computer baddies just beyond your network card waiting to ravage your virginal machine the minute it's out there alone in the wild internet. Yes, that sounded dirty on purpose.
Step 4. Install all needed software applications and tweak Windows to taste. That's it folks, you're in the home stretch. Go ahead and have a big old software installation party with all the apps that run your life. When you're done, copy over your backed up data to C: (if necessary.) Then, sit back and give yourself a well-deserved pat on the back. You deserve it.
After I upgraded my PC and reinstalled Windows, the amount of used space on my C: drive was about half the size it was before I started, as was the size of my Windows registry. But most importantly, a few really annoying inexplicable problems I had disappeared - like no native Windows wifi network detection, a constant missing DLL popup when I launched one program in particular, the refusal of one piece of software to install at all. Plus, things felt snappier and happier in general.
How to format for windows xp
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key but will differ depending on your computer and Bios.
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system.
Note: After you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
If you are putting windows XP on your computer your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd\dvd.
Aug 15, 2013 | Computers & Internet
MY PROBLEM IS THAT I DONT HAVE A MOTHER FORMATE DRIVES
if you are referring to a format on your hard drive
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope this helps you
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps you
Mar 29, 2012 | IBM Computers & Internet
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
How to format drive c in dos? i am using xp pro...can you give me the steps? PLS HELP I AM NOT FAMILIAR IN COMPUTER BUT I WANT TO DO IT IN MYSELF
Just boot from a Windows install disk (put the cd in, press the boot selection key and select the cd unit) and allow it to run: the first step in the process is selecting the drive (select C), the second one is formatting of the drive - select the regular one, not the quick. After that just pull out the Windows disk or let it continue.
Mar 11, 2011 | Computers & Internet
The computer will not boot up.
It may caused by the curreption(deletion) of important system files,
You can format and reinstall xp,vista,win 7,linux,mac os .
Restart computer when booting goes on press F5 Or DEL key to goto bios setup menu change boot order to first cd drive then hdd
PressF10 and press Y and enter.
computer will restart
Insert xp,vista,win 7,linux,mac os cd.
Press enter to boot from cd
Follow the instructions
Then your problem will solve.
Jul 28, 2010 | E-Machines eMachines Desktop PC
How to install xp in dell vastro 1015
You can format and reinstall xp .
Insert Xp cd.
Thanks
Jul 28, 2010 | Dell Vostro 1015 Laptop
Windows does not start automaticly it gives options like safe modeboot with the last knows config and start windows automaticly. When I click on any option the machine goes off and when I try to repair...
Insert Xp cd.
Jul 18, 2010 | Computers & Internet
My windows Xp just lost because of power failure.. how i reinstall the windows xp for my laptop of NEC Versa pro NX
have you tried this ......
restart the laptop press F8 it will open to boot the laptop through various process like safe mode , last good known ..... select the last good known option and press enter .... it will boot the laptop with last setting
if this one not working then go for reinstall of xp ...for reinstall xp
  1. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  2. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  3. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  4. Read the Microsoft Software License Terms, and then press F8.
  5. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  6. Follow the instructions on the screen to complete the Windows XP Setup.
Nov 25, 2009 | Office Equipment & Supplies
How to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
Formtting my hard drive
if you are formatting your computer for the first time and if you bought your computer after 2005 then just press <Ctrl> + <F11> keys right at the dell logo on startup, you will boot to dell PC restore. This will restore your computer back to the factory settings including WinXP, all the drivers and softwares.
If you bought your computer before oct 2005: then follow these steps.
1) start you computer and at the dell splash logo tap <Del> key to enter setup. (restart and retry till you see entering setup)
2) select Boot from the tabs above using arrow keys.
3) select boot device priority press <ENTER>.
4) select ATAPI CDROM, <ENTER>.
5). insert WIN XP CD in the top drive of the computer and press <F10> select yes.(this will restart your computer).
6) after reboot you will see " press any key to boot from CD" press any key within 5 sec on this message.
7) Press <ENTER> to install
8) Press <F8> on next screen
9) Press <ESC> on next screen(Options may vary on this screen , read instructions).
10) select partition using arrow keys press <ENTER>
11) select NTFS/NTFS quick, anyone. and press F on the next screen...
this wil start WIn XP set up and concludes the formatting of the HDD with Win XP CD.
Apr 28, 2008 | Dell Dimension 4500 PC Desktop
Computers & Internet Logo
275 people viewed this question
David Payne
David Payne
