Question about Neff U1661 Double circotherm super Electric Oven
Child lock code -5- has appeared.
The child lock code has appeared on the lower oven. We have followed the instruction under "troubleshooting" by turning the dial 3 times but this has not solved the problem. We have also swithced the electric supply off at source and switched on again but still no solution!
  • albr10 Aug 30, 2008
    After 2 weeks powered down (holiday), upon re-power, the -5- sign came up and despite following the troubleshoot guide (0 - light x 3) I cannot get rid of the -5- or get the oven to work.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Posted on Mar 17, 2009
  • lennon_linda Mar 03, 2011
    thanks so much for this. have spent an hour and a half trying to sort this out. carried out what you suggested and it worked straight away. you are a star.
Just got rid of permanant issue with -5- by holding down the 2 Arrowed buttons (beneath the clock) whilst turning the selector knob from fan assist (1st symbol) to oven (2nd symbol) and back, a few times (didn't count how many).
Prior to this I had de-powered then powered back up with selector at fan symbol (not sure if this had any effect on the outcome?)
Posted on Aug 30, 2008
  • 725 Answers
Turn the first dial from o to light 3 time... hope you get it
Posted on Aug 17, 2008
If the oven is a B1691 the child lock has been activated and it is reset by pressing the central rotary button right in and holding it there for 8 seconds. This was accidentally activated by my wife and we lost use if it for two weeks looking for a solution, perhaps Neff could add a wife lock as well :)
Posted on Mar 22, 2014
U1863 neff oven child lock does not turn off
you have to switch quickly 3 times beetween off and light on position.
Dec 11, 2015 | Neff Ovens
Why is it showing a key symbol, an error code f10 and the door is locked?
usually a key symbol means that the appliance is safety locked. usually by holding down a button for 3-5 seconds to lock and holding down the same button to unlock. a child lock safety feature.
Jul 20, 2015 | Gaggenau EB 270/271 Electric Single Oven
I get a red lock and cant use my oven.
Depends on your brand, but look in your owners manual and follow the instructions on getting it out of "Child Lock".
Mar 17, 2015 | Ovens
How do I remove the child lock message on my Panasonic Inverter Microwave?
Press {Stop/reset} button 3 times to unlock the unit. Or un-plug it for a little while. To put the unit into child lock press the start button 3 times.
Aug 20, 2011 | Ovens
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic
mode and verify the error codes. Ensure AM software, UI software and EEPROM
CHECKSUM versions appear on the lower text line. If AM software and EEPROM
versions do not appear, UI and AM may not be communicating. Verify this for the
lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show
the AM software version for the lower oven appliance manager, and the microwave
UI will show the AM software and EEPROM versions for the microwave appliance
manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT
DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions,
go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND
EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER
OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
I have double oven my lower oven is not working appears a code in the screen that is not allowing to work the lower oven i restart unit in the code disappears but letter around cameback the code to the...
The exact same thing just happened with my lower oven and the code 4d22 appears in the upper right part of the display panel by the the timer. There is no explanation for the code in the instruction manual. Hope someone can help us with this. Upper oven works fine.
Dec 20, 2010 | Jenn-Air JJW8230D Electric Double Oven
My neff oven error -5-. How do i turn this off?
I also had an error 5 on my Neff B1691 cooker. This indicates that a child lock has been set. To unlock you just push and hold the central control button in for about 7-8 seconds. Do the same again to set the lock again...
Mar 21, 2010 | Neff B1421 Electric Single Oven
I can't unlock touchscreen panel
This is an safety features that prevents unwanted oven operation by children.
To set child lock...
Touch and hold STOP/CLEAR or 0,START until LOCKED appears in the display and two beeps are heard. If the time of day was already set, the time of day will return to the display windows. After you touch another.
If the CHILD LOCK was already set and you touched another cooking pad, the word LOCKED shows in the display.
Then you can cancel the CHILD LOCK according the below procedure...
Touch and hold STOP/CLEAR or 0,START pad until LOCKED disappears in the display.
Aftes the CHILD LOCK is turned off, the time of day will return to the display window. The oven will operate normally.
Hope helped with this. Good luck.
Nov 04, 2009 | GE Ovens
How to start oven in PROPANE STOVE
Print the following infore for future ref if you wish. How it works is simple tage a look at it in Motion
Component Test Procedure Results
Electronic
range control
F1−1 –Upper Oven >650°F with door unlocked.............................
F1−2 –Lower Oven >650°F with door unlocked.............................
F1−3 –Upper Oven >950°F with door locked.................................
F1−4 –Lower Oven >950°F with door locked.................................
F1−7 –Membrane switch is not responding ...................................
F3−1 –Upper sensor is shorted at (< 100 ω) or
open at (>5 K ω) ...............................................................
F3−2 –Lower sensor is shorted at (< 100 ω) or
Check actual upper oven temperature,
if > 650°F check sensor.
Check actual lower oven temperature,
if > 950°F check sensor.
Check membrane switch for connection or damage.
Check upper sensor, harness, and connections
Engineering
Test Mode
Press BAKE pad.
Enter 100°F using the number pads.
Immediately push and hold BAKE pad for appropriate oven
approximately 3 seconds.
This mode can also be entered by pressing the hidden pad
for 3 second located to the left of the lower oven light pad.
Used to view the actual oven temperature for both ovens at all
times, even when an oven function is active.
This mode will also display the current fault code for 5
seconds in the time digits.
Fault codes
accessed
through
Engineering
Test Mode
F0−0 –No fault .................................................................
F1−5 –Upper hardware failure within control ....................
F1−6 –Lower hardware failure within control.....................
F1−8 –Shorted key in membrane switch ..........................
F1−9 –Internal communication errors within control .........
F1−A –Upper latch switches ............................................
F1−B –Lower latch switches.............................................
F1−C –Upper door switch.................................................
F1−D –Lower door switch.................................................
F1−E –Sensor input not calibrated ...................................
F1−H –EEPROM error .....................................................
F1−L –Temp in ovens are the same for long period .........
F1−N –Internal voltage on control not working .................
F9−1 –Upper lock switch is not correct.............................
F9−2 –Upper unlock switch is not correct.........................
F9−3 –Control does not see upper door lock....................
F9−4 –Lower lock switch is not correct.............................
F9−5 –Lower unlock switch is not correct.........................
F9−6 – Control does not see lower door lock ...................
EE –Control cannot read E-PROM. Unit will shut down.
Default from factory
Replace control
Replace control
Check membrane connection
Replace control
Check latch wire harness
Check lock wire harness
Verify sensor is operating properly
Replace control
Replace control
Check lock wire harness, and lock switch
Disconnect power for 60 seconds. If EE reappears, replace ERC
Test Mode This mode must be activated within the first 5 minutes of
power up.
Press BROIL and CANCEL pad for approximately 3 seconds.
If oven temperature is greater than 400°F, the Test Mode
cannot be activated or will abort if active.
Press and hold individual pads for 4 seconds to activate.
Display will have dashes in all segments to indicate the mode is
active.
Upper Bake: Energizes upper bake element
Lower Bake: Energizes lower bake element
Upper Broil: Energizes upper broil element
Convection Bake: Energizes convection fan
Upper Oven Light: Energizes upper oven light
Lower Oven Light: Energizes lower oven light
Upper Clean: Energizes upper motorized door lock
Lower Clean: Energizes lower motorized door lock
Stop Time: Energizes Beeper
Cook Time: Displays error codes
Timer 1: Energizes ROM version
Timer 2: Energizes EEPROM version
Keep Warm: Cooling Fan
Clock: All display segments light
If functions do not perform as specified, replace ERC
Oven
temperature
adjustment
Push BAKE pad.
Enter 550°F using the number pads.
To decrease or increase oven temperature. Push AUTO SET
pad until negative or positive numbers appear. Oven can be
adjusted from -35° to +35° (-37.2° to + 1.6° C) in 5° F (2.7° C).
To avoid over adjusting oven move temperature -5° each time.
Push OVEN CANCEL button.
Sep 04, 2009 | Frigidaire 30 in. Electric Gallery Series...
Neff oven B1641 child lock
I actually had the same problem and got the solution. Maybe its a bit late, but hopefully there will be somebody who find this useful as well.
Its not an error. The -5- indicates that the oven is "children protected".
- Put the left ON/OFF switch into its OFF position (the left switch)
- Turn it quickly 3 times: one click to the left and then one click back to right again [light position, Off position]
=> The message disappers.
If you do this again, the protection is switched on again.
Greetings from Germany
Jun 25, 2008 | Neff B1641 Single circotherm super...
Neff U1661 Double circotherm super Electric Oven Logo
610 people viewed this question
Top Neff Ovens Experts
bosch5
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
