Question about Hoover Vacuums
I have a Hoover Windtunnel self-propelled U6449-900. The brushroll stopped turning, so I replaced both belts and the brushroll...no change. Left the roller cover off and turned on the vac. The wheels from the motor are turning but the belt to the roller doesn't tighten up when the handle is released from the upright position. The brushroll usually engaged when you do this. Any ideas? Would this be a costly repair or is it an easy DIY repair. Thanks.
reddevil6
  • 1673 Answers
SOURCE: hoover upright windtunnel isnt propelling itself anymore
If the V belt is loose with the handle down, then maybe the idler wheel under neath the belt isn't contacting the belt, may be jammed down, just push on it to see if it moves up and down. Belts don't last very long, you may want to replace both of them.
Posted on Feb 14, 2008
Agent Don
  • 310 Answers
SOURCE: installing belt on hoover self propelled upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40544&thid=641399
Installing belt on Hoover self propelled upright...
Posted by Fryeburger on Jun 02, 2008
Need help installing belt on Hoover self propelled upright vacuum
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Ultra U6430-900 Wind Tunnel Bagged Upright. The best way to install the belt on a Hoover to replace one or both of the belts @ the same time for the best cleaning. The average belt change is every 4 to 6 months for best results. There is a tool that looks like a screwdriver that has a right or left angle on the end that serves as a belt puller and to hook the belt(s) onto the brushroll 1st and then take your puller and then pull or stretch the belt onto the motor pulley. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 02, 2008
SOURCE: brush roller on windtunnel won't spin
It sounds like you need to replace the actuator arm or the cable to it. Look for Hoover part 43143046 for a start. I've got a similar problem.
Posted on Jun 04, 2009
  • 389 Answers
SOURCE: My hoover windtunnel is not picking anything up all of a sudden.
The belt that drives the brush roll has broken. That's why it doesn't pick up and why it doesn't pull itself forwards. Check the User Manual (download from Hoover website if necessary) for information on replacing the belt. Good luck!
Posted on Feb 05, 2010
VacuumRepair
  • 438 Answers
SOURCE: hoover self propelled bagged windtunnel upright
Greetings from GoVacuum,
Here's a great video repair tutorial that we've put together to try and help you with the repair on your Hoover WindTunnel. I hope that this helps you with your repair. If you found this solution helpful, please rate this repair video by clicking on the 4 Thumbs Up Icons in the top right hand corner of my repair solution. Feel free to email me at chris.jones@govacuum.com if you have any questions about the repair!
Video Repair of Hoover Windtunnel Belt Change;
Thank you very much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
Beater brush will not turn even with belt intact
is there any loose pieces of carpet or twine wrapped around central bar.
Dec 28, 2015 | Hoover Self-Propelled WindTunnel Bagless...
The brushroll stops turning.
Hoover Windtunnel Self-Propelled Vacuum Belt ... - YouTube
? 2:54
www.youtube.com/watch?v=AJL9McF7MAU
May 22, 2012 - Uploaded by Crucial Vacuum Fits: Hoover U6423-900, U6425-900, U6425-920, U6429-900, U6430-900, ... U6616-900, U6617-900, U6625-900, U6626-900,U6630-900, ...
Aug 06, 2015 | Hoover U6630-900 WindTunnel Bagless...
How to stop the main belt from comming off the motor shaft on a hoover modle u6634-900/windtunnel
Hello there! If you have replaced the belt and it is still slipping off, you may be not have the right belt for your vacuum. This unit takes a flat belt and a v-belt. Make sure you are replacing the belts with Genuine Hoover Parts. I have included the links below where you may go to order the belts specific to your cleaner.
WindTunnel PowerDrive Belt 2 Pack
WindTunnel Self Propelled Belt
Hope this helps!
Jun 21, 2014 | Hoover Self-Propelled WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Had a problem with the brushroll now its burning up the flat belt
When you put the flat belt on, is the print on the outside of the belt? Is the brush correctly positioned?
Dec 21, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover self-propelled
No suction on Windtunnel 6630-900. All belts work, brush turns, it just won't pick up anything.
Sep 07, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Installing belt on hoover self propelled upright vacuum
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 02, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
I have a Hoover self propelled WindTunnel vacuum( Model U6425-920) that stops in the middle of cleaning. I have changed the flat belt and I'm still experiencing the problem. I usually have to wait an...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632298
Generic problem for all Vacuums
Posted by thjunk2007 on May 29, 2008
I have a Hoover self propelled Windtunnel vacuum( Model U6425-920) that stops in the middle of cleaning. I have changed the flat belt and I'm still experiencing the problem. I usually have to wait an hour or so b/4 it would work again. Any advice?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you my have a heat sensor, but as far as what you described you need to change both belts, the brushroll belt and the power drive belt as well and @ the same time. The average belt change is every 4 to 6 months on the vacuum. Does it stop completely or is it just the belt problem. Or #2 is the vacuum giving off a burning smell other than the belts and if it does it could be the motor. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Vacuums Logo
51 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
