Question about Apple iPod nano
Ipod nano touble
I took my IPOD on a business trip and now it never works...when plugged in instead of saying "do not disconnect" so that the battery will charge the apple logo is blinking. If I hit the middle button it will flash very quickly and read "please wait, very low battery". Now I have left this thing plugged in for a long time and it still does not work. When plugged in it won't even show up on Itunes. One day it worked and then the next day...dead. I don't undertand-is it done for or should I talke it into the Apple store?
  • Anonymous Dec 26, 2008
    when i want to put music on my ipod from itunes it won't work. it will only charge the battery. even whenmy battery is totally full it won't work. i want to try this solution, but my ipod is frozen up right now.
  • 2,071 Answers
Did you try charging it with the USB cord or do you have an adapter that plugs into the wall? If you tried with the USB cord, how long did you let it charge?Did you plug cord directly into computer or do you have external USB hub?Many times the hubs will not have sufficient power to charge.Was your computer"go to sleep"after a while.The ipod will only charge while the computer is awake.
There are a variety of things that could be wrong. If the Ipod sat for a long time the battery could be completely discharged. I've not had this problem on the Nano, but on an old Ipod Mini my sister has. I've noticed that sometimes I need to plug it in with a wall adapter to get the battery charged enough to start up quickly. If the battery is completely discharged,it can take 30 minutes or longer to see any life from the ipod. I would let it charge for few hours if you can then try the reset.
Forgive me for asking this next question...lots of times I ask these basic question and people get mad, but the key lock is off, right? On my Nano there's a small slider switch on the top. In one position the controls are all locked. Please verify that you've got it set to the right position. Mine is locked when I can see the red dot.
Assuming the battery is not totally shot and the key lock is off, it's also possible that it's just "locked up". To reset the Nano press and hold both Menu and Select (center button) for about 5 or 10 seconds. If the Ipod is alive this will reset it.
From your post, I'm not sure if you mean the Ipod was sitting for a long time without being used. If that's the case and it used to work, and it has not gotten wet or anything, then the most likely problem is a bad battery. There are services on the web you can find who will replace the battery for a fee. If, on the other hand, it just suddenly stopped working and the reset does not help you may have a more serious problem.If problem exists you better replaced the battery. Unfortunately there's no way to tell.
Hope this may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
Feb 22, 2011 | Apple iPod nano
My nano 4th G will only come on when i plug it in to my comp
Your battery is most likely dead. Very dead. Google "iPod repairs" in your country and they might be able to replace it. Otherwise you can get an exchange unit from Apple. Take it to your nearest Authorised Apple Service Centre and they will get it exchanged in a couple of days. Unfortunately this might cost almost as much as a new one.
Oct 06, 2009 | Apple iPod nano
When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
You need a new battery for your iPod. you can view a free instructional video on battery replacement at the first web address posted below. the second one is a cheap site I found for purchasing iPod parts.
http://fixyouripod.weebly.com/
http://www.ifixit.com/
Mar 13, 2009 | Apple iPod nano
My ipod nano 3rd keeps saying synchronizing 'Do not disconnect'. It's been saying that for an hour now and it's not even plugged into my computer. It's just frozen on that and I can't do anything. I just...
i want to change the list of songs i have in my ipod nano but how come the old once doesn't appear anymore but can't store new ones.. Keep on saying "not enough memory... need your help... thanks..
Oct 20, 2008 | Apple iPod nano
Cannot eject
The battery shouldn't take that long. Can you see if you have the newest firmware for your iPod? Sometimes when Apple releases a newer version of iTunes a firmware has to be applied to work with older iPods.
Click on the iPod icon in ITunes and check the settings tab in the larger window pan. Click the button Check for update.
You could always shutdown your computer and then disconnect the iPod. If the screen still says do not disconnect when the computer is off, hold down the play center buttons, untill it restarts.
Jul 23, 2008 | Apple iPod nano 3rd Generation
Problem with my 8gb ipod nano blk
Could be a problem with the motherboard and the connector interface (where you plug in the USB into the iPod). Do you have access to an ac charger you could try? That would eliminate the USB interface issue and point more to a motherboard issue.
If that does not work, then please consider the FREE Diagnostic Testing that we offer through our website. It will cost you virtually nothing to have us diagnose your issue. Our company is staffed with formed Apple Techs and we are an Accredited Business with the Southern Colorado Better Business Bureau (BBB).
Regards,
Rick
EverGreen Electronics
'Eco-Friendly iPod Service, Sales & Recycling'
E-Mail: sales@evergreenelectronics.com
Website: http://www.EverGreenElectronics.com
FREE Apple iPod Technical Support - http://www.iRepairGuide.com
Jun 15, 2008 | Apple iPod nano 3rd Generation
Ipod wont show up on itunes
Try the five r's:
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
Jun 14, 2008 | Apple iPod MA446LL/A MP3 Player
IPod Classic
I plugged my iPod in again and restarted my computer. After I restarted it took a few minutes but it finally registered my iPod.
Apr 23, 2008 | Apple iPod nano
Ipod Problem (Ipod Nano) moel NO A1199
i fix this problem just the ipod need to reboot
hold ok key and then hold menu key it will be restarted and the it will be connected to your PC
Thanks
Dec 02, 2007 | Apple iPod Photo MP3 Player
Apple iPod nano Logo
52 people viewed this question
Top Apple Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
mac colar
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
