Question about Jenn-Air Kitchen Ranges
I have a D120 jenn-air range, I need the wiring diagram for the element control switches
4 Suggested Answers
SOURCE: F1-1 error on Jenn-Air Range
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Posted on Aug 02, 2007
aborcass
  • 2651 Answers
SOURCE: How to remove stove top to replace element on JES8850BAS
i would imagine you would not have to remove te front control paenl eitherfew screw around sidesand back
heres a complete service manual for the model number, loos asif its adowndraft cartridge model not a glasstop , removing main top pg 26
http://www.servicematters.com/maytag_library/docs/16026926.pdf
Posted on Nov 24, 2008
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
We purchased an older house that has a Jenn Air D120 Electric Range but no manual to tell me how to use it. Does anyone have one they could scan and send me?
Hello Barbara,
Simple search online will get you to jennair.com
or
You can search within
Guides & Manuals, or call a Customer Care Specialist at 1-800-JENN-AIR (536-6247).
or
kitchen.manualsonline.com
Good luck and all the best in your new home.
Nov 14, 2015 | Jenn Air Kitchen Ranges
Need an owners manual for model d120
I would suggest going to http://www.jennair.com/flash.cmd?/ and looking under their Customer Care menu option.
I could not find a range with model number d120 in their lists. Under Customer Care select Find Model Number and then select Ranges from the list. The site will then show a number of pictures of different models and where the model number is located on those ranges.
Once you have that go back to the home page and under Customer Care select Find Guides And Manuals. Select the Consumer option in the first form field and input the model number into the second form field.
Jul 03, 2012 | Jenn-Air Kitchen Ranges
Need a wiring diagram for a jenn-Air range. Oven element burned out and replacing it didn't fix the problem. Don't want to spend $150 for a thermostat if ther is something else in the circuit that could be...
Hi. It could be your thermostat not sending power to bake element. If elements are really burning out that fast, check the voltage coming to stove. If more than 220 volts, could be a problem with the power coming into your home. Check also the element if it has continuity.
Oct 21, 2010 | Ovens
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Nov 23, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Oven element
bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Feb 07, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Sve47100 oven doesn't heat
Some times a company changes vendors for the controls and connections change location. But does the wiring diagram indicate a relay board in the back of range. It could be damaged form the element short
Jan 03, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air manual
You can find everything you need and diagrams at http://www3.sears.com/.  Just type in the model #.  There is no repair manual that I know of.  If you need help solving a problem once you have seen the wiring diagram let me know.
Oct 12, 2007 | Kitchen Ranges
Can't control temp of one element, is either high of off, nothing inbetween
- The infinite switch for the controller likely needs to be replaced, this part can be ordered from your nearest Jenn-air parts dealer
Mar 13, 2007 | Jenn-Air JED8230 Electric Cooktop
Kitchen Ranges Logo
151 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
