Question about HP Officejet 4355 All-In-One InkJet Printer
I can't connect to my printer it's always offline
  • 336 Answers
Try to power off your printer then power on again also your computer try to restart. then check up ink cartridge maybe empty ink.if problem same.need service center http://www.hp.com
Posted on May 27, 2011
On SKYPE - It ALWAYS says my friends are offline when they're ONLINE - THEY also say my thing their end ALWAYS reads offline....We can't connect AT ALL.
try the status setting on your end and see what it says should be on upper left pull down menu should say online but might be one of the others as well
if that does not solve it uninstall skype
download newer version
re install
log in and give it a whirl
May 20, 2012 | Acer Aspire 5552 15.6 inch Laptop AMD...
Hi, My Star TSP100 printer always goes offline after computer shutdown
Hi Valued Star Customer
It seems like the USB host may be going into "sleep mode" and not awakening. Please contact Star Support at support@star-emea.com for documentation.
Best regards
Star Technical Support
Feb 13, 2012 | Star Micronics TSP100 Thermal Printer
Printer is offline
  • Check the printers connections.Well connected?
  • Turn it off and disconnect everything and then re-connect again.
  • Access the cartridge compartment and inspect whether the cartridges are well installed.
  • Set the printer as default printer if not set.
  • Check through the paper feed tray for any stuck papers which may cause paper jams,resulting in offline mode.Still offline?
  • Open printers and faxes to view installed printer.
  • Right click on the printer icon and uncheck 'use printer offline' Still offline?
  • Try updating your printers firmware.
Hope this helps.Thanks for using fixya!
Sep 25, 2011 | Dell V313w AllInOne InkJet Printer
My hp 900 inkjet is offline and doesn't want to feed paper.
The solution for an offline error of a printer is to check the proper connection of the printer.
Two options exist to turn off the offline mode.
If you choose the first option to change the offline state of the printer,
then go to Control Panel and then 'Printer and Faxes' option on the Control Panel.
Double-click on the printer you want to change to online mode from the displayed window.
A pop-up window will open and you need to select 'Uncheck Printer Offline' option from the menu bar.
try this:
http://printers.iyogi.com/hp/hp-printer-offline-error.html
Hope this helps you.
Jun 23, 2011 | HP PSC 1610 All-In-One InkJet Printer
The printer is offline and not connecting to the network. I have tried everything.
Does it show any error message, or it just stays there like that?
Here's where to start. On your printer/fax press "Menu." Then press 5, and click "OK." Then press 2, and click "OK." It should say "Searching SSID." Make sure you are connected to your own wifi network and that your network key is inserted right.
Then, go into your wifi router's settings and make sure the DHCP server is set and that the printer can get an apropriate IP address to connect to the network.
Are you trying to connect it directly to your computer's wifi card? or are you using the router's access point. There might be issues with that too.
Have you tried connecting it to the USB cable? Even if it can't connect to the wifi network, it should always be able to connect to the wired USB interface.
Try to troubleshoot it a little. and maybe add some additional details so that we can assist you better.
May 22, 2011 | Brother MFC255CW All-in-One InkJet Printer
Printer Offline Message
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Get more information to fix printer offline error :
http://printers.iyogi.com/errors/printer-offline-message.html
Hope this information helps you.
Jan 07, 2010 | Epson Aculaser C1100 Printer
Offline wireless printer
Please make sure that printer is turn on, before doing ensure you do power cycle of printer.
Add printer on Standard TCP/IP port.
Sep 13, 2009 | Brother MFC 490cw Color Inkjet...
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
False "printer is offline" message
Try to cheeck the port from ur printer to ur cp is been connected.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP Officejet 4355 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
