Question about Refrigerators
The freezef stop working. I can hear the fan goin but its not cooling.
  • Refrigerators Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on May 27, 2011
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
Stopped cooling
go to your cooling control pannel ,,,, increase its number, set high your freezer temp, if you dont get any benifit, call to a service man . your compressor may be stopped working
Apr 04, 2014 | Haier Refrigerators
The radiator fan on my 2007 bmw 525i works fine while car is driving. Once i stop at a red light or in traffic the the fan stops working, ac blows hot air and mins later the car overheats. The car has a...
My guess is that your electric fan is NOT operating at all. Under normal conditions, just going down the highway, your cooling system will function just fine without a fan running. The air flow through the radiator is adequate to keep things cool. However, when you stop, you quickly get into an "overheat" situation. Actually, you should be able to hear your fan begin operating when your engine temperature starts climbing or your air conditioner requires the fan to do its thing. Note: If you've ever severely overheated your engine, your problems may be worse than just a fan not running, but you really do need to confirm whether your fan is operating correctly, or not. Another note: I had a vehicle with a tendency to overheat when stopped. It turned out to be a faulty (leaking) pressure cap on the cooling system.
Nov 04, 2013 | BMW 525 Cars & Trucks
Cooling pad grinding noise
As a temp fix, I've noticed that pressing the plastic circular area under the the bottom of the fan may help to realign the fan's bearings.
Basically push up until you hear the fan stop, then slowly release until you hear the fan starts up again. If it still grinds, repeat the process in a slightly different location of the plastic.
It takes a little work, but until a more permanent fix happens it's good enough.
Nov 03, 2013 | Belkin Laptop Cooling Pad
I just change new radiator and radiator cap on 2000 nissan quest .go on freeway .and know temp gauge very high i stop the car wait and run again ,now see a gauge go high and drop down to normal ,what is...
Make sure that the cooling system has the proper amount of antifreeze and that the fluid is full by checking and filling, if needed, by filling the reserve to the proper level. Then make sure that the cooling fans are coming on. Best test is to allow the engine to come up to operating temp while you observe the cooling fans. If they don't come on by the time the temp gauge is half way, try turning on the air conditioning to high. That should turn the fans on. If not check the cooling fan relay or module. Dan
Apr 23, 2012 | Nissan Quest Cars & Trucks
KEEPS GOIN OFF AFTER THE FAN MAKE NOISES, SHUTTS OFF VERY OFTEN AND GETS VERY HOT
Need the make & model & O.S. to help you. You can install this software any way to control the fan. Set the fan to always on and see if it cools down. If the fan is noisy it should be replaced and clean inside of laptop. Dust will clog fan and overheat laptop. Over heat causing the shut down condition. This is a great toll to keep Dell laptop's cool. Let me know if it works.
http://www.diefer.de/i8kfan/faq.html
Jun 06, 2010 | Dell Computers & Internet
I have a 2003 Jeep Liberty. The radiator cooling fan stopped working and the car almost overheated. I replaced the relay with the new style with the cooling pins and the fan now comes on, though...
no but there are a couple of cooling fan switches that could be causing your problem both are mounted on the motor one near the thermostat housing the other will be in the block one near the thermostat usually controls the fans.
Aug 28, 2009 | 2003 Jeep Liberty
Refrigerator stopped freezing & cooling
can you hear compressor working
Apr 05, 2009 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
