Question about Panasonic Televison & Video
Our panasonic tcp50x3 is not ih colored - Panasonic Televison & Video
  • 145 Answers
Did you mean no color for any channel or input sources? go to menu and set the system in auto menu - system mode- ntsc, secam, pal,..... etc. chose auto or ntsc 4.34 mhz
Posted on May 27, 2011
C8 mean
irst try switching off and on the printer to reset the error.
If still there the error check the following;
Check CN983, it may be disconnected on the IH inverter.
Defective IH inverter - replace IH inverter.
Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Jul 01, 2014 | Ricoh Aficio SP C820DN Laser Printer
How do i sync my panasonic phones cordless kx-tga810
335 is the magic code when you want to remove a previous handset or base station registration!
Handset:
1 " (middle soft key) i L i #
2 Enter "335".
3 "Cancel Handset" i #
LThe numbers of all handsets
registered to the base unit are
displayed.
4 Select the handset(s) you want to
cancel, by pressing the desired handset
number. i #
5 "Yes" i # i {ih}
Base Station:
A handset can be registered to a maximum
of 4 base units. A handset can cancel a base
unit that it is registered to. This allows the
handset to "forget" the base unit.
1 " (middle soft key) i N i #
2 "Registration" i #
3 Enter "335".
4 "Cancel Base" i #
5 Select the base unit(s) you want to
cancel, by pressing the desired base unit
number. i #
6 "Yes" i # i {ih}
Dec 23, 2013 | Panasonic KX TGA810 1Line Cordless...
Brightness fades in and out
There should be some problem with its main power supply regulator board. The voltage come out from it might be fluctuating. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact any experienced service technician, or the nearest service center.
Mar 12, 2013 | Panasonic 50 TCP50X3 50 Plasma TV
Error c472
[C471/472/473/474/475] indicates IH power voltage abnormality or IH initial abnormality
Clear the status counter (08-400) to "0". If still occur again, u need to check followings:
1. Check the AC input voltage
2. Check the thermostat
3. Check the IH control board
- Check if the AC input connector on the IH control board, the LGC I/F connectors CN455 is dis-connected?
- Check if the fuse on the IH control board has blown.
- Replace the IH control board.
4. Check the LGC board
Jun 17, 2012 | Toshiba COPIERS E-STUDIO 520 Copier
My coaxial input has broken off the back of my tv?
It's quite common for connections to be grouped on one or two boards for efficient production. They may be provided with cables that are plugged into their destination points.These factors mean that a single broken connector may not be replaceable alone but will have to be replaced as an assembly and its plugs reattached.
You may not get much help from the mfr. since this isn't a common failure. You may have better luck with one of the several companies that specialize in the disassembly and recycling of boards, speakers, and mechanical parts.
I checked shopjimmy.com but they show no parts available currently from your model which, incidentally, is actually just: TCP50X3
As this is a fairly recent model, recycled parts may not be available so you will likely have to contact a Panasonic service center and order the connector panel.
Nov 27, 2011 | Panasonic 50 TCP50X3 50 Plasma TV
Wifi i have a wifi modem can i use the wifi without connecting it to the tv or what do i need to use to get internet connection on my new panasonic viera plasma?
Yes,Wifi internet signal dose not require any connection to the tv all.Read ur tv owner manual how to activate ur tv Wifi internet signal out that all.This tv it is a internet ready compatible tv wright?
Jun 11, 2011 | Panasonic 50 TCP50X3 50 Plasma TV
Toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Jul 18, 2010 | Toshiba E-Studio 3511 Color Copier
Televison & Video Logo
46 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
