Question about Frigidaire Heating & Cooling
My frigidaire air conditioner isn't working.
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
SOURCE: Electronic control on Frigidaire air conditioner not working
which one take live or nuetral ?
common
start
run
thanks
Posted on Jul 11, 2009
dcramer531
  • 1654 Answers
SOURCE: Air conditioner isn't blowing cold!
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
Posted on May 29, 2011
  • 1033 Answers
SOURCE: rudd air conditioner isn't cooling,blowing
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Posted on Jun 19, 2011
  • 4736 Answers
SOURCE: why isn't there drain holes in bottom of
It shouldn't be a problem if you drilled the hole near the rear, outer edge of the drip pan and didn't accidentally pierce any of the mechanical above it. Also, be sure the rear of the unit is tilted down at least 1/4" to 1/2", so water will flow to it. Check the drain hole periodically, as they will become clogged over time.
Thanks for choosing FixYa.
Posted on Jul 23, 2011
Motor fan not working
If you clean and reset the unit, and the fan isn't still working, contact Frigidaire to see if you qualify for any assistance or limited warranty. Most of these small appliances do not have replacement parts since they are so small in BTU size.
Aug 04, 2012 | Frigidaire FRA065AT7 Wall/Window Air...
How to Replace broken fan on frigidaire air conditioner FAL125M1A1
Most of these AC units that are small in BTU size, under 15k, can't be repaired because most manufacturers don't have replacement parts available. Contact Frigidaire first.
Jul 30, 2012 | Frigidaire FAL125K1 Air Conditioner
How to make a ac unit get down to 40 degrees
You can't get an a/c unit to get to 40f unless you bypass its thermostat and have it in an enclosed, small space. It isn't designed as a chiller.
Apr 26, 2012 | Frigidaire Heating & Cooling
Our 4 month old Frigidaire FRA256ST2 stopped working today.We had an eletricain check the plug and the unit is getting power.When you plug it in and press the reset,it beeps,LCD flashes but doesn't...
A dirty or clogged air intake filter will prevent the unit from turning ON, as a safety feature. If that isn't of doesn't solve the problem. Contact Frigidaire 1-800-944-9044. As you unit is still under 100% warranty at this point. They will repair it or replace it at their option. Don't do anything to the unit, that could possibly void the warranty.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Frigidaire FRA256ST2 WallWindow Air...
My frigidare 25000 but unit isn't draining out of
Tip it a little downward on the outside. If you look at the back (outside), there may be a drain hole. Make sure it's not blocked.
Aug 12, 2011 | Frigidaire Heating & Cooling
Does the Frigidaire FAH106S1T Thru-Wall/Window Air Conditioner recycle inside air or pull in air from outside? Also, how do I close the vent on this model?
yes it does recycle the inside air - it 'does not' pull outside air in (in the air conditioning mode).
The 'exhaust/outside air' vent - 'if it has one' (some don't these days) will usually be a manual pull/push lever, although I guess it might be a electrical/electronic switch.
hope this has helped.
Aug 05, 2011 | Frigidaire FAH106S1T Thru-Wall/Window Air...
My window is only 18-19" wide. I need to know the
You can find the information you're looking for, as well as the Owner's Manual and Installation Guide at the following link.
http://www.frigidaire.com/products/air-conditioners-dehumidifiers/window-air-conditioners/fra052xt7
Hope this helped you.
Jul 14, 2011 | Frigidaire FAX052P7 Compact Room Air...
High efficiency outside air conditioner does not cool house, seems to for a while but stops. The pipes at the air conditioner are coated with ice so seems to produce cold but does not blow that through the...
Unfortunately, the ice coating isn't normal, in fact, it is an indication that your unit is low on freon or a blockage. But could also mean a few other things.
But about the only thing you can do yourself is make sure that the fan is turning or not.
Jul 07, 2011 | Frigidaire Heating & Cooling
Rudd air conditioner isn't cooling,blowing ,but isn't cooling my house because air is not cold
Jun 19, 2011 | Ruud UAMB Air Conditioner
Air conditioner isn't blowing cold! Fan works okay but air isn't cool. Can hear hissing sound that sounds like normal compressor function. Do I need a coolant recharge?
May 29, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
Heating & Cooling Logo
79 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
