Question about GE GFSS6KKYSS
GE digital display is 88 88 for several hours after any power outage. This started after utility x-former fire and clears itself before service can be dispatched. Does control need replaced ? Started while still in warranty.
3 Suggested Answers
  • 93 Answers
SOURCE: I have the same problem as most. I have a GE
its sound like your defrost timer is not working a fridge should defrost every 8 hours replace your defrost timer leave your door open to defrost all the ice buld up the timer shoul be located in the back lower where the compressor is located it about 3 sqare inch normally black with a small motor on or some are white in coulours thanks from gilles
Posted on Mar 15, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: GE Profile PFSS6PKWASS ice maker quit, water and
Try defrosting it completely then re start it again. Shut off the water suplly. Maybe the service guy forgot to turn the water supply off.
Posted on Jul 07, 2010
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Samsung RF26X series refrigerator. Power Co turned off our power to do some work in our neighborhood. Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes 88 then...
This is normal after power outage .
Unplug for 30 seconds to clear code then wait several hours for computer to stabilize.Then your good to go.
Was this helpful?
Aug 16, 2011 | Refrigerators
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
I have a GE Profile refrig with bottom freezer.Today, the power company turned off the power to the streey and when power came back on, my display in the left refrig door is brinking 88 on one side and the...
I had this issue after a power outage with our GE Profile Model GFSF6KKY Dispenser Model. No solution that I could find online helped me so I started trying different button combinations. Pressing Adjust Freezer and Adjust Refrigerator buttons at the same time and holding it for at least 10 seconds worked for me.
Nov 19, 2010 | Refrigerators
After lightning strike & power outage digital display & oven not working. is there a fuse or reset button? or is the circuit board fried?
Start by investigating, open at the point where power cord goes in there is a fuse if it is o.k there is another smaller trans former powering the display board that normally uses thermo fuse, find out whether the thermo fuse is blown i hope this solves your problem
Aug 02, 2010 | Microwave Ovens
Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
Sep 19, 2009 | GE Refrigerators
Ge profile arctica
It is unlikely that a power outage by itself will cause your problem. Recheck hour refrigerator thermostat. It should regulate to 38-42 degrees F. You can take an outdoor thermometer and put it into the fridge compartment, leave it for an hour or two and check. Adjust as necessary. If that doesn't fix it, we can proceed further.
Jan 23, 2008 | GE Profile PFS22 33" Artica French Door...
Door Keeps Locking and Unlocking after Power Outage
Located the switch - resetting fixed my stove as well.
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE GFSS6KKYSS Logo
62 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
