Question about HP P2360AA Keyboard/Mouse
My niece was playing on my computer. My mouse doesn't work now. Is there a button on the keyboard that turns the mouse off? The touch mouse still works.
  • 92 Answers
There is no button to turn off or to disable the mouse function.. But you can set or disable your mouse by configuring to your Device Manager. But take not, before you disable your mouse, you should know how to use shortcut keys and use only keyboard to navigate your files..
Posted on May 27, 2011
My keyboard in my revo rl100 doesn't work
Sounds like the battery in the keyboard is dead. Also make sure you have the wireless doggle that came with the keyboard and mouse plugged into the usb port. You might try plugging it into another port.
I'm thinking your keyboard is dead because of the battery or a virus has hijacked your keyboard.
Try booting up in Safe Mode to make sure it's not virus related. Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option and let it boot up. Safe Mode will look different because the icons are bigger and the screen is darker, this is normal. If your keyboard works in safe mode then you might have a virus that can't function in safe mode.
Mar 25, 2012 | Acer Revo RL100U1002 Desktop Computer...
Mg 0856
Sounds like a mechanical problem--in other words, the inside of the mouse is dirty. Probably has dust and stuff.
I'd suggest removing the base and trying to get all foreign matter out of it. Blow it out with compressed air.
Dec 03, 2011 | HP Wireless Optical Mouse
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Hi, I've a problem with a chicony 9820 keyboard under win XP. I've connected it to computer using a PS2toUSB adapter -2 PS2 input and 1 USB output- The problem is that the keyboard works fine, but...
You have to sync the mouse to the receiver . The receiver should have a button on it and the mouse should have one on the bottom. push the button on the receiver and then push the button on the bottom of the mouse they should then syc together.
Dec 12, 2017 | Spec Research Chicony 9820X (KB-9820)...
How can i connect my ex110 with computer
Hello there.
  1. If your wireless keyboard came with a software CD, install that first.
  2. Then plug-in the USB receiver it came with it on a USB port on your computer.
  3. Put all the batteries on the keyboard and mouse.
  4. If it doesn't work, you may find a Connect button under the keyboard and / or mouse.
  5. You can find drivers and manuals for your keyboard and mouse here: http://www.logitech.com/en-au/433/154
Aug 21, 2011 | Logitech Cordless Desktop EX110
My mousepad is working but the cursor between left and right button doesn't work? I have a ACER Aspire 9300
1) Go to control panel (either with the help of keyboard or mouse)
2) Open Mouse
3) On Button Tab Select Button Configuration ( Switch Primary and Secondary Buttons)
4) Also Check your Touch Pad Driver Software
Thanking you
May 16, 2011 | Acer Aspire 9300 Notebook
Does Saitek M80X wireless notebook mouse need special drivers for Acer Aspire 5742 running Win 7 64 bit?
No, the mouse is plug and play.
You have to manually pair the mouse with the dongle.
Follow this steps and retry them a few times and it will work:
  • Plug the dongle in.
  • Press the button on the dongle for two seconds so that the green light flashes on and off.
  • Press the button on the underside of the mouse once (short press).
  • Wait for the mouse to pair.
  • If it doesn't pair, press the button underneath the mouse once to continue scanning.
The whole process shouldn't take longer than 10 seconds
Hope it helps...
Jan 06, 2011 | Apple Mouse
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
Keyboard
From the Dell D620 Users Manual:
You can use the Mouse Properties window to disable the touch pad and track stick or adjust their settings.
  1. Open the Control Panel and click Mouse.
  2. In the Mouse Properties window:
    • Click the Device Select tab to disable the touch pad and track stick.
    • Click the Pointer tab to adjust touch pad and track stick settings.
  3. Click OK to save the settings and close the window.
The Mouse Properties utility is found like this:
Start Button>Control Panel>Printers and Other Hardware>Mouse
or in the Classic View
Start Button->Control Panel-> Mouse
Dec 31, 2008 | Dell Latitude D620 Notebook
Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
Mar 08, 2008 | Acer Wireless WIL-152 91.84R07.152...
HP P2360AA Keyboard/Mouse Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
