Question about Hotpoint HSS25GFP Side by Side Refrigerator
May need new circuit board - Refrigerator and freezer stopped working
    Scholar:
  • 142 Answers
I'l tell you a little secret: take the board out and look at the solder side. If you see a burnt terminal or burnt copper lead, more often that not you can fix that. If you know how to solder, that is.
Posted on May 27, 2011
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Where can i buy a circuit board for my lg refrigerator model lfc23760st
No need to buy a new main control board !
The problem is mainly from the fuse that soldered in the main control board, go to buy a "125V 15A or 250V 15A" fuse ($5.00 a pack of 5 pcs), cut the burnt fuse from the board, re-soldered the new fuse into the board, the refrigerator work again. you save $80 for the labour cost of the technician and $180 for the cost of a new main board.
Jul 18, 2012 | LG LFC23760ST Side by Side Bottom Freezer...
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
Refrigerator not working, freezer stll works
if you recently had light bulbs burn out in the refrige section and now the digital temp read-out is also dark,it will be your control board (motherboard) needs replacement as the bulbs burn out it causes a surge and ruins this board,its located in the lower rear area on the left lower wall in or on the inside back in a plastic case,open the case unplug the wire harnesses and remove the board,it will have some circuit trace burned and the plastic case will be discolored there
Feb 14, 2010 | Refrigerators
Norcold refrigerator burner will not stay lit. Ignitor lights the gas, but as soon as it the ignitor stops, the flame goes out. Thanks.
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Nov 16, 2009 | Thetford Norcold RV Cooler/Freezer
3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT DEFROSTING, CAUSING BOTH SIDED TO GET WARM. ELECTRIC CHECKED OUT ON HEATER AND THERMOSTAT. PUT IN A NEW CIRCUIT BOARD. SAME PROBLEM. NEW BOARD MAKES...
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
Mar 10, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Frig working, freezer stops working, then starts working again
The computer control circuit board was found to have a burned out circuit. The board is on the lower back side behind a panel, easy to replace. Just need the proper model number to order the board.
Sep 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Dec 02, 2007 | Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
189 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
