Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
How much oil do I put in the compressor, what should the oil window read?
    Sergeant:
    Novelist:
  • 185 Answers
Half a glass or below to quarter glass and you should be fine. If you can see the oil level in the sight glass you are OK.... If you can't see it add to half a glass. Never over fill it that is just as hard on it as not enough....
Posted on May 27, 2011
Compressor not running
id try a new capacitor (cheapest solution) , but sounds to me that your compressor is done for. id bet the evap coil is quite dirty , this is a usuall cause
Jul 21, 2015 | Haier ESA412K 12,000 BTU Energy Star...
New centralpneumatic air compressor does not show an oil level in the indicator window
read the instructions, nowadays some come w/out oil in them, better to be safe than sorry.... oil color if there is any should be a light tan color which is pretty noticeable.
Apr 14, 2013 | Air Tools & Compressors
My compressor will pump anymore than 35 pounds. I have put in a new piston kit. What is wrong
Does the motor continue to cycle?
Is the air bleed valve completely closed?
Is the regulator knob adjusted to the highest pressure?
What are the tank readings vs. the regulated pressure readings?
Hope this helps.
Jun 22, 2010 | Porter Cable Cable 135 PSI, 15 Gal. Oil -...
Air conditioner compressor making a knocking noise while running.i read that oil needs to be put in it if so where and how or do I need to plan on replacing the compressor
Get a can of R134a refrigerant with sealant and oil and add with a hose.
Can buy at Walmart for under $30.
Buy the conversion from R-12 to R134a kit if you need to.
Sometimes adding a few ounces of oil will quiet the compressor but you have to try.
Compressor is probably a few hundred dollars to replace, so try the cheap solution first.
Jul 04, 2010 | Cars & Trucks
Can I put it on its side in the window
I would say no. The compressor has oil in it which stands in the bottom of the case. If you put it on it's side the oil will no longer be in the bottom lubricating the compressor.
Jul 02, 2010 | Heating & Cooling
How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Apr 10, 2010 | Air Tools & Compressors
Goodman ckl49-1 fan doesn't work after a really bad storm.
It is possible that the rain has washed out the bearings and the motor is frozen up. You may need to replace the motor. Also you don't need to put more oil in the compressor. The compressor comes with oil already sealed in it and it does not need to be changed or any more oil added to it.
Aug 05, 2009 | Heating & Cooling
I installed a new a/c compressor on a 91 geo metro.Where does the compressor oil go into the compressor at?
The compressor's oil is mixed with and circulates with the refrigerant. R134a refrigerant can be purchased with or without oil mixed into it. There are also separate oil 'chargers' that inject oil without the refrigerant.
Jul 01, 2009 | 1991 Geo Metro
Over service craftsman air compressor with oil
Just find the drain plug and drain out some of the oil and put the plug back at the right time to get about the correct oil level.
The drain plug may be the sight window itself, if you can't find one.
If you need more help, post a comment.
Thanks,
Tim
Mar 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
211 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
