Question about Samsung HLR5087W 50" Rear Projection HDTV
Ok my samsung hlr5087 has blaack vertical lines going thru the whole screen.they are skinney lines but the picture is great.i have been told its the dmd module.please hellp me.its like watching tv thru a fence
  • 10,594 Answers
I'm afraid it is dmd module that is bad and need to be replaced, it would cost approx $800 plus labor so buying a new lcd tv would be good decision.
Thanks.
Posted on May 27, 2011
TV has a great picture but wont "hold it". Keeps going to a single flat horizontal line across the middle of the screen. Tapping on side of TV used to bring it back but now, nothing. Just a line.
Vertical scan output section circuit fault. Absence of vertical scan causes the single horizontal line on screen. Horizontal scan output section is OK. Contact any service technician to troubleshoot the vertical scan output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Horizontal line fault to CRT based TVs are given.
Oct 06, 2014 | Televison & Video
HL-6187W, picture has vertical lines
If you can post a picture of what the lines are I can assist with the possible causes. I would assume digital board or DMD/ light engine
But a pic would help make it easier to figure out whats going on with the set.Respond to this same post for assistance.
Aug 07, 2012 | Samsung HL-S6187W 61 in. HDTV
I have a vertical line in the middle of the tv it has what looks like pictures how do I resolve this at home
hi there, seems you have a defective Vertical IC. If you can locate this 8-10 pins mounted on heat sink and has label LA 7837 or alike. try to replace this. defective vertical IC somehow manifest as horizontal line in the middle of the screen. it has picture but cannot adjusted to occupy the whole screen. Hope this help, please rate and vote. good day
Mar 26, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Nov 25, 2008 | Samsung Televison & Video
Sharp Tv 25E-M50
WELL FIRST U HAVE TO SEE WHETEHR THE SUPPLY FOR VERTICAL SECTION IS OK.IF ITS OK THAN.CHECK FOR SOME DRY SOLDER AT VERTICAL SECTION.OR ANY LEAKAGE CONDENSER ,AT LAST REAPLACE THE IC VERTICAL.IT WILL BE OK'
May 21, 2008 | Sharp 25N-M100 25" TV
Projector vertical running lines
Hi there
This is definatelly a interference from a power cable. If any of your signal cables in the ceiling is closer that 5cm to one of those , you will get interference.
The Company that did the installation should know this and I would suggest you call them and tell them that they should sort it out. They should either move the cables or insulate them by means of conduit.
Apr 15, 2008 | NEC MultiSync MT830 Multimedia Projector
Samsung HLR5087W 50" Rear Projection HDTV Logo
168 people viewed this question
Jerry Greenberg
Jerry Greenberg
