Question about Olympus FE-230 Digital Camera
FE-230 Failure to come on
Camera lenses opens and retracts several times then finally turns off. Battery is fully charged and I checked it with a meter. The 3.7 battery registered 4.1. I will manually hold lenses open and sometime after turning camera off and on it will then work properly for a few days then same thing happens again. I purchased camera this year. Thanks, gary@kathyjclark.com
  • garylavan Aug 16, 2008
    My camera is under warranty but has not been dropped. I will contact warranty service. Thank you.
    Scholar:
  • 71 Answers
Hi Gary
Is the camera under warranty and registered with Olympus? If not registered, make sure you do that online first. It also extends your warranty to 13 months. If no receipt, It was a gift.
You most likely have a bad lens assembly (was it dropped?) or microprocessor. Here's your link...
Olympususamerica.com
Consumer division, customer service 1-800-622-6372 M-F 8 to 7 EST
Outstanding people to deal with
Hope I could be of some help. Regards, Paul
Posted on Aug 16, 2008
I own a sony cybershot dsc w35 when i switch on the screen displays "turn the power off and on again" help?
Hi. I had exactly the same problem with my Sony Cyber-Shot DSC-W7. The problem started after while lense was fully open, the battery became 100% empty. I did not have access to new batteries and did not have my charger with me so I put the camera on my car seat and went home. After charging the batteries, I turned the camera Off and the lense retracted 100%. Later on I tried to transfer some pictures to my PC. After connecting the camera to my PC with the dial in the P position and lense fully open I turned the dial to play in order to transfer photos. After transferring the pictures, I turned the camera off and disconnected from the computer.
I turn the camera on to take new pictures next day, The lense would go up, and and turn with lense fully open. It would never close. The screen was black with a message "Turn the camera on and off again". I tried 30 times or more and the same thing would happen again.
Here is what I did to fix my camera and it has been working normally since then.
1- I cleaned around the outside of the lense with lent free cloth
2- I used dust OFF to get raid of the remaining small dust particles from around the lense.
3- While turning the camera off, I pushed (down, up and turn) the lense in (NOT TOO Hard) by my hand. If you push the lense too hard, you may damage the mechanicall moving parts of the lense.
4- After a few tries, the lense retracted 90% +. I then pushed the lense a little harder all the way in, the way it normall retracts. The lense cover also closed 100%.
5- I turned the Camera on and off a few times. It was opening and closing exactly the way it used to. My Cybershot has been working okay since then.
I read a lot and here is what cause my lense to malfunction.
While lense was fully open and battery died, some small particles got on the lense and prevented lense from fully opening or closing.
In summery: two things could have caused your camera lense to malfunction.
1- if you had dropped your camera hard, some mechanical parts may have got damaged or dislocated. In this case you have to open the lense and replace the damaged part, clean and put it back on the camera. This is too risky for most ordinary people. You would most likely make it WORST.
2- If you did not drop it, most likly, some how some small dust particles got on the outside of the lense and they prevent the lense or the lense cover from fully opening and closing. If this is your case, please follow exactly what I did and your camera would be back to normal.
GOOD LUCK!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 25, 2009 | Sony Cameras
Turn the power off and on again
Jun 25, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
My Sony Cyber-Shot DSC-W55 camera does not turn on properly. When I press the gallery button, everything runs smoothly. When I press the on button, the lens opens and closes several times, making a little...
Jun 25, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Hello I have a canon IXUS 960 IS. Yesterday when I was using the camera it only closed half way when powering the camera off. Now the camera doesn't open fully and when pusing the "play" button the power...
If the outside of the lense get dirty, those small particles may prevent the lense from opening and closing 100% as nomal times. I had the same problem with my Sony. Here is what I did.
1- I cleaned the outside(sides not the lense itself) of the lense.
2- While turning the camera off, I press on the lense (up and down motion) NOT too hard for a few times untill it either retracted all the way inn or most of the way in. If most of the way in, press the lense a little harder untill it retracts 100%. If you turn it back on, it should work as normal unless some mechanical part of the lense is broken or dislocated. When it fully opens, clean up the outside of the lense and keep it always clean for normal operation.
Good Luck!!!!!!!!
Jun 11, 2009 | Canon IXUS 960 IS Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Sony cybershot 7.2 went to shut off camera and lense is still out no power to camera tried to recharge batt. w/no results
Try different batteries. I got the same problem with my cyber-shot. The battery was too low while lense was fully open. I recharged, but the lense would not close. When I turn it on, It would say turn off and on again. I did that for at least 20 times. I finally put another set of batteries and while I turned off the camera, I pressed the lense in very softly. After a couple of times the lense retracted fully. The camera has been working normally ever since.
It is also possible some dirt some how got on the sides of your lense. Try cleaning the sides of the lense.
If you had no luck so far, then your lense may have some mechanical problem. The lense need to be opened and cleaned and put back together.
good luck
Jun 09, 2009 | Sony Cyber-Shot DSC-P32 Digital Camera
Zoom lense wont retract
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $73.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 02, 2009 | Olympus FE-230 Digital Camera
Olympus fe-230
lens appears to be off track and needs repair
Oct 06, 2008 | Olympus FE-230 Digital Camera
Lens not opening
If your battery is fully charged, then it would need to go to repair
Aug 04, 2008 | Olympus FE-230 Digital Camera
Olympus FE-230 Digital Camera Logo
125 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
