Question about Kodak EasyShare DX7630 Digital Camera
The LCD monitor of my Kodak DX7630 camera has turned black. It still works on "review" mode and "menu" mode, but pictures taken are also black. The flash works, everything works, unless the viewer. What will I do to fix this?
    Sergeant:
    Champion:
  • 214 Answers
Hi your unit has shutter unit defective in lens unit assemble. you can bring to your local repair shop would charge around $45 to 95 depend on what they really want to charge. Thanks and best regard!
Posted on May 27, 2011
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
Lcd screen does not show scene and photos are all black. can anyone help?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 22, 2011 | Kodak EasyShare DX7630 Digital Camera
The viewfinder is blank and working only with review option. Since the viewfinder is blank the photo and video is also blank. Is it a firmware software problem.
Its a camera CCD Problem. If the View finder & LCD both showing black then its 100% CCD problem. Let me know Lcd also black? Also make sure lens is not covered by any thing.
Aug 24, 2010 | Kodak EasyShare DX7630 Digital Camera
Canon s2IS when I turn the camera on in review mode the LCD screen displays pictures one after another. Cannot stop the picture review except to turn off the camera. In camera mode the menu button and...
Please do the followings.
1. Turn off the camera.
2. Remove the memory card.
3. Remove the batteries.
4. Wait at least 3-5 minutes.
5. Place the memory card and batteries.
6. Turn on the camera in any mode except review mode.
7. Take any ordinary picture.
8. Change the camera mode to review.
9. What happened now. Is everything normal. if not please write a comment to explain the situation.
Jun 03, 2010 | Canon PowerShot S2 IS Digital Camera
Lcd screen does not show what your taking picture of
Turn the camera on. Press the display button (second button down right next to the LCD (Labeled LCD/info) to turn on the LCD. Make sure you are not in review mode. Here is a link I am sure you will find helpful (its what I used to solve this problem)
http://www.kodak.com/global/en/service/publications/urg00714toc.jhtml
Let me know if this works
Cheers
Jer
Jan 16, 2010 | Kodak EasyShare Z885 Digital Camera
Kodak Easyshare DX7630 screen is black and won't take anymore pic
your image sensor is bad it will have to be replaced by a camera technician .
Jun 03, 2009 | Kodak EasyShare DX7630 Digital Camera
KODAK eASYSHARE c530 BLACK SCREEN DOES NOT TAKE PICTURE
You may still be able to take pictures with your black screened Kodak camera. This problem occurs in the line of Kodak EasyShare digital camera models.
When you turn on your Kodak EasyShare digital camera, turn off the LiveView function. Take a picture using the small-windowed viewfinder (this is not the LCD screen). Also, try zooming in and out.
After taking a picture, review the picture to see if the picture has been taken. Then turn on LiveView and occasionally the LCD screen should no longer be showing a black screen.
Aug 31, 2008 | Kodak EasyShare C315 Digital Camera
Kodak easyshare DX 7630 screen black in take a picture mode but is fine in review etc
Hey Wistra,
You could try resetting your camera to the factory settings by choosing the reset to default setting in the menu. If this doesn't work the sensor on the camera is most likely broken, and you should have the camera looked at by an authorized service technician. If the camera was purchased less than a year ago the repair would most likely be covered under manufacturers’ warranty. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 05, 2008 | Kodak EasyShare DX7630 Digital Camera
Kodak CX7330. turns on but LCD screen is black and won't take a pic
It sounds like a bad connection on the ribbon cable of the LCD screen to the camera's motherboard. The fact that when you physically move the camera around and you can get the screen to then work, tells me something is loose inside.
- Jim
Jan 14, 2008 | Kodak EasyShare CX7330 Digital Camera
Picture screen
This is an ongoing screen defact - Contact Kodak for a repair quote.e
Jul 17, 2007 | Kodak EasyShare DX7630 Digital Camera
Kodak EasyShare DX7630 Digital Camera Logo
76 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
