Question about Dehumidifiers
Dehumidifier won't fill up with water and makes
    President:
  • Dehumidifiers Master
  • 2,080 Answers
If the machine's compressor runs when you switch it on, then turn the machine on maximum and let it run for an hour or so. Then check the coils in the back with your hand. If they are not getting cold at all, then there is a significant problem with the refrigeration process in the unit. It may have developed a leak and allowed your refrigerant gas to escape, or there may be another internal problem with the compressor. Either way you would need to have it serviced by a fridge technician, or more likely just replaced with a whole new unit since both options can potentially cost about the same.
If the unit runs normally and the coils are getting cold, then make sure they are not totally icing up which will impede the unit's performance. If your dehumidifier is freezing up then that probably means the unit itself is actually working well. The temperature or humidity level in the room may be a bit low and you may have the unit turned up too high for the conditions.
Try turning down the setting on the unit so that it cycles on and off every few hours and does not run continuously.
Also try using some warm soapy water to clean off any dust or oily residue from the cooling coils in the rear of the unit. Remember to also clean the air intake filter while you are at it.
If the ambient temperature in the room is a bit low, you can try adding some heat to the room if necessary. A dehumidifier will not work properly if the ambient air temperature is too low. Generally, the warmer and more humid the room is, the better they work.Since warm air rises, you can even try lifting the unit higher up off the cold floor onto a bench or table where the air is warmer.
You can click on the following link for a general operating and troubleshooting guide with additional tips on effective dehumidifier operation:
http://www.allergyconsumerreview.com/dehumidifier-advice-troubleshooting.html
The rattling noise may just be the coils vibrating against each other. Sometimes you can gently bend the coils apart slightly so they don't rattle, just dont bend them too much or you might damage them.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Posted on May 27, 2011
Motor is making very loud noise when on and bucket is not filling up with water. Machine is getting very very hot at the top when turning on.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Amcor AHD65 Dehumidifier
Dehumidifier will run but the bucket won't fill. Is there a way to run my model without the bucket? I have a maytag m7dh4582a and do not have my manual. Could their be something else wrong with it?
Is it producing water or not??? If no water is being produced, then check out this tip...
If you are making water and it is just going all over the place then, the little spout coming off the bottom of the coil, that runs the water into the bucket is clogged with dirt and you just need to take a small toothpick or knife and work the dirt out of the spout...
heatman101
Jul 23, 2011 | Maytag M7DH45B2A Dehumidifier
Compresser on the bottom gets very hot won't work
heatman101
Jul 19, 2011 | Whirlpool AD25BBK Dehumidifier
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
Jul 02, 2011 | Maytag Dehumidifiers
Water overflows when filled how do I adjust?
Remove the tank and locate the switch and 'teeter' (that the tank sits on). Make sure the tank is able to move when filled. You will have to adjust the position of the switch to allow the filled (teetered) tank to shut the device off.
Is it possible for you to drain the water into a nearby floor drain using a hose?
Thanks for your question @ FixYa.com
Jun 26, 2011 | Goldstar DH2510A Dehumidifier
Compressor won't start,can hear circuit breaker clicking out. Fan runs okay,gauges reading okay.
heatman101
Jun 06, 2011 | Fedders A7DH45B2A Dehumidifier
It won't start. Turning the knob, I don't hear the
heatman101
Jun 06, 2011 | Dehumidifiers
Zenith,water doesnot fill thetank
heatman101
Jun 01, 2011 | Dehumidifiers
My ebac 2000 is making a noise and not collecting water
heatman101
May 23, 2011 | Ebac Dehumidifiers
My Haier dehumidifer runs but doesn't collect any water. I have another exact same dehumidifier sitting 10 feet away and it fills up about every 24 to 36 hours so I know the conditions are that it...
heatman101
May 12, 2011 | Haier Dehumidifiers
Dehumidifiers Logo
202 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
