Question about Samsung SMH7174BC Microwave Oven
How to remove the control panel of a samsung microwave? model # smh7178ste
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave oven stuck on high
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
There may instead be a stuck relay on the control board, which we repair for customers nationwide with our guaranteed $39.95 service.
Feel free to contact me directly.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 08, 2008
SOURCE: How do I remove the control panel on model JE2160
You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
Posted on Jan 15, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: I need to replace the
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward.
On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
They're our favorite supplier.
Posted on Aug 23, 2010
KevinWhite
  • 1902 Answers
SOURCE: Samsung microwave model smh7178ste runs, but does
Hello & Welcome to FixYa
E-63 error code in your Samsung Microwave is a T1 maximum timer error which means that the power control board has gone bad and needs replacement. However, before replacing it you can unplug the unit for 5-10 minutes to do a hard reset, if the problem is back then replacing the PCB is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Mar 15, 2011
TheMobilian
  • 8220 Answers
Interesting video of how to get into a GE:
Service manual of a late model GE
More here
Posted on Mar 18, 2011
How to remove grease filter from a Samsung over the range microwave model number smh8165st
The support page for model SMH8165S is here, and the first solution listed is how to replace the charcoal filter.
You can also download your owner's manual.
The charcoal filter is part number DE63-00367A and you can order it from the Pros here.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
May 01, 2017 | Samsung Microwave Ovens
How do you remove grease filter from Samsung over the range microwave model number smh8165st?h
pupista@gmail.com
Smh7178ste
Bad touchpad. Part# DE34-00205C for just the touchpad or DE94-01120D for the control assembly (easier to replace but more expensive)
Aug 09, 2014 | Microwave Ovens
SE or 5E display on Samsung Model number SMH8165ST
This microwave is a piece of garbage and Samsung are a bunch of idiots. I have a solution but first I will vent. One day after my warranty ran out, I started getting this SE error. They referred me to an authorized repairman, who said it would be $200 just to come and look at it! Thats for a microwave that sold for slightly more than that new! Samsung refuses to offer any do it yourself help. Some guy who works on microwaves told me to order a new control panel. part DE94-01806C It was about 36 dollars and took about 10 minutes to install. If you want to save a little, for 24 dollars you can just replace the membrane. That requires removing the existing membrane with a hair dryer and then carefully applying the new one. Seemed like too much trouble so I went with the control panel.
Feb 04, 2012 | Samsung SMH9151 Microwave Oven
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
Will not heat and the truntable will not run
It's almost certainly the primary interlock (top door switch).
See this file for details on checking and replacing door switches.
You can also see the video at our site, which shows you how to access the door switches.
We have the service manual for the model SMH7178STE here, which should be pretty similar. It will also help you with disassembly.
May 06, 2010 | Samsung 1.8 Cu. Ft. Over-the-Range...
Samsung microwave auto starting
Please provide the model number of the microwave, and we'll be able to supply the part info. (Some Samsung models with this problem were part of a huge recall).
Sep 04, 2008 | Microwave Ovens
Microwave oven stuck on high power. Setting say 80% power does not work as it did before. Model is smh7178ste purchased 11/1/2007
William E. Miller
prototech@usa.net
Aug 07, 2008 | Samsung Microwave Ovens
Control panel
For complete info & instructions, please do a search on Yahoo.com (not Google) for this: microwave circuit repair
Nov 28, 2006 | Samsung MS840 800 Watts Microwave Oven
Microwave Ovens Logo
552 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
