Question about Garmin Gpsmap 541s Dual Frequency Combo GPS Receiver
My Garmin 541S does not show an accurate depth reading. Sometimes it flashes, or reads 6ft when I know the depth is 40feet. It just started doing this.
3 Suggested Answers
  • 5 Answers
SOURCE: NO DEPTH READING
Check the finder on the bottom of the boat and make sure the cable is ok?
Posted on Aug 09, 2007
likha
  • 790 Answers
SOURCE: depth display
reset your factory settings!
Posted on Oct 03, 2007
What is causing the depth to keep blinking when my boat is on plane.sometimes the screen just shows a horizontal line where the depth should read. garmin541s brand new
First, make sure that the connection is good, clean, and tight on both ends of your transducer. Sometimes turbulance or temperature stratifications in the subsurface water will cause this. Also, check the specifications of your transducer. Some do not perform well while moving at high speed. One test, when on plane, when the problem occurs, slow the boat and see what happens to the readout. Repeat this several times. This should help narrow down what is causing the problem.
Sep 19, 2013 | Garmin GPSMAP 541s
Garmin 541s transucer, unit problems
Sound like the transducer is catching air.
May 10, 2013 | Garmin GPSMAP 541s
Garmin 541s rear tansducer does not read after plaining out
first of all it wont read after you plain out and as far as cutting off connect it straight to the battery see if that fix your problem
May 08, 2013 | Garmin GPSMAP 541s
I lose depth when moving
that's common with all depth finders when on plane you loose bottom lock when you slow down to stop does it start to work again if so you have no problem
Apr 22, 2013 | Garmin GPSMAP 541s
Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Jul 08, 2010 | Garmin Fishfinder 90
I have a gps Map 498-depth sounder not working? Have new transducer from Garmin-it flashes "00"-it is not connected to boat yet (transducer)-need it be or can I put in a bucket of water (need it be in...
If the transducer is out of the water, you will not get a reading and see the flashing depth. You should hear and feel the clicking in the transducer when out of the water and working properly. Are you getting a temp reading when out of the water?
May 16, 2010 | Boating
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
New GPSMap 440 S Depth flashing
You need to visit the garmin site and download a software upgrade its free and should fix any glitches you may be experiencing with your unit.
Jul 01, 2009 | Garmin Gpsmap 440s Dual Frequency Combo
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Depth display
Oct 02, 2007 | Garmin GPSMAP 498
Garmin Gpsmap 541s Dual Frequency Combo GPS Receiver Logo
248 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
