Error SC326 on aficio 1045
Good day all,
i've this error code sc326 on my aficio 1045, can anyone assist me how to solve this problem.
  • 417 Answers
Hi there below is what is states in the service manual.
326 C 2nd laser synchronization error
The 2nd laser synchronization signal
cannot be detected by the main scan
synchronization detector board even if
the laser diodes are activated.
• Poor connection between the laser
synchronization detector board and
the LD unit.
• Laser synchronization detector board
out of position
defective
• LD unit defective
Hope this helps you.
Thanks Jason
Posted on Aug 17, 2008
Reset error code
It's a laser error code, service call required
Feb 04, 2014 | Ricoh Aficio 2035 Copier
What is error code SC326-00 on a Ricoh Aficio 450 copier?
326 error in laser unit . check ld conection and reset yourmachin
Jul 05, 2012 | Ricoh Aficio 450 Copier
MY RICOH AFICIO MP C6000 IS SHOWING AN ERROR CODE SC326
That is a "second laser synchronization error". Try this: Hit the yellow button, press numbers 1, then 0, then 7, then hit the orange key. When it goes into SP mode, turn off the copier and unplug it. Wait 15 seconds then plug back in and turn on. If that does not fix it then you need to call a tech to service the machine.
Mar 05, 2011 | Ricoh Aficio 1035 Copier
Error sc326
this number belong to synchro2 is not detect replace laser unit
Feb 15, 2011 | Ricoh Aficio 3025P Black and White Copier
I have problem model ricoh aficio 3235 error sc326
you proplem with laser unit sychro2 not detected try to clean mirrors inside laser and be carful if it's not work out change it and go to programmes and put 2-109 and 2-108
Jan 09, 2011 | Gestetner DSm635 Copier
RICOH AFICIO 1035 I GET AN ERROR CODE SC326 AND PAPER KEEPS GETING JAMED WHERE IT TRIES TO ENTER THE BIG GREEN ROLLER.
SC326 is a laser synch detect error. The jamming is probably just because of the code popping up and the machine shutting down. 9 times out of 10 the cause of an SC326 is toner dust buildup on the laser optics. It is either that or possibly a laser unit (LD Unit) failure. The power to the LD unit flows thru the front door switches and I have seen those go bad and cut or reduce power to the LD unit which will cause the same code. I would get a Ricoh tech out to clean the laser optics. This is especially true if you open the fron door and there is toner dusting around the toner cartridge/DV unit area.
Good Luck and Thank You for using Fixya.
Aug 31, 2010 | Ricoh Aficio 1035 Copier
Sir my Ricoh 1045 machine have SC 326 problem, after taking a single copy the error code comes. please give a good solution to clear my problem. thanks
sc326 is a laser synchronization error. The problem is usually caused by the laser sync detection board or the LD unit.
Jun 02, 2010 | Ricoh Aficio 1035 Copier
After sc326-00 my copieur ricoh aficio 350 put on his screen sc322-00 and not work, how cold i resolve this problem
Laser Synchronization Error(1 & 2)(sc322 & sc326)
· Laser synchronization detector board out of position
· Laser synchronization detector board defective
Also check if any cables are loose and also if the laser unit is dirty.-Clean it.
Feb 09, 2010 | Ricoh Aficio 350e Printer
Ricoh Aficio 3006 error sc452
The SC 326 is -- 2nd laser synchronization error. Meaning, the 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated.
Basically your polygonal mirror motor unit is bad and needs to be replaced. You can replace the whole laser unit but that is expensive. When you replace the PMM unit, do so in a still air area -- as to not get anything in the unit. When you get the PMM unit -- contact me and I can walk you through the steps to replace.
The SC 452 is --- Transfer Belt Mark Detection Error. Once you fix the SC 326 error this one should be fixed also.
Jul 17, 2008 | Ricoh Aficio Colour 3006 Color Copier
Richo 1045
Probably cleaning to the mirrors and glasses inside the laser the problem can be solved, but this is a complicated work if you are not technician I recommend to him that she asks for technical service. Also a bad connection of the flat cable can cause this problem. The detector of synchronism defective also since code SC326 is a fault of detection of synchronism.
Jan 07, 2008 | Ricoh Aficio 450 Copier
1,052 people viewed this question
k24674
jasbo
jasbo
