Question about Singer 2517 Mechanical Sewing Machine
Bobbing thread is not picking up the top thread is gathering underneath the material
    Problem Solver:
  • 11 Answers
Try tightening the tension on top.
Posted on Jun 03, 2011
My Toyota 444 sewing machine. When sewing,stitches ok on right side of material but underneath,stitches are entangled. sometimes it stops sewing and I have to pull thread out.
ALWAYS RAISE the presser foot when threading the top thread. (You will need to remove the top thread from the machine and rethread from the beginning.)
For tension, start out with it set about the mid-point on the tension dial. Then tweak it from there. If top thread is showing on the bottom of the fabric, tighten the top tension. If bobbin thread is showing on the top of the fabric, loosen the top tension. It's ideal when both threads meet in the middle of the fabric.
Sep 12, 2017 | Toyota Sewing Machines
Feeder not moving
knotted up thread under the material indicates that the needle thread tension is incorrect ( needs tightening)
once you have that correct the material, will feed normally
use scrap when adjusting and the correct tension is when the top and bottom threads meet at the join ( middle -center )of the materials being sewn
Aug 09, 2014 | Elna 2007 Mechanical Sewing Machine
I am having issues with threading my machine. I have followed the instructions but every time I sew on the machine the thread on the top sews correctly but underneath the cotton gathers up. What am I doing...
If the thread is bunching under the material it is the top tension. While threading the machine be sure the foot is in the up position until you are done threading it. If you have tried that and it still bunches you need to tighten the tension a bit at a time until it starts sewing correctly. Be sure you are starting with a clean machine and that the thread is not too large for the needle ....
hope this helps.
Nov 25, 2013 | Brother LS 2160 Sewing Machine
Thread Tension
Are you using a plastic bobbin? I had that problem using plastic bobbins, Switched to metal bobbins and it solved that problem.
Also check to see if your bobbin's thread is wound tightly around it. If you can 'squeeze' the wound thread and it feels like it's not firm, the bobbin might need to be rewound.
Jun 06, 2013 | Singer 3116 Simple
The bobbin housing in singer model 9410 keeps moving out of position
After you put the bobbin case in, release it, and then pull on it to make sure it is in correctly.
The gathering is called a "bird's nest", and is caused by the machine not being threaded correctly.
Rethread the machine top and bobbin.
Then, sew a test stitch on a scrap of like material.
Apr 08, 2013 | Singer Sewing Machines
The top thread just hangs and knots on bottom of material
try changing the needle-flat side goes to the back of the machine
check to see if the thread has come off the thread take up lever
try rethreading the machine top thread & bobbin
clean under the needle plate area & also in the bobbin area for lint or loose threads
Feb 20, 2012 | Sewing Machines
Material wont feed threw bobbing gets tangeled
try rethreading the machine top & bobbin--use different thread this time
try a new needle
clean under needle plate & bobbin area for loose threads & lint
Jan 10, 2012 | Baby Lock Sewing Machines
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
JONES SEWING MACHINE PROBLEMS
We have a very old Jones Sewing Machine (1960's) we are having trouble with the thread at the moment. When we sew the thread gathers up underneath the material that we are trying to sew. Any suggestions to overcome this problem?
Feb 21, 2009 | Sewing Machines
Tension problems on light weight cotton material
Your upper tension should be set on 4, and make sure it is threaded properly, the thread is between the didc'c uf upper tension.
Dec 18, 2008 | Sewing Machines
Singer 2517 Mechanical Sewing Machine Logo
62 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
