Question about Zebra RW 420 Printer
I have Zebra MR420 mobile printer. I'm trying to pair it to PC. Following are the Bluetooth settings on printer - Address: 00:xx:xx:xxxx..... Authentication: off Ver: 2.1.18 Discoverable: on Encryption: off Mode: slave Now I do not see this printer when I try to search for it from Add to Bluetooth device option on PC. How do I pair this printer to PC or Phone.
2 Suggested Answers
  • 185 Answers
SOURCE: zebra QL320 plus no bluetooth discovery
Turn the printer up side down and remove the battery. Undo the philips screw and remove the module from the top. re-seat it back on the main PCB and replace the screw and battery. if the module still doesn't work then it is more than likely it has failed.
Posted on Apr 13, 2010
Blue tooth speaker wont turn back on.
Unable to connect to a device?
Before attempting any of the following steps, make sure that you are running the latest software version on your SoundLink Wireless Mobile speaker. Click here to visit the software update center and update your speaker. If you are still having difficulty connecting to a device after updating the software, continue to the troubleshooting steps.
Unable to connect with a previously paired device?
Please try the following to resolve this issue:
Perform a product resetTo perform a SoundLink speaker reset, following these steps:
  1. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly
  2. Press Power to turn the SoundLink speaker back on
Clear the pairing list on both the SoundLink Wireless Mobile speaker and the source
  1. On the SoundLink speaker, press and hold the Bluetooth button for approximately 10 seconds until you hear a tone. The SoundLink speaker clears all Bluetooth devices from its memory and becomes discoverable
  2. Clear the list on your Bluetooth device. For more information, please refer to the manufacturer of the device
  3. Perform a product reset. On the speaker, press and hold Mute for 10 seconds, the LEDs will flash briefly. Press Power to turn the SoundLink speaker back on
  4. Try pairing the device again by following these steps:
    1. With the Bluetooth device and the SoundLink speaker both turned on, press and hold the Bluetooth button on the speaker for three seconds to make the speaker discoverable. The Bluetooth indicator will slowly fade on and off approximately once every second to show the speaker is in discoverable mode
    2. Set your Bluetooth device to "Discoverable." This will allow your device to discover the SoundLink speaker
    3. On your device, locate the Bluetooth device list. Select "Bose SoundLink" from the list
    4. If your device asks for a passkey, enter digits 0000 and press OK. Some devices also ask you to accept the connection. Your Bluetooth device indicates when pairing is complete. The SoundLink speaker indicates pairing is complete when the Bluetooth indicator stops fading on and off and remains on
Be sure the SoundLink speaker is within 30 feet of the Bluetooth deviceThe system is designed to operate at a range of 30 feet. However, performance can be diminished by obstacles such as walls or metal, and may also be affected by other Bluetooth devices. Try moving the SoundLink speaker closer to the Bluetooth device.
Be sure the source's Bluetooth function is OnMany Bluetooth enabled devices have an option where the Bluetooth feature can be turned On or Off. This option may be set to Off to save the battery life of the device. Be sure this option is set to On. If the Bose product is paired to the Bluetooth enabled device, it should automatically reconnect when its Bluetooth function is turned on. If the Bose product doesn't automatically reconnect, manually select the Bose product within the Bluetooth list on the device.
Manually connect the SoundLink speaker in the device listSome devices will pair to a device but not automatically connect. Go to the pairing list of the device and check if this is the case. If it is, try connecting to the SoundLink speaker.
Oct 20, 2013 | Just Wireless Bluetooth Headset Wireless...
Zebra Printer zm400
You may try anyone of these option.
  • If you had this printer registered in the DNS, then its possible to obtain the IP assigned to this printer from the DNS server.
  • Earlier was the printer mapped to any print server on the network? if yes, you may obtain its IP from the print server.
  • Check the DNS cache from any PC that used to access this printer. Command to display DNS case is "ipconfig /displaydns"
Feb 08, 2012 | Office Equipment & Supplies
How do you pair the phone with bluetooth
pair the phone with another bluetooth phone by putting the same code on other bluetooth mobile setexample 0000 or 1234 or any one else but this code must be put on the other set also for pairing
0000 on mobile 1 ----------pairing----------------0000 on mobile 2 (sucessfully paired)
0000 on mobile 1------------pairing---------------1234 on mobile 2(error can't be paired)
Nov 30, 2011 | Cell Phones
I can't find the codes for bluetooth pairing.
Normally, the 'factory default' paring code for a new bluetooth device is - 0000. Try this first.
If 0000 doesn't work, then try resetting the cd player back to factory settings (contact the manufacturer for further assistance).
Nov 28, 2011 | Car Audio & Video
Ive a samsung mobile want to transfer my pictures from mobile to my pc ,laptop
You can do transfer by one of the following ways:
1. If your phone & laptop have bluetooth, activate blutooth of both your phone-pc and paired them.
2. USB cable. Make sure your phone software ( pc suite ) installed on your PC then paired them
3. Card reader. If your pictures is in your phone's memory card, you can use card reader to transfer the pictures.
Which way do you wish to choose?
Regards
Aug 10, 2011 | Cell Phones
I have my bluetooth on and have tried to receive files via bluetooth from other phones and from pc and i can pair with other device but not receive files.It says paired but not connected.Is there something...
Sometimes this happens because either you or the other person changes the pairing keys or remove your mobile from his paired list.
It can be solved by unpairing and then pairing again wwith the other device.
Go to settings in your wildfire, Wireless and network, bluetooth. Long press on the device name and select unpair. Also remove your wildfire from the other device's paired list. Then scan for bluetooth devices and pair again. This should solve this problem.
Also, when some device sends you a file via Bluetooth, there is a notification asking permission to receive file. Make sure you click on it and select accept.
May 31, 2011 | HTC Wildfire Cell Phone
I am trying to get connected on my pc through my vodafone mobile connect .Could you help how to do this
  1. Delete all the internet profiles (if any) from your mobile phone.
  2. Delete all the data accounts (if any) from your mobile phone.
  3. Send the message WWW to 52586
  4. Save the settings that you receive.
  5. Connect your PC/Laptop to the mobile phone using the Bluetooth software.
  6. In the software select the option resembling "Connect to Internet".
  7. Provide the number to dial as *99***1# and dial.
  8. You will be connected to the internet..
thanks
Apr 21, 2011 | Cell Phones
Recieving an invaild pointer address message when
try looking for bluetooth and make sure your phone is compatible with it
Jul 19, 2009 | Adapters.com Bluetooth USB Adapater, USB...
How to send photo from mobile to our computer
there are 3 ways
1.
You can use the USB data cable to transfer data between
the device and a compatible PC or a printer supporting
PictBridge. You can also use the USB data cable with
Nokia PC Suite.
To activate the device for data transfer or image
printing, connect the data cable. Confirm "USB data
cable connected. Select mode.
" and select from the
following options:
Nokia mode — to use the device for PC Suite
Printing & media — to use the device with a
PictBridge compatible printer or with your
compatible PC
Data storage — to connect to a PC that does not
have Nokia software and use the device as a data
storage device
To change the USB mode, select Menu > Settings >
Connectivity > USB data cable and the desired USB
mode.
2.
Set up a Bluetooth connection
Select Menu > Settings > Connectivity >
Bluetooth and from the following options:
Bluetooth — Select On to activate the Bluetooth
function. indicates that Bluetooth is activated.
My phone's visibility — to define how your device
is shown to other Bluetooth devices
Search for audio enhancements — to search for
compatible Bluetooth audio devices. Select the
device that you want to connect to the phone.
Active devices — to check which Bluetooth
connection is currently active
Paired devices — to search for any Bluetooth device
in range. Select New to list any Bluetooth device in
range. Select a device and Pair. Enter an agreed
Bluetooth passcode of the device (up to 16
characters) to pair the device to your device. You
must only give this passcode when you connect to
the device for the first time. Your device connects to
the other device, and you can start data transfer.
My phone's name — to set the device name for
Bluetooth connections
3. Take off you microSC memory card then read directly to your computer
cheers!
Jul 11, 2009 | Nokia 3110 Cellular Phone
Need to get bluetooth pairing code
A lot of times these are common numbers like 4 1's or 4 0's. Also can try 1234 to see if that works. Sorry so generic but I haven't worked with seiko's only zebra models
Hope it works
TankMurdock
Apr 23, 2009 | Seiko MPU-L465 Printer
Zebra RW 420  Printer Logo
187 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
