Question about Mitsubishi WD-60735 Projection Television
Replaced lamp in wd-60735 and after i plugged back in and after reboot process is complete when i hit power the green light comes on and you can hear static like tv is on an inactive channel, but after about a minute it shuts down. there is no blinking lamp light or anything and you actually have to unplug it and let it reset before you can attempt it again
  • 11 more comments
  • costaelectro May 27, 2011
    That has already been done. the green light will blink for about a minute indicating a reboot which is what should happen. just to let you know i own a tv repair shop and this is about the fourth set with this condition that has come thru my shop. although I have great confidence in my technician i think he gets frustrated with dlp sets quirkyness. his suggestion is always the same to replace with reconditioned light engine which is too expensive of a fix and customer always chooses not to repair. I am sitting on two that I hate to send to the recycler like the previous ones and i was hoping to get lucky and find a quick fix from someone who may have run across this problem. and also i'll let you know we have replaced the ballasts and tried both osram lamps and phillips lamps. its just funny because the lamp light never blinks just a steady green power light for about a minute until it shuts down and locks up. Sorry to doubt anyone but im really doubtfull anyone will be able to give me a solution on this but i will be very greatful if they can!!!!
    just received your other response and i will try that tomorrow and let you know what it does. Thanks
    Good morning I got a 66 code which according to the service manual is cause by a loose cj4 connector or bad lamp or loose hv connector between lamp and ballast all of which have been checked. the question now is where is the lamp enable signal being lost? which board? which micro? Tech said it was very hard to narrow down :(. You got you a good brain teaser now! Appreciate any advise or tips. Thanks Alex
    I got a code 66 which according to service manual indicates bad connections @ cj4 or lead between ballast and lamp or lamp itsself, which have all been checked and eliminated as possibilities. My tech says that the lamp enable signal is being lost somewhere in a micro on one of the boards but it is very hard to isolate which one it would be. hope you needed a good brain teaser! If you can take this info and see if you or anyone you know in the trade has had this problem and know an easy fix to it that would be greatly appreciated! Thanks for the effort,
    Alex
  • costaelectro May 28, 2011
    please read all the comments for this thread
  • costaelectro May 29, 2011
    Again Please read all the comments in this thread before you try to answer!!
    Please read all comments in this thread and give it another shot if you may have a an idea. Thanks, Alex
    Please read all comments posted in this thread and give it another shot!
    please read all my comments in this thread and give it another shot
    Thanks for the response I was'nt sure if it went thru or not. I actually sent it a couple of times because it didnt look as if it was going thru on my end, but anyway thanks for the clarification and I could use all the luck i can get on this one.
    Please read the entire thread and give it another shot! Thanks, Alex
  • costaelectro May 30, 2011
    Please go back and read the whole thread and give it another shot. By the way self diagnostic comes back with a 66 code but more specifics are found in the additional comments in this thread. Thanks Alex
  • costaelectro May 31, 2011
    Hello thanks for the response. Unfortunatly I cant send you a copy of the service manual but any info you could give me would be greatly appreciated. I'll also pass the last suggestions along to my tech
  • 4,889 Answers
In mitsubishi, the self-test diagnostic blinking will not be there by default. You will have to activate it by following the procedure below after you unplug and re-plug
Procedure:
After you unplug when the standby light is on, press and hold the "Menu" and "Device/Input" buttons on the front panel of the tv for about 5 seconds. The LED will flash a certain number of times, pause for a while and then blink again. Count the number of blinks before and after the pause then post it here and I will tell you whats the source of the problem.
Sai.
Posted on May 29, 2011
  • eagle338
    eagle338 May 30, 2011
    Sorry about that. Reading the comments it seems like you are not getting the Lamp Enable signal. This signal is sent out by the DMD board. When this signal occurs there will be an increase of voltage on two of the pins (where the connector from teh DMD plugs into the ballast ) for a split second before it goes off again. Its been a while since I have worked on this set so I think I am gonna need a service manual to be specific. I will try to look it up in my collection or you can just upload the one you have to a file hosting site and get me the link. I should also tell you that the LE signal will not be sent if the High Voltage generator on the ballast is malfunctioning. Measuring the input and output voltages of the ballast would be the first thing to do.
  • eagle338
    eagle338 May 31, 2011
    Ok thats all there is to test. Verify if the lamp enable signal is there or not. It goes from DMD to DM power and then to the ballast . Test the input voltage to the ballast. If the input voltage is there and the output voltage is around 320V the ballast is OK. If you get the lamp enable signal to DM power but it does not go through to ballast then DM power is faulty. If everything is normal but the output voltage of the ballast is less than 320V (upto 15v error is ok) then the ballast is faulty. I found the service manual in my collection so no problem with that
    Top Expert:
  • Mitsubishi Master
  • 73,647 Answers
Hello
System booting is not get completed. Do a system reset.
Press the SYSTEM RESET button on the
control panel
The TV will turn off and the green LED
will flash quickly for about one minute.
When the green LED stops flashing,
you may turn on the TV. The changes
you made most recently, before using
SYSTEM RESET, may be lost. Changes
you made previously, however, are
not lost.
If this does not help, try TV reset. You can had its proceedings described in its user manaul.
  • Mitsubishi Master
  • 2,098 Answers
Please Reset the tv by pressing the "System Reset Button" on the front panel with a pointed object such as pencil or paper clip.
Try again the unit. Let me know the status of the LED light (Power/timer led, Status led, Lamp led) in the front panel if still the symptoms persist.
Jdvillanueva
Posted on May 27, 2011
  • Jdvillanueva
    Jdvillanueva May 27, 2011
    You may also do the "Error Code Operational Check".
    Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational Check.
    Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
    activates the Error Code Mode. The "TIMER LED" flashes denoting a two digit Error Code.
    Note: The front panel buttons must be used, NOT those on the Remote Control.
    > The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
    > The flashing then pauses for approximately 1/2 second.
    > The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
    > The Error Code is repeated a total of 5 times.
    Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
    Let me know what the code is to assist you further...
    Jdvillanueva
  • Jdvillanueva
    Ok, bro...
  • 345 Answers
HI, Thanks for using FixYa! I need some more information. What prompted you to replace the lamp to begin with? Did it blow or did you do it because you weren't getting a picture and saw the flashing LED on the front of the TV? Also, where did you get the lamp from? Did you order it directly from Mitsubishi or did you get it from a third party online retailer? If you got it from a third party was it just a lamp or did it come with the cartridge as well and you reused the original cartridge that the lamp you replaced was in? Also, could you tell me what prompted you to reboot the television after you was replaced the lamp. That process is not normally required for a simple lamp replacement. If I get more details I should be able to help you.
Posted on May 28, 2011
  • Shawn O'Halloran
    Shawn O'Halloran May 29, 2011
    Alex, just an FYI, we don't see the entire thread as experts. For example, I only see my comments, your initial question, your responses to me and your responses to other experts comments. We don't see the comments that the other experts add until after the problem has been resolved. I know how frustrating it must seem to see people asking stupid questions over and over again or offering the same advice over and over again, but it's unfortunately a very badly designed system they have for this site.
    Now that being said, thank you for the abundance of information you provided. After all of that, it's obvious that you aren't just some guy who can't figure out why his lamp isn't working on his TV and you've gone through a lot more than just replacing a lamp. I'm not going to waste your time trying to grasp at straws without having the set in front of me and doing as your tech suggests and that is fully diagnose, investigate and isolate the problem. I don't think there's a simple fix for this at all and as noted, the big issue is going to be isolating where that problem of communication being lost is. Good luck, I hope it all works out and have a great holiday weekend! -Shawn
  • 373 Answers
Mitsubishi DLP TV's have a system restore button on the front. Use a ball point pen to press.
Green lamp light 60735 Mitsubishi
Check this out
http://www.amazon.com/Mitsubishi-WD-60735-Watt-Lamp-Replacement/dp/B005F6O0JG
Sep 03, 2014 | Televison & Video
How do i reset the lamp timer on my mitsubishi model wd-60735
Not going to fix that if the set even has that (which I doubt). Was the lamp a Mitsubishi or a generic cheap replacement?
when set goes off look to see if lamp is off or on, If you have to turn set back on or when its off, do the sets self check--press and hold both the menu and device buttons at same time for 5 second and release both---power light should blink a digit error code like 1,2, blinks pause and repeat that (1,2 is no error found and 3,7 is lamp issue.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
-- "wd-60735 lamp was replaced have sound but no
check your Lamp Fan if it stops running when Lamp trys to light ,then it is defective ,but if it is ok Ballast Board could be the problem, it is what Powers the Lamp ON.
Aug 23, 2011 | Mitsubishi WD-60735 Projection Television
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
May 18, 2011 | Mitsubishi WD-60735 Projection Television
I turned the TV on and heard a pop. I now have a black screen. Nothing works. The Timer light is green when on but not the power light
Hi:
This is an indiccation that your lamp has failed, replace the lamp and you will be good to go, If you heard a pop this was the lamp shattering in its enclosure. Just replace you lamp.
Feb 27, 2011 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi wd-60735 tv when i turn the tv on nothing comes on only hear the volume and screen just pitch black?
Did you recently replace the lamp? If you did then it might be the new lamp. I mistakenly bought an aftermarket lamp to replace mine and it would not work consistently. Apparently if it is not an Mitsubishi original lamp it has issues, because after I replaced it with a Mitsubishi lamp it worked perfectly fine.
Aug 14, 2010 | Mitsubishi WD-60735 Projection Television
I have a DLP mitsubishiWD-60735 will not power up the green light just keep flashing tried resetting the system didn't work
Replace Lamp Call Mats Electronics 1-800-628-118 or Encompass Parts for listing to all Parts for your TV 1-800-638-3328 or Go to their website.
Nov 13, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-60735 Projection Television Logo
392 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
