Question about Mongoose Sector 26 Men's Full Suspension Mountain Bike
What is the diameter on the mongoose blackcomb handlebars?
    Brigadier General:
  • 8,546 Answers
It would be stamped right on the clamp area. Loosen the stem's front face and look. That would only tell you the size of the 'bulge'. Otherwise, measure the dimension you need with a caliper.
Click on the pic of the bars.
http://www.bikeman.com/content/view/1637/115/
Posted on May 27, 2011
Raise the handle bars on my new mongoose bike
in the middle of handlebars you will see a hexadon bolt,when you got your new bike the right angle wrench should have been with it if so place the wreanch onto the bolt and turn anticlockwise this will loosen the nut,then pull the handlebars up until the wright is achived make sure they are straight then turn the wrench clockwise until it tightens,.Adrian....
Jan 23, 2015 | Mongoose Cycling
Adjust handle bars for mongoose bike
Just loosen the nut on the front of where the handlebars goes through, adjust it the way you want it, and tighten it up.
Jun 14, 2012 | Mongoose Cycling
Just bought a Mongoose Spear (26"). How do I raise the handlebars?
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
I would recommend you get used to the position that yields a careful compromise between aerodynamics and uprightness when needed.
Apr 29, 2011 | Mongoose Spear 26 Inch Men's Bike
Greeting I just purchased a Mongoose Blackcomb All Terrain Bike and I'm having problems installing the front wheel.
Unhinge the Vbrake at the front, by ushing the arms together and sliding the silver metal pipe out of it's holder. The brkes should release their tension. Undo the front bolt going through the center of the wheel with two spanners.
Don't use one spanner as it turns the opposite side and you'll be there all day.
Lift the bike up and pull the front wheel out away from the forks.
Vote for me if you think this helps you. Thanks :)
Jun 24, 2010 | Cycling
How do you adjust handlebars on mongoose fsg?
There are two ways to adjust handle bars on a bike. It's either by using a hex key at the top of the neck or loosening the octagon nut at the base of the neck near the body.
May 21, 2010 | Mongoose 20-Inch Gravity Games BMX...
Mongoose Handlebar adjustment
where the bars slide into forks there should be a allen nut on the top undo this slightly and adjust bar height then tighten up allen nut
Apr 03, 2010 | Mongoose Exile 26 Men's Full-Suspension...
2001 klf300 rear brake drum is ineffective. I
that looks like a mongoose black comb. I dont know y the brakes would not be working i have a blackcomb my self and i can ride it up or down a creek and still have breaks im not really sure what would cause the brakes to not work google it. id suggest or call the manufacture
Oct 20, 2009 | kawasaki Full Suspension Mountain Bike Men
Mongoose bmx: installing handlebars and installing detangle eqipment
The info and other good advice is on this site:http://www.bikeguide.org/how-to/brakes/brakes.php
Sep 08, 2009 | Freestyle Mongoose Bmx & Owners Manual -...
Mongoose Sector 26 Men's Full Suspension Mountain Bike Logo
181 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
