Question about Gemini Sound Products Gemini CDMP6000 Dual CDMP3 Mixing Console RS410 10 Active Loudspeakers DJ Package
I just bought the cdmp - 6000 and the cd player and usb port plays the music like its a short in my speakers. Everything is new i unpluged re-hooked up everything and still the same probloem. Please help?
  • 670 Answers
What do u mean it sounds like ****? it could be a dozen things cables loose wires, basically check n recheck everything n then just the dj stuff by itself that will narrow it down so we know what it is.
Posted on May 27, 2011
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
Help my gemini cdmp-6000 service manual
You can download the user manual for Gemini cdmp-6000 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nov 03, 2011 | Gemini Sound Products Gemini Cdmp-6000...
My cdmp-6000 always hangs and resets.... what causes it? and what maybe the possible solution?
I can give you some questions to verify possible problems:
1. Is the mixer, and ALL connected equipment powered from the SAME receptacle? If not, ground bounce can be causing damaging transients. This OFTEN requires running power back from where amps are to the mixer using an extension cord.
2. Are ALL audio interconnectsusing balanced lines where possible?
3. Is humidity 40% or greater? If not, possible static discharges from rugs, clothes, etc. may be causing transients that reset the unit.
4. Are stage lighting equipment run from a separate source to avoid transients from dimmers and switching?
5. Is the power all have three wire cords and the building have grounded receptacles?
If your system satisfies all these the next step I would suggest is a high quality power conditioner.
May 07, 2011 | Gemini Sound Products Gemini Cdmp-6000...
Hi, There is a problem on my CDMP 6000 left player pitch control. When pitch control is switched on and adjusted to +/-, it does not get set at that value but keeps fluctuating. Also, the pitch control...
You MAY have contamination in the slider.You could try putting a little CRC226 into the slot and work the control. Use ONLY this product CRC226 available at Home Depot in the electrical dept/
Apr 30, 2011 | Gemini Sound Products Gemini Cdmp-6000...
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
GEMINI CDMP 6000 5 mounth old 10 times used ( home used ) . Left unit play correct audio CD but right unit have problem with play some tracks from the same audio CD. In Macedonija ( EUROPA ) we dont have...
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
Nov 27, 2010 | Gemini Sound Products Gemini Cdmp-6000...
I just got a kaoss pad and having need help connecting to a cdmp 6000 help please
You haven't got a send and return on your cdmp 6000. What I advice you to do is the following: connect the master out, the red/white cinch, to the input of the kaoss pad. Than connect the output of the kaoss pad to your speaker system or reciever. You can now control effects on the master single.
Feb 20, 2010 | Korg Mini Kp Kaoss Pad
Gemini Sound Products Gemini CDMP6000 Dual CDMP3 Mixing Console RS410 10 Active Loudspeakers DJ Package Logo
142 people viewed this question
Top Gemini Sound Products Music Experts
Vito Vacirca Jr.
Colin Stickland
Colin Stickland
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
