Question about Dometic RM2652 Refrigerator
I have a brand new Dometic DM2652RBX. The refrigerator has been used twice. Tonight I turned it on preparing for another trip and only the freezer is getting cold. I had it on the A/C mode.
VtToolMan
  • 704 Answers
SOURCE: I have a rv dometic refrigerator model dm 2662.
Here's a link with a step-by-step troubleshooting guide that addresses your situation. Just follow the link and walk through the process and you should determine what you need to replace to get the unit working properly again.
http://gasrefrigeration.net/does_not_get_cold.htm
Hope you find this very helpful and best regards!
Posted on Aug 08, 2009
SOURCE: New Refrigerator Past Warantee Not staying cold
Thanks - according to the inside of the refrig - I do have a 5-year seal warrantee and a 1 year refrig warrantee - thanks for the tip. No noise coming from freezer or refrig.
Posted on Nov 26, 2007
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
  • 423 Answers
SOURCE: Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Posted on Aug 11, 2009
  • 24 Answers
SOURCE: dometic refrigerator Model # rm2610
Well first of all solution # 1 pertains to household refridgerators..RV models have no fan inside maybe outside,But I would find out if it gets cold/freezes with 120 volt and or LP(propane) and look trrough the internet and download your model service manual.
Posted on Aug 05, 2010
Where can i find a drip pan for a S1621 silhouette dometic rv fridge
use make and model number with brand and look in manual for it there should be a parts replacement list with phone number
May 26, 2014 | Dometic RGE400 Top Freezer Refrigerator
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
Dometic rm4223 model does not run on 12v when traveling
You could contact me and I'll buy your old broken fridge, or you could buy my brand new rm4223 that is missing parts (but the cooling unit and cabinet are brand new, never used.
Sep 08, 2013 | Dometic WA3210 Compact Refrigerator
Freezer working fine, fridge not cooling. Left to defrost last night, turned back on this morning and all seemed fine. Fridge was cooling and seemed to be running all ok. Tonight the earth leakage keeps...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Fisher and Paykel E522BRX Bottom Freezer...
Help! In 2006 I purchased a used RV with a dometic model 2408 refrigerator that did not work. After reading up on Absorption refrigerators and repair facilities I had it rebuilt by RV Mobile in Everett,...
The evaporator coil is usually located in the freezer compartment, and there are ducts with dampers that send cool air to the refrigerator. It sounds to me like that may be your problem. It seems that if you move the appliance around a little, (cleaning it and the like), then for a short period you start to get a semblance of cooling. Hope this helps
Sep 10, 2009 | Refrigerators
The freezer seems to be working fine but the
If you want a service manual for a Dometic Brand click on the link below. They are good people they will help you.
http://www.gasrefrigeration.net/dometic_manuals.htm Aug 06, 2009- If I can help you let me know, I work and talk to Dometic a lot, Thanks Sea Breeze
appliancepartsse@yahoo.com
Aug 05, 2009 | Dometic Refrigerators
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
1,165 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
