Question about Husqvarna Designer I
Have a designer 1 and the 5d embroidery .I can get the designs from the computer to the floppy, but my machine will not read them. I have done this in hus and vip sharon Habets
  • 776 Answers
The floppy disk drives are getting quite old.
They work by moving a small magnetic coil over the disk similar to the needle on a record player. The magnetic coil (known as a "read/write head") must be very close to the disk to read the data. Unfortunately, dust tends to gather under the read/write head and lifts it up away from the disk.
Option 1)
A simple thing to try is spray some "canned air" into the drive unit. This will hopefully blow the dust ball off the read/write head. Canned air is available at target, walmart and office supply stores near the electronic departments usually. When you use this method, the canned air is not really just air, and it causes the surface it is sprayed on to get cold. This can cause some condensation (liquid water) to form on the sprayed surfaces. Allow the sprayed surfaces to warm to room temperature and water to evaporate before putting your disk in. It should take less than 15 minutes. If any water is present, it will cause read/write errors and possibly damage your disk too. Take your time and try a couple of sprays. If you can get the disk drive open on the sewing machine, you might be able to simply pull the dust ball off of the read/write head. Be careful not to bend it - it is very delicate piece of sheet metal. Any bend could cause the disk to scratch. Don't be afraid to touch it, just be careful when you do touch it.
There could be other issues associated with the computer on the sewing machine, the cables from the disk drive to the computer (all inside the machine). We can get into that if needed. Let me know if the can of air cleans things out.
Posted on May 27, 2011
Replace floppy drive with USB on a Designer 1
Check with a Viking dealer whether Viking offers a conversion kit. My guess is that rather than offer such a kit, Viking would rather sell replacement floppy drives or a newer model of machine.
Dec 21, 2012 | Husqvarna Designer I
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
My D1 still runs designs from a floppy. I have the 4D software. What computer extension do I need to save my designs to, in order for the sewing machine to be able to stitch them. So far I'm having no luck...
Your Designer 1 will read none of the file formats you listed. It uses .shv which is a special file type created just for the Designer 1. Some embroidery sellers offer this format, but most do not. You don't need the .shv if you have the 4D software. When you purchase designs, you can buy almost any format you want and your software will deal with it. Most Husqvarna Designer owners purchase designs in .vp3 or .pes format. Avoid .art designs.
You need to set up your software using the Configure module. You can access this either by locating your 4D software folder on your hard drive - in that folder there should be an .exe called Configure - or use a link in your normal 4D screen once you open the program. Look for the icon along the top that looks like a screwdriver and pliers (or something like that). In Configure use the Send 1 tab to tell your software that you have a floppy disk Designer 1.
When you want to load designs for your sewing machine, open 4D Disk Manager (it will be in the drop-down Accessories box using the arrow beside the Configure button). You need to have the correctly formatted floppy disk in your computer's floppy disk drive. If you don't have one, you can format a blank one from within the Disk Manager module. Most importantly if you are using a floppy that already has been used in your Designer 1, you need to use the Read Disk icon along the top. The designs already on your floppy are read into the program. You can then add whatever designs you want by using the Open (icon showing an open manilla folder) or View (looks like a blue camera) buttons. Then you choose the Write Disk button to put not only your newly added designs on the floppy disk, but to also put back the ones that were already on it. Click "Yes" when asked if you want to erase designs already on the disk. It is quite safe provided you read the disk into Disk Manager first, as described above.
Jun 10, 2010 | Husqvarna Designer I
Viking D1 error message file not found
You need to use either Organizer or Disk Manager to put designs on the floppy disk. Both of these are Husqvarna programs, not part of your computers operating system. If you copy shv file directly, the machine does not have all of the information that it needs to read the files. If the folder containing your original shv files that you purchased contains additional files, you just need to copy EVERY file within that folder to the floppy disk and it might work. Don't attempt to move individual files to the floppy. You will need them all.
Apr 10, 2009 | Husqvarna Designer I
Husqvarna Embroidery card reader/writer
Hi - I think you have a Viking Designer 1, which has a slot for a floppy disk on the side of the machine. If so, you need to purchase embroidery software that supports file type .sv1, and you will need to buy floppy disks.
You can buy embroidery software from Viking that will allow you to write design files onto floppy disks, but you can find other embroidery software packages that support the D1 which cost quite a bit less - make sure that file type .sv1 is supported before you buy.
Viking does sell designs that come on a D1 floppy disk. You can just pop the floppy into the machine, select you design, and go. You can find Viking designs online from time to time, but before you buy, ask if a floppy is included - the newer Viking design packages come with a DVD but might not include the floppy for the D1.
Hope this helps, Ginny
If you have a Viking #1+, you won't be able to use floppy disks with your machine. Please repost and I'll tell you what to look for.
Jan 30, 2009 | Sewing Machines
Internal flopppy problem with Designer 1 embroidery machine
Dear bjdouce,
Push the floppy drive lid inwards and do the following:
First of all, check for any visible thread or dust inside the floppy drive.
Secondly clean the drive by blowing it with compressed air.
If this does not help, it is time to upgrade your machine to USB. Great to work with. Cost: plus minus $500.00.
Good Luck
Nov 15, 2008 | Husqvarna Designer I
Probel with Embroidery disc
I am pretty sure you can download Disk 100 free from the Husqvarna Viking website. This has all the embroideries that came free with the machine, plus the alphabets (I think!). You can download this direct to your PC or to a set of floppies, depending on what your Designer needs and what support software you have (or have not) got. If you have no Husqvarna software at all, your PC will not be able to read the floppy. It is in .shv format which PCs are unable to read, being an embroidery machine language only.
If you are trying to open the faulty disk in your Disk Manager software, I always found it worked better if I didn't put the disk in the floppy drive of the computer until after I had already opened Disk Manager.
Hope some of the above is useful to you.
Jun 17, 2008 | Husqvarna Designer I
Designer 1 embroidery problem
If the machine is reading the file to not be found it is probably that the designs are on the floppy but the person sending did not read them to the floppy right. they should have been read thru the softwear.
Dec 28, 2007 | Husqvarna Viking 1
Embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Dec 18, 2007 | Husqvarna Viking 1
Sewing Machines Logo
71 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
