Question about Vacuums
I bought this machine about 3 years ago but hadn't used it due to illness. Now when I tried to sew with the Tuff Sew ,the threads continually break. If I can make about a 3 inch line of staight stitches without the top thread breaking,I consider myself fortunate The direction in the manual are extremely poor. I had to finish my project with my very old Bernina. I regret buying the Tuff Sew straight stitch. JLWebb
  • nextbabe Jun 01, 2011
    I just purchased the #69 nylon bonded thread. I haven't had a chance to install it on my machine yet. I will let you know if it solves the problem. Thanks again. JLWebb
  • 776 Answers
I do not have one but these machines require heavy duty thread...
The manufacture recommends using only "#69 Bonded Nylon Thread"
You should have a 18 to 20 gauge needle for that size thread. Needle type is 135x17
To be completely honest, these machines look like they are 20 to 30-year-old designs meant to be "store branded" machines (Woolworth, K-mart, Sears, ...). As demand at these types of stores dried up, they may have tried (successfully) to remarket them as "tuff" machines. Almost all older machines used all metal gears - it doesn't make them tough or high quality. The poor level of technical support and documentation would upset me too.
I really hope the recommended thread and needle help with your problem.
Good luck.
Posted on May 27, 2011
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I have needles snapping and bobbin tangle
Try to repair in this order.
1) Your machine likely needs oil. Especially put a few drops of oil on the outside edge of your bobbin holder.
2) Try replacing your needle if you have some spares. If you are using a decorative thread (metalized) use a needle with a teflon lining on the eye (called metallic thread needle).
3) Try buying a better quality thread. Do not use generic thread in a sewing machine (i.e. "made in cheap country" with no brand name)
Please rate me..
May 04, 2011 | Vacuums
I do not have a manual and can thread for needles but the two other threads are a mysteryonce I get to the last bit the machine cuts but does not sew therefore I cannot be doing the threading properly...
First, you can search for a manual for your machine by searching with the make, model number, and the word manual. Like "Elna 6003 manual", and chances are you can at very least find a paper one to buy, but often now you can find free downloads in pdf format.
Then, most machines require that the needle be put in with the flat side to the back. If you're doing that, then check that you're threading from front to back. I can't remember about the one machine I used years ago that threaded from side to side, but it was probably the same, with the thread going from the rounded side of the needle to the flat side. But first, try searching for a manual. And are you using cheap thread? It's not worth the time it takes to thread the machine. Get at least Coats and Clark general purpose thread, if not something better.
Feb 28, 2011 | Vacuums
I have the brother Ls-2000 sewing machine i threaded the top as well as the bobbin but when i try to sew the thread gets stuck and it bunches up and tangles in the bobbin. also the little bit that did sew...
adjust your tension.You probably did not wind your bobbin properly as well.Make sure you oil your machine every month or so and make sure your bobbin is seated properly before you sew.
Go slower with the pressure foot speed and use the right needle.ALWAYS test on scrap of your sewing material first!!!
I have this machine for like 2 years and can do 2-5oz cowhide and buffalo leather on it (no joke, and it works FLAWLESSLY) inside it has full steel construction,just needs regular oiling compared to pro machines and easily made a few grand $$$ with it while my pro machine is getting repaired (I don't even bother with my pro machine anymore) But you MUST oil it every month and use the RIGHT needle and adjust your tension properly
Also pull out the thread a good 6 inches from the needle and bobbin before dropping the pressure foot and sewing.
Best $70 bucks (WITH TAX) I spent hell,the leather I use costs more than the machine!
Jan 12, 2011 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
Vacuums Logo
35 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
