Question about Vacuums
Hi there. i am looking for the manual for the juki HZL F300. I lost mine and cant figure out how to get a zigzag stretch stitch to work
  • 300 Answers
I could only find this, but there may be others.
Details: Juki HZL-F300 Sewing Machine Instruction Manual - Photocopied Version
http://www.sewingpartsonline.com/juki-hzl-f300-manual.aspx
Posted on May 27, 2011
When in the center needle position is selected, the needle is not centered, it is left of center. When the right needle position is selected, the needle sits only slightly to the right of center. How can...
Make sure machine is set for regular zigzag stitch and not a fancy zigzag stitch, and rotate it by hand at least two full revolutions in the normal direction of rotation to make sure it is settled in to the regular zigzag stitch. Now set the stitch width to maximum width and slowly rotate it by hand, watching the needle. Does the needle strike the top of the foot at the extreme left or right? (and this is the slotted zigzag foot, right?) If not, you are good to go. If the needle does hit the top of the foot squarely, do make sure that the foot is mounted correctly and change the needle, making sure it is the correct size and that it is inserted all the way and facing the right direction. It is somewhat unlikely that the left to right position of the needle bar needs adjusting.
Sep 09, 2011 | Vacuums
Hello, i have a bernina 930 that i just purchased. it does the straight stitch perfectly but when i try to do zigzag or decorative stitches it just moves the needle while in up position and goes back to...
I understand that you are not yet sure of what you are looking at this point, but don't worry I have a wonderful link that is very helpful. This link will help you what if what you are looking for or answer to your issue.
Please just click HERE so that you will be directed to the exact site.
Once you get there, you will see lots of links awaits. Thanks.
Aug 06, 2011 | Vacuums
HAVING A PROBLEM WITH MACHINE JAMMING UP AROUND BOBBIN AREA WHEN TRYING TO FREEHAND EMBROIDER IT STARTS OFF OK THEN QUICKLY JAMS UP HAVE ADJUSTED THE FOOTPLATE SO THERE ARE NO TEETH
Check your tension first by sewing a wide zig zag stitch. Does the top of the stitch and the bottom look identical? The sides of the stitch should look like a hole where the thread disappears to the other side, with no extra thread from the other side coming through. It also should lie flat and not be puckering in the middle. When it looks identical and no puckering the tension is correct. Use the same type of material and thread you will be using for the embordery. The bottom side of the stitch is effected by the TOP tension. The top side of the stitch by the BOTTOM tension.
Are you stretching the material you're hand embordering with a hoop?
The dog feed needs to be totally down and if your machine has an adjustment the tension on the foot should be lessened too. (not all machines allow for that adjustment).
Last but not least make sure you have the right needle for the job and material.
Jamming up in the bobbin area would most likely be from the top tension being too loose but also make sure the material isn't getting pulled down in by stretching it with an embordery hoop. Do use a presser foot... a wide clear one is best.
Apr 26, 2011 | Vacuums
Janome 6600 sewing machine. bobbin thread is gumming up underneath on a swimsuit knit type material (4 layers). Brand new machine had 1 1/2 weeks. Sometimes material goes down into the bobbin area jammed...
Make sure you're using a polyester thread (I use maxilock serger thread) then a stretch needle, and hold the tails of your thread until you get started into the seam so the fabric cannot push down into the opening on the throat plate.
Also, a small zigzag stitch (about 1.8 - 2.0 wide) is good to use on lycra as that will allow the fabric to stretch after the garment is made.
This is stuff I've used with my 6500P and other previous Janome machines in making Ice Skating outfits.
Oct 17, 2010 | Vacuums
How to change my vacuums belt
If you can't stretch it for enough get a bigger one and cut the bigger belt to where you want it.
May 19, 2010 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
163 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
