Question about Minn Kota MinnKota MK2DC Dual Bank DC Alternator Charger ()
I have a Minn Kota MK220. I am charging two gel batteries for the first time in a year. I have checked and cleaned the connections, the fuses are good but the "check connections" light is on for both batteries. Any ideas?
5 Suggested Answers
  • 157 Answers
SOURCE: minn kota problem
Hello Jim. You have lost your power some where. Start with the wire & terminal connections to the battery. Open the bottom of the foot pedal and check the wiring connections there. Note be very careful here for you have the battery still connected. You may have a fuse in line some where blown. You can check for voltage with a VOM(volt meter) on the wire terminals. Good Luck.
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: year made MKAD2674059 minn kota
According to: http://www.northlandmarine.com/MinnKotaMotorControlBoardAssm.htm
*Note: Newer model trolling motors have serial numbers beginning with the two-letter prefix MK (Minn Kota), followed by a two-letter year code. MKAB .......... 2001
MKAC .......... 2002
MKAD .......... 2003
MKAE .......... 2004
MKAF .......... 2005 MKAG .......... 2006
MKAH .......... 2007
MKAI ............ 2008
MKAJ ........... 2009
MKBA .......... 2010 A serial number with the designation MKAB denotes a
2001-motor and MKBA would be a 2010-year model
Posted on Jun 13, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
What is amp. draw of minn kota 40pd? thanks
Digital Maximizerâ„¢
Digital Maximizerâ„¢. Up to five times longer run time on a single charge.
Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
Pioneered in 1985, Minn Kotas innovative Maximizerâ„¢ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
your manual is here and states it has a battery level meter.
http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
Minn Kota Motors
Jan 06, 2016 | Minn Kota Boating
Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
ONLY THE check connection light comes on. There is
I am having the same issue with My Mk 210 charger and have tried contacting Minn Kota two times for help? Have you had any luck finding the solution ?
Jul 27, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Feb 27, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Minn kota problem
Same deal with mine, was using it with no problems until I turned up the trust alittle and it just quit, never turned back on nor did the circuit breaker pop. Talked to Minn Kota thy said the board might be fried as well. So took it to a authorized dealer. I had 2 issues (only minor with the motor) Easy fix for mine was under the button on the foot pedal is a small round magnet about half the size of a pencil in diameter or so. The tech said it got recessed down to far and if it should happen again just pull it up again. So took it back home re-installed and no luck, just heard a tiny ticking noise from the foot pedal, no prop movement. SO I checked the batteeries, all good. Even though the connectons had very minor corrosion I decided to disconnect all and clean them. Re-connected them and now I am back in business. Dont understand it, but hey it works until I actually test it out on the lake. Hope it helped
Sep 29, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota MinnKota MK2DC Dual Bank DC Alternator Charger () Logo
201 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
