Question about Dryers
I have a Kenmore 700 series electric dryer. Still runs but no heat. I have cleaned the lint catch out and have air flow to the outside. I changed my breaker out and that is not it either. Today I got a new Thermal cut-off fuse and high limit thermostat, put the new ones in and still nothing. The dryer is only about 3 yrs old. I have already replaced the timer on it as well. Any ideas would be outstanding. To try to help me out. Thanks!
  • Dryers Master
  • 7,482 Answers
Hi g dolden...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please take time to rate me
Posted on May 27, 2011
    Genius:
  • 1,140 Answers
Have you checked the heater element itself?
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
My bosh next 700 series I not heating to dry the clothes I checked the vent and it not clogged inside and outside. Help pls
Try to reset the thermal cutoff, but should be no reason why it should have tripped.
The actual operating procedure is
The air enters the body of the dryer through the large opening in front of the dryer
Then the air is sucked past the heating element and into the tumbler. (the tumbler is the large bin holding your clothes).
Then after the air has circulated around the clothes, it enters the door and is directed down through the lint screen. (this catches lint from the drying process... some clothes producte more lint (such as towels) than others (such as panties) because the weave is more coarse.
Then the air passes through a duct in the front of the dryer (after the lint filter) and into the fan.
The fan forces the air into the duct leading out the back of the dryer, at which point it exits your house.
It is extremely difficult to tell you the problem without being there to eliminate any one of several things that could be the problem. First, when you have the dryer turned on and have the heat setting set to cottons, is there ANY heat at all? If you feel the door, and there is SOME heat but there is not much heat on the clothes when you feel them, the intake opening in front of the dryer is probably in need of cleaning.
While you should always clean your lint filter after each use of your dryer, you should also periodically clean the intake at least once every six months. If you do not, the air intake is eventually restricted and the drying efficiency of the drye is affected. Consult your owner's manual for the exact location of the air intake.
IF THE INTAKE IS CLEAN and clear of obstruction, and there is still not enough heat to dry the clothes, but the door feels warm when dryer is operating. Then this would imply that the exhaust duct needs cleaned out. This is something that definitely needs done periodically to prevent fire. The exhaust duct collects additional lint that the lint filter misses. While this is a small amount of lint, over a period of time, this builds up on the inside of the exhaust duct and prevents the flow of the exhaust which reduces the heated air flow around the clothes in the tumbler. This results in the air not flowing and not becoming warm enough to dry the clothes efficiently.
IF THERE IS NO HEAT AT ALL: Then there is a likelihood that the heater itself needs replacement. This is a costly repair and you will be wise to invest in another dryer instead.
The working process of your clothes dryer is a relatively simple machine. It brings in air, heats the air, flows the air through the tumber where the clothes tumble loosely with the heated air circulating around them, then the air passes through the lint filter as it exits out your home. The lint filter is necessary because those tiny pieces of fabric (lint) can collect in your exhaust duct and catch fire. This is the major cause of dryer fires. This is why you should also periodically clean out your exhaust duct. Even though you have a lint filter, the lint filter does NOT catch all the lint and lint will eventually coat the interior walls of the exhaust duct.
Apr 20, 2012 | Bosch Dryers
Kenmore dryer will only work on no heat cycle...any other heat cycle will give pf code. md number 417.84092500
The Kenmore H5T is an electric clothes dryer meant for residential use and manufactured by the Kenmore Company, which manufactures a wide variety of appliances for the home, including refrigerators, dishwashers, microwaves, stoves, and clothes washers and dryers. While most Kenmore clothes dryers work well with only basic care and maintenance, certain problems, such as the dryer not heating, occasionally occur. Troubleshooting this issue may solve the problem without the help of a service technician.
instruction
  • Ensure that the dryer is properly connected to a working grounded power supply. Confirm that the power cord is plugged firmly into the dryer and the power outlet. Reset household fuses or circuit breakers if necessary.
  • 2 Remove the lint screen from the bottom front of the dryer. Pull off all lint so that the filter screen is clean, and replace the lint screen in the dryer.
  • Run the dryer for 5 minutes on a normal cycle and hold your hand under the outside exhaust hood to feel for air movement. If there is no air movement, turn off the dryer and unplug the unit. Disconnect the exhaust vent and clean out any possible obstructions, such as excess lint. Reconnect and confirm that the vent is not kinked or crushed and preventing proper heated air flow.
  • Ensure the dryer is not in a room or outside with ambient temperatures below 45 degrees Fahrenheit. The dryer will be unable to heat properly if the ambient temperature is too low.
  • Avoid overloading the dryer with too many clothes, which will limit proper heat and air flow in the dryer. Make sure the dryer is not set on an "Air Only" dry cycle, which does not provide heat.
  • Contact an authorized service technician if the preceding steps do not resolve the problem.
  • Dec 20, 2010 | Kenmore Dryers
    My fridgidaire dryer model FDR336RDS2 seems to run too hot
    Over heating in a dryer is almost always due to an air flow problem. Typically it is in the venting.
    - Check the vent from the dryer to the wall by removing it and cleaning out, make sure there are no kinks or tears in it.
    - Run the dryer once it is connected and feel outside to see if you are getting the same airflow outside as you can at the outlet of the dryer, if the air flow feels weaker outside your vent is restricted and you need to have it cleaned.
    - If these are ok check your lint filter, softener residue can plug up the screen so air has trouble flowing trough it, you can wash it out with a brush and hot water
    - With the lint screen out take a flashlight and look down the chute, if you see lint in there take a brush and vacuum and clean good
    Apr 22, 2010 | Frigidaire GLER341A Electric Dryer
    Wont heat at all
    On top of the element is a limit that blows if the venting or ductwork is clogged from fluff. I have a few repair photos HERE
    Feb 10, 2010 | Kenmore 62602 Electric Dryer
    Dryer stops after about 10 minutes. can be re-started but stops again and again. Thermostat was replaced about two months ago.
    the motor could be overheating,you might need a clean out on the dryer?vac out the inside where the motor is,clean out the duct where the lint filter slides into and then go outside and make sure the air is blowing out with force,i've been finding alot of cages outside that stop animals from crawling into the vent line but the cage also catches lint and stops the air flow,if so take the cage off or clean it every month,if you have a long run blow out the vent line with a leaf blower,you could also have a bad motor
    Jan 19, 2010 | Dryers
    Kenmore series 90 electric dryer: exhaust air is
    that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
    Dec 18, 2009 | Kenmore Dryers
    I have a Kenmore Series 600 electric dryer and it takes forever to dry clothes. Over an hour for a regular load. There is no way this can be right. Is this a common problem with this model.
    This is likely the result of an air flow problem if you are sure the heater is working properly. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
    If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
    Having performed all these actions will likely resolve the problem.
    Oct 31, 2009 | Kenmore Dryers
    My Kenmore Series 400 dryer spins & heats, but the clothes stay wet. I've cleaned the lint basket & have checked the vent from dryer to outside. Any suggestions?
    Check the outside vent again while the dryer is running. There should be a good strong air flow, if not then your problem is in the exhaust system somewhere
    Jun 21, 2009 | Kenmore 73952 Gas Dryer
    Kenmore 400 Series electric takes ver long time to dry.
    Very common problem. You need to call a
    duct cleaning company and tell them to clean
    your dryer vent. Rule-of-thumb: dryer vents
    should be cleaned every couple of years to
    prevent them from being clogged with lint and
    causing lint fires. This is definitely your problem. Good luck :)
    p.s. one way to verify a clogged vent is
    to go outside where the vent exits the house
    and feel the air-flow. should have adequate air-flow.
    Mar 09, 2009 | Kenmore 73952 Gas Dryer
    Dryers Logo
    150 people viewed this question
    Top Dryers Experts
