Question about Dishwashers
KItchenaid Dishwasher stuck on clean cycle, will not advance
captaynkyrk
  • 170 Answers
SOURCE: KITCHENAID DISHWASHER NOT CLEANING PROPERLY;
there's a filter at the bottom of the inside of the washer. remove the rack and spray arm and you can get to the filter and clean it out. once cleaned you will notice a difference after each cycle.
Posted on Jul 07, 2008
bigg t
  • 640 Answers
SOURCE: Loud Squeal: Clean and Rinse Cycles
Just on a whim i would say the bearings in the motor are worn.Any leaks?It's also possible that some broken glass went through the screen and into the pump motor if any glass has been broken.
Posted on Apr 09, 2009
  • 120 Answers
SOURCE: My Kitchenaid dishwasher seems to be stuck on the
check to see if you don't have it on an extended wash cycle setting. After that, check to see if the dial is stuck.
Posted on Oct 05, 2009
Macmarkus
  • 2605 Answers
SOURCE: Dishwasher stuck on wash cycle
Based on your description I'd say the issue is with the control. Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described. Heck if you called me with this description I'd be happy to bring you a new control and have a first time complete. ( unless you requested a re-solder option...see below re: my opinion on this )
I digress,
As I've alluded to the issue is within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch servicer if that is an option for you and your budget however, If you cannot afford that option or feel capable of checking this on your own, there`s a way to visually inspect the control yourself. It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board. This will be one of the pins from the heater relay, hence the unit sit`s and takes forever to finish and eventually display's the "1" error ( on models with a display ) because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "fixya" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
macmarkus :)
Posted on Apr 14, 2010
heatman101
  • 43501 Answers
SOURCE: Our kitchenaid dishwasher is not cleaning well
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Posted on Jun 01, 2010
Kitchenaid dishwasher stuck on wash cycle
I'd you wish to get some details then check the following link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | KitchenAid Dishwashers
How do I reprogram the start, rinse cycles? snowflake is blinking and nothing happens when I try to start washing.
[PDF]Download Bosch Dishwasher-Manual - DASH Property ...
www.dashpropertymanagement.com/.../Bosch-Dishwasher-Manual.pdf
Lift tab to open the rinse aid reservoir and add -3 tablespoon max, do not overfill. "qUid rinse aid ... Cancelling a cycle I Reset the dishwasher. 0 LEDs flashing ...
[PDF]Dishwasher Use & Care Guide EIDW6105G - Datatail
media.datatail.com/docs/manual/40243_en.pdf
We view your purchase as the beginning of a relationship. ... Store dishwasherdetergent and rinse agents .... This cycle allows you to program your preferred.
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
https://www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR
KITCHENAID DISHWASHER REBOOT ... Dishwasher Repair will not start - Repair & Diagnostc - Kitchenaid - Whirlpool ... What toDo When the Dishwasher Won't Start - Duration: 5:43. by doityourselfstan 217,315 views. 5:43 ... KitchenAid & WhirlpoolDishwasher - Not Cleaning ,pump wash arm impeller ...
Dec 16, 2015 | Dishwashers
Broken Timer? My OLD Kitchen Aid Quiet Scrub Dishwasher no longer advances through cycles automatically--I have to turn the knob manually for every step. It works fine other than that.
Hi Spring
All depends where you are and wether you can get Parts.
Is the timer accessible?
Timer is driven by a small clock motor.
Could it be fixed or lubricated.
Give it a service and save money!
Good luck
Free Online KITCHENAID DISHWASHER Repair Manual
http://www.diytroubleshooting.com/kitchenaid-dishwasher-troubleshooting
Jul 08, 2015 | KitchenAid Dishwashers
KITCHENAID DISHWASHER STUCK IN WASH CYCLE
It can be the issue with defective float switch. The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. One more thing, if your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jan 16, 2013 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchenaid dishwasher #KUD524SEBLO will fill with water but not run wash cycle. suggestions?
Check this possible causes:
Water-heating cycle
heat,wash,rinse you must check the 3 types. one of them can be the problem, most of the time when water reach the level of heating work o.k , you must troubleshooting the heating elements.
Timer
often fail, in some cycle, they stuck, try to clean the contacts, tight the wires very well, or replace.
sincerely. God bless you
May 05, 2012 | KitchenAid Dishwashers
My Kitchenaid dishwasher seems to be stuck on the wash cycle for over an hour. How to I fix this?
Oct 05, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid Superba Dishwasher clogged or jammed with broken glass
You will probably have to get at it from the bottom, possibly the back of the washer. Here is a link to your repair manual.
http://kitchen.manualsonline.com/manuals/mfg/kitchenaid/kitchenaid_dishwasher_product_list.html
Feb 02, 2009 | KitchenAid KUDS01DJ - Multiple Color...
Kitchen aid dishwasher
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Sep 01, 2008 | KitchenAid KUDMO1FK - Multiple Color...
Dishwashers Logo
309 people viewed this question
Top Dishwashers Experts
