Question about Lanzar SD34MIP Car Video Player
I have a Lanzar SD34MIP and the front LCD no longer displays any characters (for example what radio station you are on). It shows a gray backlight but nothing else. Other than this, the unit plays CD and DVDs and even radio if I can find a station. Do I need to replace the front unit with the LCD? Thanks for the help,
    Problem Solver:
  • 45 Answers
MOST LIKELY YOUR RIBBON CABLE IS STARTING TO BREAK. GO ON EBAY AND SEARCH FOR RIBBON CABLE IN PARTS AND ACCESSORIES
Posted on May 27, 2011
  • dprince77 May 27, 2011
    Thanks for your suggestion. There is no ribbon cable connecting the removeable front piece. It just has contacts on the main unit and front piece which contains the LCD. I did try to clean the contacts but it did not make a difference; however perhaps the contact is the issue although everythings else on the front seems to work except the LCD not displaying any image.
My lcd display is dim on my sony xdr-ds12ip dab radio, you can see the display faintly and it does search and display the time. Also the backlight is working normally.
The backlight allows you to see the display. The LCD display only allows the backlight to shine through and produce the characters. Try looking at the display from a different angle as the light is polarized.
Jan 29, 2015 | Sony Computers & Internet
Display
Hook a spare monitor to the video output usually on the back, if picture okay! the inverter board located under the screen is defective, or the backlight behind the display has failed. But if both show the same symptoms it means the video graphics card is faulty, normally built into the motherboard.
Apr 15, 2012 | Computers & Internet
Hp g5000 sreen does not light up as usal, i can see a the start up when i shine a torch at the sreen, what do i need to do to get working.
An LCD screen cannot produce enough light by itself. It needs an additional source of light.
A Backlight is used as the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to the Fluorescent lighting used in homes and businesses, but on a MUCH smaller scale.
The LCD screen is a composite of layers, surrounded by a thin metal frame that resembles a picture frame.
To one side of the LCD screen layers, and under the frame is usually where the Backlight is mounted.
[Note* Two Backlights are used in some models]
Replacing a Backlight is more labor intensive than replacing an Inverter.
Due to this, and the cost, the LCD screen itself is replaced as a unit most of the time, when it comes to Backlight replacement.
Example of a replacement LCD screen for the HP G5000 series of Notebook PC's,
https://www.screentekinc.com/HP_G5000_Series--15.4-inch--1280x800-wxga-laptop-lcd-screen.shtml
[Note* Stating HP G5000 is just stating the model series. When buying replacement parts the EXACT Model Number should be used. This information is located on the bottom of the laptop, in a white Service Tag.
When replacing an LCD screen, the model number of the replacement LCD screen should be matched to the existing LCD screen's Model Number.
Inverters and LCD screens are matched together. Make sure you get the correct part]
An Inverter is used to provide power from the laptop to the LCD screen, and to the Backlight.
Note* 90 Percent of the time the problem is a bad Inverter.
Example of an Inverter for an HP G5000 series notebook PC,
http://www.zlectronic.com/product/INVERTER-FOR-HP-DAC-07B035-DAC-09B017-DV5000-G5000.html
The LCD screen, Top Cover, Display Bezel, Inverter, Backlight, and various screws, make up the Display Assembly.
The Display Bezel made of plastic surrounding the LCD screen, and in front of the LCD screen is removable.
Behind it is easy access to the Inverter.
The Inverter is approximately 4 inches long, and the width of a No.1 pencil.
Usually located at the bottom of the LCD screen, and right behind the Bezel.
This article shows replacing an Inverter and LCD screen on a Compaq Presario v2000 series Notebook PC,
http://www.insidemylaptop.com/replace-lcd-screen-inverter-compaq-presario-v2000-laptop/
This pictorial guide is not for the HP G5000 series Notebook PC, but the models are very similar when it comes to Inverter replacement.
The above link is to show you what is involved.
Please post questions in a Comment.
Regards,
joecoolvette
Apr 03, 2011 | Computers & Internet
I can no longer see anything on the screen!
Did you try pressing the DISP or DISPLAY button on the back of your camera (manually turns the screen on and off)? If that doesn't correct the problem, then the problem is likely a loose connection of either the flex cable to your LCD screen, or the power cable to the LCD backlight. In that case you'll need to reseat them to make sure that they're making a good connection. Here's an example repair of an LCD that shows how to get in there. The red circled items are what need to be checked and reseated for a better connection.
Apr 18, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
Nov 12, 2009 | 2009 Ford Escape Hybrid
Installing the Lanzar SD34MIP stereo
ground the emergency brake wire, I forget the color. This is all you have to do.
Feb 01, 2009 | Lanzar (SVD59EL) DVD/VCD/CD/WMA/MP3 Player...
Radio lights no longer work, does not show the station etc...
Internal bulb has failed. there is no fuse to replace yourself.
A good electronics repair shop should get you back on track for about $20USD.
(mostly labor)
Jan 15, 2009 | 2004 Ford Thunderbird
Nokia 6133 LCD Replacement Trouble
my guess is that you messed with something while you were prying it open.
I have the nokia 6126 (very similar) with a broken screen but i get it open, could you help me with that
Feb 14, 2008 | Nokia 6133 Cellular Phone
No light in display
When the display is out? Does the backlight ever come on? If so, then there is no way to change this. If the backlight doesn't come on, contact Bose for service.
Feb 12, 2008 | Bose Acoustic Wave music system II -...
Volume, Display and FM stations missing?
This could be a bad ground on the radio, or you have serious circuit problems. if a fuse blew, the radio would not work at all. Check the installation first, replace the radio seconds. Good Luck
Jul 29, 2007 | Sony CDX-L420V CD Player
Lanzar SD34MIP Car Video Player Logo
90 people viewed this question
Top Lanzar Car Audio & Video Experts
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
