Question about Mag Innovision LT917S 19 inch Monitor
Mag Innovision LT917S i need windows 7 32 bit drivers, i am stuck with 256 bit color and i cant use the pc.
  • Ben Beharrell May 27, 2011
    I assume that uses VGA connection to plug into the computer? (the one with all the pins)
    You will most likely need a driver for your video card. If you don't know where to find your video card make and model, check here:http://www.playtool.com/pages/findspecs/...
    Or here:
    http://www.wikihow.com/Find-Video-Card-S...
5 Suggested Answers
  • 50 Answers
SOURCE: need driver and users manual for mag innovision lt576c monitor
Download updated drivers and manual from Mag website link here: http://www.maginnovision.com/Support/Downloads.aspx where you select product group, type and model.
Posted on May 25, 2008
shaggyrat
  • 1224 Answers
SOURCE: need a driver and users manual for mag innovisionLT576s
42905439-177x150-0-0_.jpg ViewSonic (HASU05F) Information: Product details Price Range: $25.00 - $40.00 at 3 stores This AC Adapter is ideal for use with your Flat Panel Monitor or LCD Display. The High performance AC Power Adapter pictured here provides consistent and continuous power at the specified Voltage and more
this is what else u need to power the monitor it is plug and play compatible
make sure your video card has the right software to run monitor
Where can I get drivers for my video cards?
Answer ATI – http://www.atitech.com/
Nvidia - http://www.nvidia.com/
Matrox – http://www.matrox.com/
Pinnacle – http://www.tridentmicro.com/
Trident - http://www.tridentmicro.com/
Diamond Multimedia – http://www.diamondmm.com/
Cirrus Logic - http://www.cirrus.com/en/
http://www.opendrivers.com/driver/214283/mag-lcd-monitor-drivers-windows-95-98-2000-xp-me-nt-free-download.html
heres the driver that you needed for your monitor
I can’t find where the AC power cord plugs in on the back of the monitor. Answer There are two places where the AC connector could be found.
1. Look at the back of the monitor right next to the signal cable connection.
2. If the signal cable does not detach from the monitor, follow the signal cable to the end, and you will see the 15 pin D-Sub connector (blue connector). There you will find a small hole with a pin inside (in between the two notches).
Posted on May 26, 2008
CosmaP
  • 409 Answers
SOURCE: Mag Innovision LT917s 19 inch monitor- On and Off !!
Replace it.  It would probably cost more to get it repaired.
Posted on May 28, 2009
lserni
  • 466 Answers
SOURCE: mag innovision 786n winxp driver download
DriverGuide.com claims that the driver is available here
http://members.driverguide.com/driver/detail.php?driverid=489569
for US$2,99.
There is an "universal driver" also here:
http://www.edriverdownload.com/driver/MAG%20InnoVision%20/MAG%20InnoVision%20all%20crt%20models%20Driver.html
Posted on Oct 22, 2009
My monitor gives 16-bit color at 640x480, but will only offer 256 colors at 1024x768 -- and only displays 16 colors when I select that... In order to access resolution options, I have to go into Advanced...
The monitor has no influence here - something is wrong with your video card: either its driver is missing (or corrupted) or the video chip has failed.
Uninstall all the drivers for the video(except the generic VGA one), from Programs and Device Manager
http://pcsupport.about.com/od/windows7/f/open-device-manager-windows-7.htm
and reboot several times then go to Dell
http://support.dell.com/support/downloads/index.aspx?c=us&cs=19&l=en&s=dhs
select your pc and get the correct driver.
If that doesn't fixes it then the video chip has failed, you will need to buy a new video card.
Aug 02, 2011 | Dell Dimension 4600 PC Desktop
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
OR
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
Or
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
Mag innovision 786n winxp driver download
for US$2,99.
Oct 22, 2009 | Mag Innovision Computers & Internet
May 28, 2009 | Mag Innovision LT917S 19 inch Monitor
Monitor resolution (slider) stuck on 4 bit color setting . . .
I would go to http://support.gateway.com/support/default.aspx input your model and os then dload and install drivers for the motherboard.This should fix the problem.
Thanks for posting and please rate
Sean
Mar 16, 2009 | Computers & Internet
I have a mag inndvision moniter i need diver
windows 98 will not have any drivers for video , monitors
don't need drivers
upgrade windows
Aug 01, 2017 | Mag Innovision M572TVs LCD Television
Need driver and users manual for mag innovision lt576c monitor
May 25, 2008 | Mag Innovision LT576s 15" Flat Panel LCD...
Open Questions:
Mag Innovision LT917S  19 inch Monitor Logo
186 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Jaime Hernandez
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
