Question about Conair Weight Watchers WW35 Body Fat Glass Electronic Scale
WW45 scale gives Err message after the tap instead of the 0.0 so that I can weigh I just replaced the battery as it was doing nothing after the tap before. I have owned this scale about 3 months
fitnessbalan
  • 59 Answers
SOURCE: My scale came up with an error message of ErrL
here is the contact information for conair
http://www.conair.com/-cn-18.html
Posted on Mar 21, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
  • 3 Answers
SOURCE: err 4
Sounds like it wasn't initialized, even though it says Er 4 instead of Er 0... According to my manual, to (re)initialize it and reset it to zero, tap the platform lightly. It should show zeroes running across the display for a second or two, then show all zeroes and turn off. It should be re-initialized...
Error Codes for the 5757 (according to my manual):
Er 0 Initialization error (remedy described above)
Er 1 Instability error (step off the scale, then back on)
Er 2 Overload warning (registering weight beyond the 440 pound max)
Er 3 Contact error (body impedance beyond technical limit - try dampening feet and try again for better contact)
Er 4 Bodyfat error (bodyfat percentage is beyond range - try dampening feet and try again for better contact)
Er 5 Bodywater error (bodywater percentage is beyond range - try dampening feet and try again for better contact)
Posted on Oct 17, 2009
  • 10865 Answers
SOURCE: My weight watchers scale keep giving me the
Change the batteries. J.
Posted on Jun 15, 2010
SOURCE: scale wont reset bfm788dq-63 health o meter
There are lots of links which may help you but according to me http://www.dictone.com help more
Posted on Jul 02, 2010
Why do I just get an ERR message when I try to weigh myself?
The replacement batteries could be of the wrong type, defective, or incorrectly installed.
Oct 02, 2015 | Conair WW60 Weightwatchers Scale
Health O Meter digital scale, model HDR743DQ1-41, reads "EE". What should I do?
The more recent models don't have to be tapped before getting on,if its an older one, the message might mean you took too long or weigh more than the capacity,usually 300,or 330lbs for a digital scale although some go to 400lbs or more. Try switching the battery for a new alkaline or lithium one;digital scales often need more power than a common cell can provide.
Jun 28, 2013 | Health & Beauty
My WW78 scale keeps giving an ERR message when I stand on it.
Usually I change the weight by weighing one foot and then weighing again with both. And then I keep repeating that until my results are consistent. Then that result seems to be accurate
Feb 19, 2012 | Conair Weight Watchers® WW78 by Glass...
Keeps showing err. Thinner scale
Tap the scale twice with your foot so 0.0 appears first, then weigh yourself. If you step on the scale before 0.0 appears, the scale will not function properly.
Sep 26, 2010 | Conair Thinner Scale by TH304 Glass Body...
Ww17 scale give err display and then goes blank. I tried a new 2032 battery also Can you please advise Joe
You have to turn it on before you step on the scales.
Tap the scales in the center with your foot. lines will appear and then 0.0 then step on to weigh yourself.
Jul 01, 2010 | Conair Large Digital Display Memory...
Err 4
Jul 02, 2009 | Taylor 5757 Digital Glass Body Fat Scale
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Conair scale ww36gd err reading
I have a WW36DG digital scale and most of the instructions are the same, so far as I can see. When you tap on the scale, 888.888 appears. It is just seting itself. If you step on the scale before it reads 00.0 it wil give you a Err signal. If you stepped on the scale after it read 00.0, and an Err signal appears, either your battery is very low or it is malfunctioning. it does have a 10 year warranty on it. For the person wanting to set the scale, here are the directions. Good luck.
Customizing Your
Weight Watchers® Body Fat Monitor
1. Tap center of scale platform with foot to activate digital display (display will
flash).
2. Wait for "0.0" to appear in display window.
3. You are now ready to input your personal data. Firmly press the SET button
located below the display.
Enter User Number
• P-01 will flash in display window
• Press UP or DOWN arrows to select your individual user
number (Ten user numbers available: P-01 through P-10)
• When selected user number appears in display, press SET
button to save user number
• The scale is now ready for you to enter your height
Set Height
• "Ht" (height) will flash in display window
• Press UP or DOWN arrows to scroll to your height measurement
• Press SET button to save height
• The scale is now ready for you to enter your age
Set Age
• "Age" will flash in display window
• Press UP or DOWN arrows to scroll to your age
• Press SET button to save age
• The scale is now ready for you to enter your gender
Set Gender
• The gender icons will flash in display window
• Press UP or DOWN arrows to select male or female icon
• Press SET button to save gender
• The scale is now ready for you to weigh yourself and to
determine percentage of body fat
Nov 25, 2007 | Conair TAD1216PWT Digital Answering...
Conair Weight Watchers WW35 Body Fat Glass Electronic Scale Logo
361 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Danny Kuhlmann
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
