How to open and change Santo SC-S260 filter bag ?
    Problem Solver:
  • 13 Answers
To modify a web server and web server pages you need to log in into the system *** an user that have enoght privilages to modifi the software packages and the web directory where all those web sites reside...
in Linux like OS that is the "root" user you can access to that user account by the "sudo" command or the "su" command..
in Windows the user will be the "administrator"
now that you have access to the system as an superuser you can go and modify a web page using a text editor i recommend "scite" for linux and the "notepad" for windows.
if the web site that you want to modify is on web server Apache you have to go
to the web directory root in linux like os this directory is "/var/www/"
in Windows that directory will be C:/Program -files/folder of web server application folder
i hope this helps
Posted on May 27, 2011
Sanyo sc-s260 user manual
I want to clean my vacum cleaner, How i can open my sanyo vacum cleaner model: sc-s260
Dec 26, 2013 | Metropolitan Vacuum Cleaner Vacuums
Need to change bag
here's the link to the instruction manual; http://sanyoservice.com/pdf/images/SC-180E.PDF (it is for the sc-150 and sc-180) Check page 8 for details. Hope this helps :)
Jul 31, 2007 | Sanyo Transmax SC-150 Bagged Upright...
Electrolux side by side refrigerator water not dispensing
Hello - I would suggest checking that the water valve is completely open (usually located on the back of the unit). When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. A clogged water filter or a blocked supply water valve may also lead to no water to the dispenser.
Oct 14, 2012 | AEG Santo 7085 KG Side by Side...
Can't find paper bags SC - P11 or electrostatic micron filter SC - F2 at any retail stores
Try a local vacuum repair shop. Most of the major retailers carry in stock mostly what they sell.
The local repair shop may not have the bags in stock, however they should know where to get them from.
I just checked my supplier here in Canada and they have the bags, but not the filter. Take the filter with you that you are looking for, maybe the store will have a suggestion of a replacement.
Good luck,
Mark
Nov 10, 2010 | Sanyo SC-180 Bagged Upright Vacuum
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
How do I install new filters on a Miele Blue Moon?
There are two filters on the blue moon. The hepa filter and the motor filter. You get to both filters the same way. You open the lid, like you do when you change a bag. The motor filter is right behind the bag inside a plastic cover. There should be two tabs you can pull down to open and access the filter. The hepa filter is located toward the back of the bag chamber but on top. There is one tab in the middle that lift up on.
Sep 23, 2009 | Miele Blue Moon Bagged Canister Vacuum
I can not find how to get the canister apart to empty the dirt.
From the bottom of your machine going upwards past the handle that is on the canister portion of this vacuum, you will see that the top of that canister had a depression where you should be able to put your fingers in, and gently pull that lid back, opening the vacuum bag compartment. According to the manual, simply pull that back, exposing the bag. To remove the bag, pull the cardboard plate on the top of the bag, out towards the no open face. Throw away your old bag, and take your new bag, fold down the paper sides of the bag, then slide the new bag into the track completely. Close your lid, and you are done.
While you have this compartment open, it's a good idea to check your filter that sits below the paper bag.
Part numbers
Paper Bag: SC-P11
Filter: SC-F2
I hope this helps you.
Jan 20, 2009 | Sanyo Transmax SC-180 Handheld Vacuum
AEG Santo 1683-TK7 Led's and interior light flashes when door is opened
as rwsummers correctly points out replace this part as from uk i bought it from maplins £3.31 part no N74CN 1UF 275V de-solder the two points on rear of pcb and re-solder new part in place and reassemble turn on power and "voila" works like new. Thanks.
Oct 06, 2008 | AEG Refrigerators
Sanyo vacuum cleaner bag
We have the Sanyo Transfomax 3 in 1 vacuum and FINALLY found that one has to use a screwdriver at the edges of the "hand hold" just above the Sanyo name (between black and green parts), to pop open the cleaner in order to replace the bag or clean the filter.
What a miserable way to change a bag!
I know this is almost a year late...but I just found your request. Ta ta, Rita
Sep 16, 2007 | Sebo X4 Bagged Upright Vacuum
Computers & Internet Logo
David Payne
David Payne
