Question about Dryers
Ceiling fans.. I have a ceiling fan that I bought from meijer, it came with a remote, my friend put it up with out putting the transmitter for the remote in. I want to use my remote, but do not know where it goes. I cannot find the instructions.
Does blue wire connect to black wire on model 99328
Posted on Oct 09, 2008
Are you talking about the receiver? If so connect wires from fan, White, black,blue to receiver white, black, blue. White to white and so on. Then connect the two wires from other side of receiver, white and black(or Red) to corresponding colors from ceiling. Then store receiver just above the ball in the ceiling mount plate, you will have to move the wires to the side and push it in. Hope this helps
Posted on Aug 19, 2008
Need code for concord ceiling fan remote RM-100-A
There is no code! You have to match the frequencies in the transmitter & receiver. The dip switches in the transmitter will be where you put the battery.
Sep 02, 2014 | Dryers
WHERE THE REMOTE CONTROL TRANSMITTER IS LOCATED IN THE CEILING FAN
The transmitter is the piece you hold in your hand, the reciever is the part that fits inside the ceiling fan. It usually goes inside where a lamp attaches to the bottom of the fan.
Aug 01, 2014 | Hunter Sontera 52" Ceiling Fan with...
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
Harbor breeze ceiling fan w/lights&remote
Did the fan have a remote when it was purchased? If so, you already have a receiver in the fan somewhere. You'll have to find it to see if you can set the new transmitter to the same frequency.
Jul 23, 2013 | Dryers
How to reverse kichler ceiling fan, UC7206T
Stock Kichler ceiling fan c. 2006, works with replacement remote control 337001WH hand-held unit from Amazon 2013. Started running backwards when two remotes were activated at the same time by accident. Random button pushing on two remotes simultaneously got it to go back to forward. (Apparently original remote hand-held transmitter had forward/reverse setting, but the substitute 337001WH transmitter doesn't. When two transmitters run at the same time, the fwd/rev code may be decoded in the collisions at the receiver. Thank goodness!)
Jun 13, 2012 | Kichler Lighting 300105CTO Ceiling Fan
We have just bought a home that 3 of the living room/dining room fans are on 1 remote and that remote has quit. We've put in a new battery but it still doesn't work. Can they just go bad ??? Where...
Yes, they can. Another possibility, however, is the jumper settings could have been accidently changed when the battery was changed. Inside the remote is usally four little switches in a row, each can be on or off (zero or one). These need to be set to the same values as the receivers in the fans.
Sep 18, 2011 | Hunter Ceiling Fan Remote Transmitter...
Remote
I usually move wires around to accommodate them in under mount where is sort of "U" shaped between it and ceiling box. That's where most illustrations advise, then small transmitter wire ,sticks out from trim under cover.
Jan 15, 2010 | Aloha Housewares (93645) Ceiling Fan
Installation
I assume that you're talking about a remote-controlled ceiling fan.
There are two parts to a remote-control setup -- the transmitter (the switch which you use to operate the fan and/or light), and the receiver (which receives the signals sent by the transmitter, and directly controls the fan and/or light).
The receiver -- which should look like a plastic rectangle, usually white, grey, or orange-brown in color -- can be identified by the fact that it has several colored wires coming out of it, and doesn't have any buttons. This is mounted in the ceiling fan itself. On nearly all setups, it goes inside the canopy (the decorative part of the ceiling fan, up by the ceiling, which hides the fan's electrical wires).
The transmitter may be either hand-held like a television remote control, or in-wall mounted like a light switch. If you have the hand-held variety, there is nothing to install in a wall box. The wall-box wires should be appropriately connected up, and a blank cover plate should be put on top of the gang box.
If, on the other hand, you have the in-wall variety of transmitter, then yes -- it gets mounted in the wall, in a gang box, like a normal light switch or outlet.
If you need any further clarification, please feel free to ask!
Jun 17, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
299 people viewed this question
Top Dryers Experts
