Question about Groove Tubes Tascam Cd-gt2 Portable Cd Guitar Trainer Cdgt2 Bstk
Hi, I have the Tascam Portable CD guitar trainer, model CD-GT1 (it has the date May, 2004 on the bottom side). I am wondering if I can get an instruction manual for this, as I don't have it and need it to operate the thing. I know it is outdated, but maybe someone can help me with getting the manual. Thanks, Kate mccabe
  • Groove Tubes Master
  • 5,603 Answers
You would probably find that the manual for the Vocal trainer, VT-2 would be very similar to the GT-2. Search for the manual for the VT-2.
Posted on May 29, 2011
I bought a Tascam ga-30cd amp new, and have barely used it for about six months. Yet it periodically crackles and sound drops out in the middle of a song. I will then press the boost button and it will...
I suspect there is bad soldering on the circuit board in the vicinity of that button. The movement causes the connection to re-establish. It isn't necessarily one of the button leads. Look for a little grey line around the menicus of one of the soldered leads.
Jul 25, 2011 | Tascam Ga30cd Guitar Amplifier with CD...
Tascam CD Gt1mkii CD Guitar Trainer - skipping around quite a lot, on any cd .unusable. can it be fixed easily and cheaply?
VERY carefully clean the lens with a QTip and 99% isoprophyl alcohol. Use ONLY 99% and it can be a bit hard to find.
Be careful to NOT snag the QTip cotton on the carriage or parts holding the lens... clean ONLY the lens, very gently. Let dry thouroughly before trying it again.
Sep 28, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
Keeps switching off and showing tocread on display
That probably means it can't read the "Table Of Contents" which is essentially the directory of the disc.
MAKE SURE any disc you try to read has been "finalized".
Any disc that you have burned that can have stuff added is NOT finalized and may not work in certain CD players.
May 08, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
My tascam cd gt1 does not display anything when the power is turned on. i think that maybe it s the switch. completly dead. help
Test the power adapter to make sure that there is power at the plug (volt ohm meter). Try wiggling the plug while it is plugged into the unit with the power switch on. If it works intermittently it means that the solder joint for the power adapter jack has failed on the circuit board. If that isn't the problem it probably is the power switch that needs to be tested next. IF you aren't confident with disassembling the unit far enough to do the tests you will need to take it in for servicing. Let me know how you make out.
Jan 19, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
My Tascam CD GT1 mkii guitar trainer is doing everything except when I plug my guitar into the unit, I can not hear my guitar?
Here is the manual if you don't have one:http://www.tascam.com/details;9,21,23,19.html Make sure your guitar cord is working. Make sure your are plugged into the Guitar/Mike input jack.Do not connect a guitar amp to this jack via line out on the amp or otherwise. Set the Guitar/Mike switch to Guitar. Use the Input control to adjust the level of the input.Adjust your Headphone level using the Output control.Carefully read pages 12, 13, 14 and 15 of the manual.There are various combinations of controls that would make your guitar too quiet to be heard. Example: Mix Balance page 24. Let me know if this helps.
Nov 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
No manual for the above as i lost it can anyone help
Look under the resources tab and you will be able to download the manual at:http://www.tascam.com/products/cd-gt1mkii;9,21,23,19.html
Aug 18, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Tascam CD-GT1MKII is turning off and on by itself
are you plugged in or on batts as mine was on batts and they were low.
Jul 29, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Lost oners manual for tascam cd-gt1mkii
You can find one here:
http://www.tascam.com/details;8,21,23,19.html
Apr 06, 2009 | Tascam CD Gt1mkii CD Guitar Trainer
Groove Tubes Tascam Cd-gt2 Portable Cd Guitar Trainer Cdgt2 Bstk Logo
119 people viewed this question
Top Groove Tubes Music Experts
Michial Gueffroy
Are you a Groove Tubes Music Expert? Answer questions, earn points and help others
